40 KHz burst
Results 1 to 5 of 5
Thread: 40 KHz burst
    This will get you spot-on 40kHz with a 4MHz oscillator.
      Cycles VAR BYTE
      TRISIO.0=0  ' make pin an output first
      GOTO Main   ' jump over Pulse routine to Main
     ' @ 4MHz generate Cycles number of 40kHz pulses
    asm
    _Pulse
       bsf  GPIO,0 ; change to whatever port pin you have available
       goto $+1    ; 2uS per GOTO $+1
       goto $+1
       goto $+1
       goto $+1
       goto $+1
       bcf  GPIO,0
       goto $+1
       goto $+1
       goto $+1
       goto $+1
       goto $+1
       decfsz _Cycles,f
       goto _Pulse  ; 25uS total for 40kHz carrier
       RETLW 0      ; return to CALLing routine
      Cycles = 8    ' number of carrier cycles to generate
      CALL Pulse
      PAUSEUS 24
      GOTO Main
    Just enter the number of carrier cycles you need to generate in the Cycles var, and
    CALL the routine.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jul 2009
    Thank you both a million for your help, I had done it with ASM and ENDASM but not as elegant as Bruce did, I just coded the delay using NOPs and the the eight pulses hard coded.
  1. What's the best way to output 30 to 40 kHz from a 12F683 pin?
    By fizyxman in forum mel PIC BASIC Pro
    Last Post: - 1st June 2009, 01:08
  2. Resonator Suppliers for 40 MHz?
    By mcphill in forum General
    Last Post: - 23rd January 2009, 03:05
  3. with 40 MHZ osc serin2 not work
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 13th August 2006, 23:56
  4. 40 kHz wave
    By RUBiksCUbe in forum mel PIC BASIC Pro
    Last Post: - 14th December 2005, 21:01
  5. Catching 12 khz
    By SuB-ZeRo in forum Schematics
    Last Post: - 15th June 2005, 08:11
