Hi Al, Dave and Dave
This appear to be an HSEROUT issue!!
When I use HSERIN with a string before the variables like this - check reciver code HSEROUT line
RECEIVER
Code:'variables begin here A0 var byte net var byte led var PORTD.0 SYNK VAR BYTE SYNK = $7E 'end of variables test: hserin [WAIT(SYNK),DEC net] if net = 23 then lcdout "i got 23 " toggle LED 'lcdout $fe,1 endif HSERout ["got this",DEC net,$d,$a] 'net var show in hyperterminal got test end
TRANSMITTER
then the number 23 as well as the number 2 appears !!Code:'RF variables 'A0 var BYTE 'A0=23 'TRAIN VAR BYTE 'TRAIN=$55 TRAIN VAR BYTE train = $B3 SYNK VAR BYTE SYNK = $7E 'Variables end here loopy: high LED ' LED on hserout [TRAIN,SYNK,dec 23] low led 'LED off Goto loopy ' Go back to loop and blink LED forever End
See here:
If I remove the string of letters , in this case "got this " then every single received line shows only the number 23 which is what we are expecting to see!Code:got this23 got this2 got this23 got this2 got this23 got this2 got this23 got this2 got this23 got this2
See here:
PERFECT except for once in a while the occasional number like 2 or 3 shows up!Code:23 23 23 23 23 3 23 23 23 23 23 23
And trying Al's suggestion of removing the DEC modifier (only on receiver side and for both hserin and hserout)
I get this
Now tell me that's not a strange oneCode:got this2 got this2 got this2 got this2 got this2 got this2 got this2 got this2
Now...some really awesome observations from my tests here :
First off this is working like a charm !
It's pretty damn close to near perfect in terms of reliable data transfer! (would love any further suggestions re checksums -- I though of something like catching a few instanced of the byte and then accepting it as correct!
Range is awesome ! Right now, as I am typing this the Transmitter is outside my house at the edge of the property - well over 200m and I have taken it upstairs and downstairs every little nook and cranny and it's still spot on !
Speed is fantastic - its so fast the led hardly blinks and the MCS serial tool window is filled up in less than a second
I have both receiver and transmitter hooked up to a 9V battery and then into a 5V regulator with no caps anywhere. My entire house is flooded with 2,4 and 5,8 GHz wireless and there are electrical appliances plentifold.
If the receiver is left in powered on happily waiting for it's signal , as the transmitter is powered on the receiver has already caught at least 6 bytes :-) ...this is how wireless should be in a perfect world :-)
I would be happy to report that the combination of train and sync byte are a winner! Spot on Mackrackit - thank you!
I am extremely happy with verything so far and just want to thank all of you who have guided me with code snippets, corrections and everything else!
Thank you so much !!
Dave Houston I will still definitely be getting you code working too, come rain hail or snow!
All that remain (for now :-)) is the ability to send more than one byte.
I was thinking 3 bytes. (24 bits total)
So my question is this:
Assuming I am to stick with this method , what is the best method (most relaible) to be adding more bytes to be sent ?
Thanks yet again
Kind regards
Dennis
