Setting bits
Results 1 to 10 of 10
Thread: Setting bits
    Well that certainly would work as well. Thanks. I was hoping there would be some kind of command like DCD that would just magicaly set all the bits on but I guess not. I might look into just manipulating the bits some how. then again, I havnt looked but how many CPU cycles does the lookup command take? anyone know?
    No magic commands, but maybe this will do ...
    BarGraph is a Word var.
    BarGraph=$FFFF<<(LEDcount-((BarData-RangeLOW)*LEDcount)/(RangeHIGH-RangeLOW))
    If the BAR is going the wrong way, just change it to shift right (>>).
    Bombay, India
    Wow Darell, that's an ace. I use this for scaling readings but never thought of it this way. Nice tip.
    Superb
    Thanks Jerson,
    bearpawz had most of it already, I just filled in the blanks.
    Then compiled, tested and heard ... Ohhh Yeeaaah, before I realized it was me talking.
    Last Post: - 14th June 2016, 08:55
  2. Configuration bits setting problem
    Last Post: - 26th August 2009, 18:25
  3. PICKit2 - warning about configuration words
    Last Post: - 4th August 2009, 15:01
  4. error on compiling
    By parker in forum mel PIC BASIC Pro
    Last Post: - 16th June 2005, 15:31
  5. Trouble setting config. bits
    By jswayze in forum mel PIC BASIC Pro
    Last Post: - 13th March 2004, 23:22
