PIC to PIC TX RX and PIC to PC COM RX ..a little help please
Results 1 to 40 of 68
    Nov 2007
    South-West of Australia. A small town called Denmark. 'Where the forest meets the sea.'
    Default RS232 Comms
    Dennis,
    A few thoughts on linking PICs by RS232:
    1. I've done it - unfortunately, deleted the code after getting it working.
    2. I used SERIN2 and SEROUT2, by habit rather than for good technical reasons.
    3. HSEROUT/HSERIN do pass much of the processing down to the chip hardware and save lots of processing time and code space. However, if you are still in the 'getting something working stage' I'd use SEROUT/SERIN to avoid additional DEFINES and so on needed for HSEROUT/IN.
    4. I've had a short read through your code and not spotted any problems. I'd suggest that you temporarily abandon the keypad business and write a very basic routine to send/receive one byte variable PIC-Hyperterm and then PIC-PIC. Start using SEROUT/SERIN then move on to SEROUT2/SERIN2 and then HSEROUT/HSERIN.
    5. Have you got carriage returns (Decimal '13') at the end of each transmission?
    6. I've not looked up the data for your chips but what is TRISX?
    7. Just had a longer look at the code and I think your sequencing is wrong? Should be:
    a. PICA. Press key
    b. PICA. Send to the other PIC (I think you receive here?)
    c. PICB. Receive data
    d. PICB. Send data
    e. PICA. Receive data
    f. PICA. Display data on LCD
    g. PICA. Press key......
    Watch those CRs!
    8. I assume that each end of the PIC to PIC RS232 link is symetrical i.e both have RS232 chips for level conversion or both do not?
    Regards Bill legge
    Default thank you Bill
    Hi Bill
    Thanks a million for the informative response and advice :-)
    Here is my reply to your examination :
    1.Damn, just my luck ! Nice to hear you came right though :-0
    2.I wouldn't mind using either have those but found issues with serout2 and the data displayed in hyperterminal so used serout.
    What are your thoughts on using DEBUG ?
    3.I did notice in reading through other forum posts and the manual that DEFINES are required.
    4.I was thinking of doing exactly the same thing just to remove also possible room for error :-)
    5. No I do not have carriage returns at the end of each transmission are you referring to 10,13 at the end of serout ?
    I was under the notion that I could just SEROUT ping and port at 2400T and the variable name all in a loop.... is this where my problem is...apart from being a little rusty and having to re-live been a PIC newbie again ?
    6.TRISX is a very secret register which you enable my moving the shift in the time space continum on a PIC 18f4520 ....:-) lol just kidding.
    OK jokes aside TRISX is the comment I placed there so that I could remember how to manipulate TRIS for IO.
    7. Sequencing is correct ...just realised I have not added the connection diagram :-( will add it to this post now.
    I am sending from PIC 16f887 PIC 18F4520
    PORTC.6(TX)-----PORTC.7(RX)
    PORTC.7(RX)-----PORTC.6(TX)
    so it's PIC16F887 >>PIC18F4520 >>PC(hyperterminal)
    out in | out
    TX RX | TX
    LCD IS HERE (wired to 18F4520)
    Once again ...where are the CR's and where should they go exaclty ?
    8.The only place there is a MAX232N is on the TX side of the 18F4520 so that is can connect to PC serial port, in which case I am able to send and receive data to and from the PC :-)
    Hope this helps , will post more info just now to make it simpler to read ;-)
    Any more info would be much appreciated.
    Kind regards
    Dennis
    Just to add to the confusion...
    DEFINES are not required.
    Demo:
    X   VAR BYTE
    START:X = X + 1
    HIGH PORTD.2 :PAUSE 250:LOW PORTD.2:PAUSE 250
    RCSTA=$90:TXSTA=$24:SPBRG=129:HSEROUT ["HSER ",DEC X,13,10]
    PAUSE 250:RCSTA=$0:SEROUT2 PORTC.6,84,["SER ",DEC X,13,10]
    GOTO START
    Sometimes complete control is handy.
    Default smoke and mirrors ...?
    Hi Dave ...how are you ?
    Mmmm that sure got me :-)
    An here I am still trying to at least get some comms going :-( !
    I have the champagne ready ...now just to find the ship to smash it open on and the people to join my 'I can finally TX/RX' between PIC's celebrations...
    All I can say for now is... WATCH THIS SPACE ! LOL
    Kind regards
    Dennis
    Smoke and mirrors???
    Here is a simple example to build on
    SEND:
    SEROUT PORTC.4,T2400,[9,3]
    RECEIVE:
    SERIN PORTC.4,T2400,[9],net
    IF net = 3 THEN DO_SOMETHING
    Connect VSS and the two PIC pins together.
    Default ok....just another question ...
    Will try the operation with only your code...
    Can one run SERIN and SEROUT on same pic as I would like to send the received data to hyperterminal and also to the LCD. So would the fol.lowing code be correct then ?
    Oh and why did you choose PORTC.4 ? Looking at the pinouts for both pics I see PORTC.6 is TX and PORTC.7 is RX -are these for hardware serial , ie. HSERIN and HSEROUT and should I use them for SERIN and SEROUT or is it better to use PORTC.4 in case I want to use them for HSERIN/OUT later ?
    Here's the code
    Transmitter PIC (16F887)
    Receiver PIC (18F4520)
    SERIN PORTC.4,T2400,[9],net 'prepare to receive the data from other PIC
    IF net = 3 LCDOUT "data is",net 'look for the number 3
    SEROUT PORTC.5,T2400,[9,3] 'send received data to hyperterminal via max232n to PC
    end if
    Smoke and mirrors indeed :-)
    Kind regards
    Dennis
    I went with PORTC4 for no good reason other than to show that the bit banging routines work on most any pin. You are correct about HSERN only working on the hardware pins.
    What I can see of your code(using phone) it looks like it should work.
  1. Direct PIC to PC without MAX232
    By acjacques in forum Serial
    Last Post: - 23rd October 2014, 22:32
  2. Serial VB 2005 pic 16f877a problems
    By Snap in forum mel PIC BASIC Pro
    Last Post: - 8th July 2013, 01:52
  3. PIC or xbee times out after Tx 504 bytes
    By archendekta in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2009, 09:45
  4. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 15:46
  5. RX TX modules - intermitent communication
    Last Post: - 11th June 2009, 01:13
