PIC to PIC TX RX and PIC to PC COM RX ..a little help please
Results 1 to 40 of 68
    Smoke and mirrors???
    Here is a simple example to build on
    SEND:
    SEROUT PORTC.4,T2400,[9,3]
    RECEIVE:
    SERIN PORTC.4,T2400,[9],net
    IF net = 3 THEN DO_SOMETHING
    Connect VSS and the two PIC pins together.
    Default ok....just another question ...
    Will try the operation with only your code...
    Can one run SERIN and SEROUT on same pic as I would like to send the received data to hyperterminal and also to the LCD. So would the fol.lowing code be correct then ?
    Oh and why did you choose PORTC.4 ? Looking at the pinouts for both pics I see PORTC.6 is TX and PORTC.7 is RX -are these for hardware serial , ie. HSERIN and HSEROUT and should I use them for SERIN and SEROUT or is it better to use PORTC.4 in case I want to use them for HSERIN/OUT later ?
    Here's the code
    Transmitter PIC (16F887)
    Receiver PIC (18F4520)
    SERIN PORTC.4,T2400,[9],net 'prepare to receive the data from other PIC
    IF net = 3 LCDOUT "data is",net 'look for the number 3
    SEROUT PORTC.5,T2400,[9,3] 'send received data to hyperterminal via max232n to PC
    end if
    Smoke and mirrors indeed :-)
    Kind regards
    Dennis
    I went with PORTC4 for no good reason other than to show that the bit banging routines work on most any pin. You are correct about HSERN only working on the hardware pins.
    What I can see of your code(using phone) it looks like it should work.
    Default Thanks Dave
    Thanks a million for the feedback
    Will try it right away and feedback asap :-)
    Kind regards
    Dennis
    Default it works :-)
    Hi Dave
    Good news and a big thank you !!
    It's working...
    I am transmitting from 16F887 to 18F4520 and then from 18F4520 to and LCD and to PC serial port.
    One tiny issue I have is with the serin command.
    It displays a string fine but the variable is always a wingdings character unless I use a lookup ...(see my code below for serout on receiver)
    So I have three questions now ....
    1. Is there any way to set the serin command to send the variable (net) in the code example so that it appears as the number 3 ?
    2.Could you possibly show me a code snippet to accomplish the same thing using debug and also hser please
    3. Bearing in mind I want to eventually to accomplish all of this using RF modules, and may decide to use hserin/out ,and all I want to do is relaible transmit 3 or possible 4 bytes, would I have to use an external oscillator or would the internal suffice ?
    Kind regards
    Dennis
    Try
    DEC net
    OSCs..... Some will not agree but many times times the internal is not stable enough at higher baud rates to be reliable.
    To set DEBUG up
        DEFINE DEBUG_MODE  0    ' Debug sending TRUE serial data
        DEFINE DEBUG_REG PORTC  ' Debug Port = PortC
        DEFINE DEBUG_BIT 4      ' Debug.bit = PortC.4
        DEFINE DEBUG_BAUD 2400  ' Default baud rate = 2400
    Send
    DEBUG 9,3
    Receive
    DEBUGIN [WAIT("9"),DEC net]
    The same syntax works for HSERIN/OUT
  1. Direct PIC to PC without MAX232
    By acjacques in forum Serial
    Last Post: - 23rd October 2014, 21:32
  2. Serial VB 2005 pic 16f877a problems
    By Snap in forum mel PIC BASIC Pro
    Last Post: - 8th July 2013, 00:52
  3. PIC or xbee times out after Tx 504 bytes
    By archendekta in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2009, 08:45
  4. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 14:46
  5. RX TX modules - intermitent communication
    Last Post: - 11th June 2009, 00:13
