1 Pin 7-Segment Display
Results 1 to 1 of 1
    Aug 2005
    Michigan, USA
    Default 1 Pin 7-Segment Display
    I came across an interesting 1-Pin 74HC595 Shfit Register Interface recently. It's basically a new twist on an old method but being able to drive one or more serial-to-parallel latch ICs or driver ICs with a single pin opens up some interesting possibilities.
    Please check out the method theory and details here; Roman Black's "Shift1 System for 1-wire Shift Registers"
    So how about a one pin 7-segment clock display? You can only light 47 of the 48 segments because we have to throw away the last bit stream bit but still interesting, yes, no?
    Regards, Mike
  1. Thermo 7 segments - little problem
    Last Post: - 27th July 2013, 08:31
  2. 7 Segment Displays and MAX7219
    By Bill Legge in forum mel PIC BASIC Pro
    Last Post: - 31st October 2010, 19:30
  3. 32 bit square root
    Last Post: - 6th May 2009, 04:37
  4. A little DTMF help
    By Travin77 in forum mel PIC BASIC Pro
    Last Post: - 30th May 2006, 02:31
  5. Keypad unlock (as in garage door possibly)
    By Fred in forum Code Examples
    Last Post: - 2nd April 2006, 05:26
