PIC to PIC TX RX and PIC to PC COM RX ..a little help please
Results 1 to 40 of 68
    The Dave Houston page to read, but study his whole site for that matter.
    http://davehouston.org/RFTipsTricks.htm
    If you are using DEFINE to set up the HSER then do not add these lines. That is what the DEFINES are for.
     RCSTA = $90 ' Enable serial port & continuous receive
     TXSTA = $20 ' Enable transmit, BRGH = 0
     SPBRG = 51  ' 2400 Baud @ 8MHz, 0.17%
    The 93 thing has me confused at the moment.
    You might try SERIN2/SEROUT2 for giggles while you are playing with this serial stuff...
    Default Ok... been reading and studying like a bat outta hell..
    Dave ...Thanks a million !
    So while the error prevails ...
    Do you have any code snippets I could try to start testing the RF portion be it SERIN/DEBUG/HSERIN etc.
    Perhaps I will find the error in the code while I am experimenting :-)
    Kind regards
    Dennis
    Here is part of something from a past project. The "TRAIN" part is the controversial part. But some how the data slicer needs set up. This is where Houstons site is handy..
    SEND:
    TRAIN	VAR BYTE
    TRAIN=$55
    SEROUT PORTC.4,T2400,[TRAIN,TRAIN,TRAIN,TRAIN,TRAIN,9,3]
    RECEIVE:
    SERIN PORTC.4,T2400,[9],net
    This is just the basic way, you can make it all more reliable by adding checksums and stuff...but this should get you started.
    Default it works ...kinda
    Hi Dave :-)
    How are you ?
    Well the lines you gave me work on the wire ..just like before...so I decided to try the TX/RX RF pair TLP-434 and RLP-434 from Bruce at Rentron.
    And .... it works ...kinda :-)
    Instead of seeing the number 3 (DEC 3) it shows me the number 2 (DEC 2) in MCS serial terminal window.
    oh and it also seems to bypass the if NET=3 statement/test for some reason ..I don't think it ever 'sees' a 3 coming in.
    So now I'm wondering where I have gone wrong :-(
    Here's my receiver code :
    'Keypress display on LCD and TX to wherever
    'Ocsillator selections here
    'DEFINE OSC 8
    'OSCCON=%01110000
    'or
    'DEFINE OSC 4
    'OSCCON=%01100000
    'OSCTUNE.6 = 0 'PLL Multiplier disabled
    'OSCTUNE.6 = 1 'PLL 4x
            OSCCON = $70            'Int CLK 8MHz
            ADCON1= %00001111       '$0F = disable A/D converter
            cmcon   =   7
            INTCON2.7 = 0     'switch pull-ups ON
    'END of oscillator selections
      'timer/oscillator defines
            DEFINE OSC 32            '4x 8MHz
    'END of timer/oscillator defines
    'Port IO directions and presets for port pins begin here
    'TRISX = %76543210   << tris bit order numbering
    'TRISA = %11111111       'All pins are inputs
    '// Define port pins as inputs and outputs ...
            TRISA  = %00000000 'example only - TRISB = %00001111 ;Make B4-B7 outputs, B0-B3 inputs,
            TRISB = %11111111  'for 4x4 keypad all input
            TRISC = %10010000
            TRISD = %00000000
            TRISE.0 = 0
            TRISE.1 = 0
            TRISE.2 = 0
    'End of Port IO directions and presets for port pins begin here
    'variables begin here
            net var byte
            led var PORTD.0
    'end of variables
    'includes begin here
            INCLUDE "modedefs.bas"
            include "c:\pbp\samples\keypad.bas"
    'end of includes
    high LED
    'RF SERIN line here
         serout PORTC.3,T2400,["the key pressed or received value is ",net,10,13]
          low led
          IF net = 3 then
           low LED
        serout PORTC.3,T2400,["the key pressed or received value is ", net,10,13]
    'LOOKUP  net,[0,"123A456B789C*0#D"],net 'use lookup table to diplay proper display in hyperterminal
    '************************SEROUT TO HYPERTERMINAL
    and the transmitter code
    '16F887 Transmit to PIC 18f4520 serout loop
     '@__config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_ON & _LVP_OFF & _CP_OFF
      'OSCCON = %01100001 for 4mhz, or OSCCON = %01110001for 8mhz
    '        OSCCON = %01110001           'Int CLK 8MHz
    '        ANSEL= %11111111       '$0F = disable A/D converter
    '        option_reg = 7     'switch pull-ups ON
     '       define osc 8        '8MHz
    'clear the ports
    ANSEL = %00000000           'All digital
    OPTION_REG.7 = 0            'Weak pull-ups enabled
    DEFINE OSC 8                '8MHz
    PORTA=0
    PORTB=0
    PORTC=0
    PORTD=0
    PORTE=0
    'end of port clear
    'TRISA = %11111111    <<   'All pins are outputs
            TRISC = %10100000
            TRISD = %00000000
            TRISE.0 = 0
            TRISE.1 = 0
            TRISE.2 = 0
    'end of includes
            LED var PORTd.0   ' Alias PORTD.0 to LED
     'RF variables
            TRAIN	VAR BYTE
            TRAIN=$55
            net var byte
     'Variables end here
    loopy:
            high LED '  LED on
            'for RF use the line below
            low led
    goto loopy
    Any help would be greatly appreciated
    Kind regards
    Dennis
    Getting a 2 ?? Maybe you just need to add 1
    Try sending something other than a 9 or waiting for something other than a 9.
    It must be seeing the 9 or it would not go on to the next command.
    This is the very most basic code, but it does work. I pulled it from my "laser fence". If the beam is broken the TX kicks in and an alarm goes off at the house.
    DEC net
    Might be the missing link...on the display
    If the LED goes low then I would say it is working, but try sending something else and see what happenes.
    Default and now for the next step
    Hi Dave
    I still haven't solved the number 3 problem
    Where should I place the DEC keyword in ? As I try to compile with DEC keyword in, MCS spits out compile errors.
    I am using TLP-434 and RLP-434 modules.
    With this in mind would you suggext I now start adding in manchester encoding ?
    Should I be trying SERIN/OUT2, DEBUG and HSER first ? (these all worked well when the PIC's were wired together)
    I see your lines of serin code pre-condition the receiver first, should i be sending more $55's ?
    As always any help or suggestions,tips,tricks etc would be greatly appreciated.
    Kind regards
    Dennis
  1. Direct PIC to PC without MAX232
    By acjacques in forum Serial
    Last Post: - 23rd October 2014, 22:32
  2. Serial VB 2005 pic 16f877a problems
    By Snap in forum mel PIC BASIC Pro
    Last Post: - 8th July 2013, 01:52
  3. PIC or xbee times out after Tx 504 bytes
    By archendekta in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2009, 09:45
  4. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 15:46
  5. RX TX modules - intermitent communication
    Last Post: - 11th June 2009, 01:13
