Hi Dave :-)
How are you ?
Tried the code exactly as you suggested ...
On the receiver end it seems like debug is just WAITing forever to receive the number 9 match but it never seems to get it, so that's where the program stops.
I thought it might be the order of the numbers so I changed their order but that didn't fix the problem.
Is it possible that the problem could be on the receiver PIC as I still have a serout line to send the data to the PC serial port to view in hyperterminal.
Is it ok to run debug and serin in the same PIC ( wondering if this is a silly question) or should I use debug to transmit to hyperterminal as well ?
Could the problem be that I have the DEFINE statements in the wrong place ? I noticed an extra space character in the code snippet you posted between mode and 0 .. removed that and recompiled but still no joy :-(
Any suggestions ?
Here's the code :
Receiver
TransmitterCode:'debug defines begin here - necessary for degug operation DEFINE DEBUG_MODE 0 ' Debug sending TRUE serial data DEFINE DEBUG_REG PORTC ' Debug Port = PortC DEFINE DEBUG_BIT 4 ' Debug.bit = PortC.4 DEFINE DEBUG_BAUD 2400 ' Default baud rate = 2400 'debug defines end here 'Main code begins here Pause 2000 ' Wait for LCD to startup test: lcdout $fe,1 lcdout "starting tx rx" '******************************************* '*SERIN PORTC.4,T2400,[9],net 'prepare to receive the data from other PIC '*this lines works perfectly to send data '******************************************* ' '****heres the same thing using debugin (RX)- check/adjust defines for settings DEBUGIN [WAIT("9"),DEC net] '****end of debug line lcdout "rx complete" pause 1000 lcdout $fe,1 'clear lcd screen IF net = 3 then lcdout $fe,1 LCDOUT "data is ",dec net 'look for the number 3 pause 2000 endif lcdout $fe,1 lcdout "begin serout to hyperterminal" pause 1000 LOOKUP net,[0,"123A456B789C*0#D"],net 'use lookup table to diplay proper display in hyperterminal ' send net variable to hyperterminal using serout serout PORTC.3,T2400,["the key pressed or received value is ",net,10,13] lcdout $fe,1 goto test end
Code:'debug defines begin here DEFINE DEBUG_MODE 0 ' Debug sending TRUE serial data DEFINE DEBUG_REG PORTC ' Debug Port = PortC DEFINE DEBUG_BIT 4 ' Debug.bit = PortC.4 DEFINE DEBUG_BAUD 2400 ' Default baud rate = 2400 'end of debug defines LED var PORTd.0 ' Alias PORTD.0 to LED loopy: high LED ' LED on Pause 1000 ' Delay for .5 seconds low led 'LED off Pause 1000 ' Delay for .5 seconds '*this serout lines works perfectly :-) 'SEROUT PORTC.4,T2400,[9,3] '**another example - SerOut PORTC.6,T2400,["are you receiving this tx from 16f887 ",datatx] 'DEBUG line starts here DEBUG 3,9 'end of debug line pause 1000 Goto loopy ' Go back to loop and blink LED forever End 'End of all code
