PIC to PIC TX RX and PIC to PC COM RX ..a little help please
Results 1 to 40 of 68
    Dec 2005
    Quote Originally Posted by Dennis View Post
    I tried the same transmitter and receivers using your code as well but have no success when I use it but it does work when the two PICS are connected by wire !
    If it works wired but not wireless, the most likely explanation is that you have something amiss in the way you have connected the TX/RX modules.
    Default uncanny behaviour!!
    Hi Al, Dave and Dave
    This appear to be an HSEROUT issue!!
    When I use HSERIN with a string before the variables like this - check reciver code HSEROUT line
    RECEIVER
    'variables begin here
            A0 var byte
            net var byte
            led var PORTD.0
            SYNK VAR BYTE
            SYNK = $7E
    'end of variables
    test:
    hserin [WAIT(SYNK),DEC net]
        if net = 23 then
        lcdout "i got 23 "
        toggle LED
        'lcdout $fe,1
     HSERout ["got this",DEC net,$d,$a] 'net var show in hyperterminal
     got test
    TRANSMITTER
     'RF variables
     'A0 var BYTE
     'A0=23
      'TRAIN	VAR BYTE
     'TRAIN=$55
     TRAIN  VAR BYTE
     train =  $B3
     SYNK VAR BYTE
     SYNK = $7E
     'Variables end here
    loopy:
    high LED '  LED on
    hserout [TRAIN,SYNK,dec 23]
     low led 'LED off
     Goto loopy  ' Go back to loop and blink LED forever
    then the number 23 as well as the number 2 appears !!
    See here:
    got this23
    got this2
    got this23
    got this2
    got this23
    got this2
    got this23
    got this2
    got this23
    got this2
    If I remove the string of letters , in this case "got this " then every single received line shows only the number 23 which is what we are expecting to see!
    See here:
    23
    23
    23
    23
    3
    23
    23
    23
    23
    23
    23
    PERFECT except for once in a while the occasional number like 2 or 3 shows up!
    And trying Al's suggestion of removing the DEC modifier (only on receiver side and for both hserin and hserout)
    I get this
    got this2
    got this2
    got this2
    got this2
    got this2
    got this2
    got this2
    got this2
    Now tell me that's not a strange one
    Now...some really awesome observations from my tests here :
    First off this is working like a charm !
    It's pretty damn close to near perfect in terms of reliable data transfer! (would love any further suggestions re checksums -- I though of something like catching a few instanced of the byte and then accepting it as correct!
    Range is awesome ! Right now, as I am typing this the Transmitter is outside my house at the edge of the property - well over 200m and I have taken it upstairs and downstairs every little nook and cranny and it's still spot on !
    Speed is fantastic - its so fast the led hardly blinks and the MCS serial tool window is filled up in less than a second
    I have both receiver and transmitter hooked up to a 9V battery and then into a 5V regulator with no caps anywhere. My entire house is flooded with 2,4 and 5,8 GHz wireless and there are electrical appliances plentifold.
    If the receiver is left in powered on happily waiting for it's signal , as the transmitter is powered on the receiver has already caught at least 6 bytes :-) ...this is how wireless should be in a perfect world :-)
    I would be happy to report that the combination of train and sync byte are a winner! Spot on Mackrackit - thank you!
    I am extremely happy with verything so far and just want to thank all of you who have guided me with code snippets, corrections and everything else!
    Thank you so much !!
    Dave Houston I will still definitely be getting you code working too, come rain hail or snow!
    All that remain (for now :-)) is the ability to send more than one byte.
    I was thinking 3 bytes. (24 bits total)
    So my question is this:
    Assuming I am to stick with this method , what is the best method (most relaible) to be adding more bytes to be sent ?
    Thanks yet again
    Kind regards
    Dennis
    May 2008
    Italy
    ...And trying Al's suggestion of removing the DEC modifier (only on receiver side and for both hserin and hserout)
    Dennis, I suggested you to remove the DEC modifier in Transmitter not in the receiver side.
    The reason is that you Tx a pure ascii code and convert it to decimal at the receiver side, while now you are modifying the byte twice (at Tx & at Rx) and can yield wierd results.
    Al.
    Thanks Al for pointing out my mistake.
    Dennis,
    Just for fun, send this straight to the terminal, you might find it interesting.
    XNUM    VAR BYTE[8]
    XNUM = 225 'CHANGE THIS NUMBER AS NEEDED
    SEROUT2 GPIO.5,16780,[TRAIN,SYNK,DEC XNUM.7,DEC XNUM.6,DEC XNUM.5,_
       DEC XNUM.4,DEC XNUM.3,DEC XNUM.2,DEC XNUM.1,DEC XNUM.0,_
       "--",DEC XNUM,$d,$a]
    More bytes?
    SEND
        XNUM    VAR BYTE
        YNUM    VAR BYTE
        ZNUM    VAR BYTE
        XNUM = 225
        YNUM = 100
        ZNUM = 4
        START:
        SEROUT2 GPIO.5,16780,[TRAIN,SYNK,XNUM,YNUM,ZNUM,$d,$a]
        PAUSE 5000
        GOTO START
    RECEIVE
        XNUM    VAR BYTE
        YNUM    VAR BYTE
        ZNUM    VAR BYTE
        START:
        SERIN2 GPIO.5, 16780,[WAIT(SYNK),XNUM,YNUM,ZNUM]
        SEROUT2 GPIO.4,16780,["X-",DEC XNUM," Y-",DEC YNUM," Z-",DEC ZNUM,$d,$a]
        GOTO START
    Default ok.... just for fun !
    Al thanks a million for the clarity on that one .. will check and feedback !
    Dave ... ok just for fun so be it !
    And if I get greedy would the Var bytes be num num num ? :-)
    Expect Feedback .. results may vary :-0
    Kind regards
    Dennis
    Default working!!
    Hi Dave ;-)
    That TX RX code you passed on works like a charm too X Y and Z coming through clear as day although I changed it for HSERIN and HSEROUT
    Not sure what you want me to try with this code though ??
    [code]
    XNUM VAR BYTE[8]
    [code]
    Did you want me to TX/RX it ? modify and put on send and receive side ?
    Dennis
    Thumbs up Mods
    Hi Al
    I applied your suggestion , unfortunately it didn't work , my receiver side has an IF ..THEN statement looking for the number 23, and implementing your suggestion on the TX side only doesn't seem to send the correct DEC 23 to the RX so the IF condition is never met ...check my receiver side code for clarification.
    To confirm , I only left the DEC modifier on the receiver side.. (please note though that at the receiver side I have hserin and hserout statements using the DEC modifier.
    I placed your code suggestion on the TX of the first PIC only ..so it looks something like this
    TX ----------- hyoerterminal
    TX ------RF----- RX
    PIC1 PIC2
    Will bash around with it a little more and see what comes of it :-)
    I'll post result back as soon as I have double checked each step too.
    kind regards
    Dennis
    Hi Dave ;-)
    Really??? Well how about that...
    [code]
    XNUM VAR BYTE[8]
    [code]
    Dennis
    Send directly to a terminal.
    You said you wanted three bytes, sometimes 8 bits can be as good. just thought you might see a use... splitting the byte up, multiple outputs on the same port... but if you need 23 then it will not help you this time.
    Al was suggesting you only put the DEC on the RX side. That is why I thanked him for pointing out my mistake. I put a DEC on both in a couple of post.
  1. Direct PIC to PC without MAX232
    By acjacques in forum Serial
    Last Post: - 23rd October 2014, 22:32
  2. Serial VB 2005 pic 16f877a problems
    By Snap in forum mel PIC BASIC Pro
    Last Post: - 8th July 2013, 01:52
  3. PIC or xbee times out after Tx 504 bytes
    By archendekta in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2009, 09:45
  4. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 15:46
  5. RX TX modules - intermitent communication
    Last Post: - 11th June 2009, 01:13
