During power up ...
all pins are INPUTS ( say floating ! ) ... till you turn them to outputs.
So ...
1) place some pullup or pulldown ( to suit your application ) resistors to fix the outputs ( may be inputs too, depends on circuitry ahead ... )  levels while they are " uncontrolled "
2) program output and input levels required ( PORTx = % 11001010 i.e )
3) THEN program inputs and outputs ( TRISx = % 00110110 i.e )
This way ... outputs are fully under control ... Even if Pic is taken off from its socket !!!
