What an awesome calculator proggie ;-)
A true GEM !
Thanks a million
Dennis
A true GEM !
Thanks a million
Dennis
Thank mister e for the MultiCalc, I use it often.
http://melabs.com/resources/samples/pbp/usart.bas
Play with the above to get started with the USART. Notice they did not use DEFINES.
The program will echo your keyboard with one PIC connected to a PC. The terminal program that is part of MCS is good for this setup. I think the above sample is for 4Mhz. So check the values with MultiCalc.
Keep us posted...
Hi dave
Thanks again :-)
For my 16f887 i have the following set for using the internal clock
So I use 8 MHZ not so ?Code:OSCCON = %01110001 'Int CLK 8MHz ANSEL = %00000000 'All digital OPTION_REG.7 = 0 'Weak pull-ups enabled DEFINE OSC 8 '8MHz
For the 184520 the following is set
So do I choose 4MHz or 32 MHz ?Code:'Ocsillator selections here OSCCON = $70 'Int CLK 8MHz OSCTUNE.6 = 1 'PLL 4x ADCON1= %00001111 '$0F = disable A/D converter cmcon = 7 INTCON2.7 = 0 'switch pull-ups ON 'END of oscillator selections 'timer/oscillator defines DEFINE OSC 32 '4x 8MHz 'END of timer/oscillator defines
thanks a million
Kind regards
Dennis
For the 887 use 8Mhz for the calcs.
I am not sure about the 4520, I have not used USART with PLL enabled.
But...
I think the USART uses the primary OSC so try 4Mhz. 50 50 chance of it working![]()
Hi Dave
Could I set both PICS to 4 MHz internal OSC ?
And once it's working try variations ?
That would be the way to trouble shoot.
Just make sure they are running at the expected speed with a blinky and a stop watch or meter if you have one..
Hi again Dave
I think I am almost ready for the next step ....
RF and RF module TX RX
I have been reading posts all through the forums, even some of yours from years back ...
Now for the next step ... to try the same or a similar thing without the wires.
Should I start off with sering or plunge straight into HSER ?
The plan is to be able to send 3 bytes using the most reliable method.
So the question is where do I start and what do I start with ?
Kind regards
Dennis
