A quick way...
Results 1 to 6 of 6
Thread: A quick way...
    Jul 2009
    Default A quick way...
    I am using the following code to detect when a pulse arrives at a pin:
    Wt:
    IF fin = 0 then Wt
    It works well, since the pulse is only a couple of micro seconds long and I am running at 4 MHz, but I also need the routine to timeout after about half a second. I tried using PulsIn, but it does not detect the pulse. I though may be using TMR0 and an interrupt coded in assembler could make this loop exit, but my expertise in assembler are very (extremely) limited.
    Do any of you have an idea?
    May 2008
    Italy
    Tray and see if this works:
    Wt:
    W0=0
    While fin = 0
    W0=W0+1
    pause 1
    If W0> 500 then goto TimeOut
    Wend
    Al.
    If it is a very short Pulse (a few uS), you might miss it's arrival during the 1mS Pause statement.
    If you can route your pulse into say RB0, then rather than polling the pin, you can poll the INTF bit (not knowing your PIC I'm using the registers from a 16F628 as an example). This bit will SET and stay SET when your pulse arrives. So if you blink and miss the pulse because you were doing something else, the Flag tells you it's happened.
    Don't worry, the software doesn't actually need to vector to any Interrupt routine, once set up (eg INTEDG=1, INTE=1, GIE=0) you can just poll the INTF flag (rather than the pin) as per Al's example.
    Don't forget, it's your job to reset the INTF flag ready for the next event.
    Jul 2009
    That sounds perfect, since the pulse could be a short as 2 uS. I am using a PIC12F509 and if you could please give me an example for this one I will really apreciate it...
    By the way, what I need is to toggle pin GPIO.2 from 1 to 0 when this pulse arives in GPIO.1 and this should be as fast as possible, since the actual 1 to 0 edge is used to measure distance.
    Then really neither of the above replies are suitable.
    This is because whilst you are away doing something, (for example the PAUSE instruction), you are not looking for the event in order to trigger your Output IMMEDIATELY. Even with my suggested modification, you won't miss the pulse, BUT you'll only do something about it some time later - and that time could be delayed by anything up to 1mS.
    You would need something like Darrel's INSTANT INTERRUPTS - but NOT to Poll the input pin, but to give you your Timeout. If setting your Output pin relative to the Input trigger is so critical, then I would even consider if a PIC is the suitable device - you could do it quicker with discrete logic.
    Question
    Hi, Aherra
    Which distance measurement do you want to do ???
    sound in air, in water, light ???
    2µs looks a VERY very very short - or long ( ! ) period for those ...
    PS : http://pagesperso-orange.fr/atexa_el...ason/radar.htm
  1. Quick n dirty HPWM out of phase
    Last Post: - 17th August 2014, 06:29
  2. Quick DS18B20 question
    By gti_uk in forum General
    Last Post: - 21st June 2009, 18:24
  3. Quick USB CRC5 question
    By Michael Wakileh in forum USB
    Last Post: - 12th June 2009, 05:23
  4. Two quick (and elementary) questions.
    By scorpion990 in forum mel PIC BASIC Pro
    Last Post: - 27th June 2008, 00:03
  5. Interrupt Quick Question
    By shawn in forum mel PIC BASIC Pro
    Last Post: - 25th January 2005, 06:51
