"Select Case" Help
Results 1 to 10 of 10
    Jan 2006
    Istanbul
    <font color="#000080"><i>
    </i></font>Temp <font color="#000080"><b>VAR WORD
    </b></font>Temp = <font color="#FF0000">512 </font>- voltage <font color="#000080"><i>' Voltage
    </i><b>SELECT CASE </b></font>Temp
        <font color="#000080"><b>CASE IS </b></font>&lt; <font color="#FF0000">256 </font><font color="#000080"><i>' Voltage is greater than 256.
    </i><b>END SELECT
    </b></font>
    bmsherma, Try this...
    SELECT CASE VOLTAGE
    CASE < 257
    PORTC = %0001
    CASE < 513
    PORTC = %0010
    CASE < 769
    PORTC = %0100
    CASE < 1024
    PORTC = %1000
    END SELECT
    Pause 100
    I use this construct when determining groups of numbers. You start with the smallest and move up to the largest.
    Nov 2009
    Default Thanks
    Thanks everyone for the advice.
    Dave P, your idea seems to work. However what if I want to isolate the low range OR the high range. I'm essentially trying to put logical operators in my case statement.
    Case is < 256 OR is > 768
    PORTC = %0001
    Case Else
    PORTC = %1000
    Can I write that first Case statement with the OR term?
    Or would I have to do this:
    Case is < 256
    PORTC = %0001
    Case is > 768
    PORTC = %0001
    Case else
    PORTC = %1000
    Is there no way to use logical operators in Case Statements in PICBasicPRO??!
    bmsherma, The second way you have it is the way I would do the construct..
    Quote Originally Posted by bmsherma View Post
    NO!, logical operators are NOT allowed in Case statements.
    Nov 2009
    Default Thanks
    Thanks everyone for the help!!
    This forum is GREAT
    Wink
    With a very, very very little Trickery ... I think it makes it.
    IF ( Voltage.8 ^ Voltage.9 ) THEN
       PORTC = 1
       PORTC = 8
    Wink
    Or ... With Select Case
    Voltage = Voltage.Highbyte
    SELECT CASE Voltage
        Case 1,2
           PORTC = 1
        Case Else
           PORTC = 8
    END SELECT
