Hi all,
I have been using this little include on PIC16F876A's for ages without a flaw.
But, for some reason it wont work in an 877A.
Any tips or clues would be much appreciated.
cheers
Woodzy
'FILENAME : INT.BAS
'PROGRAM : INCLUE for continuous clock
'DATE : 01NOV2005
DEFINE INTHAND ROLLOVER
wsave var BYTE $020 SYSTEM
wsave1 var BYTE $0a0 SYSTEM
wsave2 var BYTE $120 SYSTEM
wsave3 var BYTE $1a0 SYSTEM
ssave var BYTE BANK0 SYSTEM
psave var BYTE BANK0 SYSTEM
i_hour var BYTE
i_minu var BYTE
i_sec var BYTE
i_tic var BYTE
GOTO AFTERINT 'Jump past interrupthandler
asm
ROLLOVER
; If you are using a PIC with 2K or less,
; you MUST unremarke the lines that follow.
; movwf wsave ;only for PICs with 2k or less
; swapf STATUS,w ;only for PICs with 2k or less
; clrf STATUS ;only for PICs with 2k or less
; movwf ssave ;only for PICs with 2k or less
; movf PCLATH,w ;only for PICs with 2k or less
; movwf psave ;only for PICs with 2k or less
; interrupcode follows here
movlw 0x58
movwf TMR1L
movlw 0x9e ;restart timer from ffff - 9e58 => 5Hz if using 4MHz
movwf TMR1H
decfsz _i_tic,f
goto slutint
incf _i_sec,f
movlw 5 ;5 = 1Hz if using 4MHz (change to 10 for 8MHz and so on)
movwf _i_tic
movf _i_sec,w
sublw 60
btfss STATUS,Z ;check for 60 sec
goto slutint ;no
clrf _i_sec ;yes
incf _i_minu,f
movf _i_minu,w
sublw 60
btfss STATUS,Z ;check for 60 minutes
goto slutint ;no
clrf _i_minu ;yes
incf _i_hour
movf _i_hour,w
sublw 24
btfss STATUS,Z ;check for 24 hours
goto slutint ;no
clrf _i_hour ;yes
slutint
bcf PIR1,0 ;zero tmr1 interrupt flag
;end of interruptcode
; restorecode follows here
movf psave,w ;restore
movwf PCLATH
swapf ssave,w
movwf STATUS
swapf wsave,f
swapf wsave,w
retfie
endasm
AFTERINT:
INTCON = %00000000 'all interrupts off
PIR1 = %00000000 'zero tmr1 interrupt flag
PIE1 = %00000001 'enable timer1 interrupt
TMR1L = $58
TMR1H = $9e
i_hour = 0
i_minu = 0
i_sec = 0
i_tic = 5 'this value should be the same as the value of line 8 in the ISR
T1CON = %00110001 'timer1 on, prescaler=1/8
INTCON = %11000000 'interrupt on
