Problem runing my code
Results 1 to 34 of 34
    May 2009
    Thumbs up
    this is my code example it works great, i put pic to sleep sinding 1919 and i wake up pic when i send any number ,using serial communicator in mcode studio.
    'pic16f628a
    @ DEVICE WDT_ON, PWRT_OFF,MCLR_ON,CPD_OFF, BOD_OFF, PROTECT_OFF,INTRC_OSC_NOCLKOUT
          Include "modedefs.bas"
    PCON.3=1
    RCSTA=$90'DEFINE HSER_RCSTA 90H
    TXSTA = $20'DEFINE HSER_TXSTA 20h
    DEFINE HSER_BAUD 2400
    DEFINE HSER_SPBRG 25
    'DEFINE HSER_EVEN 1
    'DEFINE HSER_TIMEOUT 1 ' Clear overflow automatically
    define RX_INT    PIR1,RCIF       ;-- USART Receive Interrupt
    PORTA = %00000
    PORTB = %00000011
    TRISA = %00000
    TRISB = %00000011
    intcon = 0
    vrcon = 0
    CMCON = 7
    SDO  Var PortB.4
    SCLK Var PortB.5
    BTM  Var PortB.6
    BTN VAR PORTB.7
    SEG var byte
    Digit var byte[4]
    index var byte
    B0 var word
    D0 var byte
    j var  BYTE
    b0 = 0
    LOOP:
    if B0 = 1919 then SLP
    HSERIN 10,main,[DEC4 b0]
    MAIN:
    'im using here  dsr 7segment leds with 74hc164 , bcz not found lcds in my country no pic ic
    D0 = B0 DIG 0
    READ D0,DIGIT[0]
    D0 = B0 DIG 1
    READ D0,DIGIT[1]
    D0 = B0 DIG 2
    READ D0,DIGIT[2]
    D0 = B0 DIG 3
    READ D0,DIGIT[3]
    for index = 0 to 3
    seg = digit [index]
    SHIFTOUT SDO,SCLK,0,[SEG\8]
    PORTA.0[index] = 1
    PAUSEus 999
    PORTA=0
    NEXT INDEX
    goto loop
    SLP:
    CLEAR
    PORTB = %00000011 ,,, tried portb.0 with rx port ising led ot IR ld .
    OPTION_REG = %00000001
    INTCON.1 = 0
    INTCON.4 = 1
    @ SLEEP
    @ NOP
    B0 = 0000
    PAUSE 100
    HIGH PORTB.7 ' just to see pic is wake up
    PAUSE 1000
    LOW PORTB.7
    GOTO LOOP
    data @0,3,159,37,13,153,73,65,31,1,9 'here s  the numbers  from 0 to 9
    thanks a lots for helping
    HELLO
    May 2009
    HELLO EVERYONES AGAIN LOL, IM TRYING TO SEND DEC NUMBERS FROM PC TO PIC BUT I DONNO HOW TO WHY WHEN I SEND EX: 15 IT STORES $60 IN EEPROM OR DEC 20 IT STOR $08 . AND IT STUCKS I SEND 5 TIMES OR MORE THEN IT RECEIVE THEM 1 TIME ....????????
      INCLUDE "MODEDEFS.BAS"
    intcon = 0
    vrcon = 0
    CMCON = 7
    PORTB =%00000010
    TRISB = %00000010
    SO      con     2
    SI      con     1
    B0      var     byte
    mainloop:
     Serin2 SI,N2400,[B0]        ' GETTING DECIMAL  NUMBERS FROM PC
                                      'USING SERIAL COMMUNICATOR
            If B0  Then print
    GOTO MAINLOOP
    print:
    WRITE 5,B0      'SAVE NUMBERS IN EEPROM
    PAUSE 100
    Serout2 SO,N2400,[B0]
            Goto mainloop
    HELLO
    May 2008
    Italy
    Mus.me,
    Serin2 SI,N2400,[B0] is wrong. For 2400 bauds use : Serin2 SI,396,[B0]. The same apply for SEROUT2.
    Do you use hyperterminal for RS232 com with the pic?
    ...... I SEND 5 TIMES OR MORE THEN IT RECEIVE THEM 1 TIME ....????????
    You are writing "5 TIMES OR MORE" in the same location, so at the end you will see only the last byte Txed.
    Al.
    May 2009
    Quote Originally Posted by aratti View Post
    hello everyones again lol, im trying to send dec numbers from pc to pic but i donno how to why when i send ex: 15 it stores $60 in eeprom or dec 20 it stor $08 . And it stucks
    mus.me,
    serin2 si,n2400,[b0] is wrong. For 2400 bauds use : serin2 si,396,[b0]. The same apply for serout2.
    Do you use hyperterminal for rs232 com with the pic?
    write 5,b0 'save numbers in eeprom
    you are writing "5 times or more" in the same location, so at the end you will see only the last byte txed.
    Al.
    thank you aratti im using serial communicator in microcode studio . But still gettin wiered symboles when i send from pic to the pc . I want to send dec and ascii but i donno how
    HELLO
    May 2008
    Italy
    ...... But still gettin wiered symboles when i send from pic to the pc . I want to send dec and ascii but i donno how
    Mus.me, all the ascii from 0 to 31 will give you wierd symboles, and 32 will show nothing because is space. This is the reason why you use the notation DEC before the variable to Tx.
    If you want to receive both decimal and ascii you can Tx twice the variable
    Serout2 SO,390,[DEC B0, " ", B0,13,10]
    or you can select in which format to send out the variable depending on its value
    IF B0<33 Then
    Serout2 SO,390,[DEC B0,13,10]
    Serout2 SO,390,[B0,13,10]
    Al.
    May 2009
    mus.me, all the ascii from 0 to 31 will give you wierd symboles, and 32 will show nothing because is space. This is the reason why you use the notation dec before the variable to tx.
    If you want to receive both decimal and ascii you can tx twice the variable
    serout2 so,390,[dec b0, " ", b0,13,10]
    if b0<33 then
    serout2 so,390,[dec b0,13,10]
    serout2 so,390,[b0,13,10]
    al.
    thank you very much aratti for ur help .i tryed it whith baud 16780 it works good i send from pc to pc and from pic to pc its the same i get using serial communicator of microcode studio .i will try with transmeter and receiver bcz i tryed it using ir it does error .got a amall robot to test likw remote control than i carry on have agreat day ARATTI ...
    HELLO
    May 2009
    HI ARATTI,
    I DID THIS CODE IT WORKS GREAT THNK U FOR HELP
    SYNC CON "A"
    SO      con     1
    SI      con     0
    B0      var     WORD
    B0 = 0
    MAIN:
    Serin2 SI,16780,10,MAIN,[WAIT(SYNC), DEC4 B0]
    SerOUT2 SO,16780,["OK MUS ..!  ",DEC4 B0]
    GOTO MAIN
    NOW IM TRYING INFRARED BUT STILL NOT WORKIN I KNOW IR RUNS ON 40KHZ, AND IVE GOT TRANSMITTER AND RECEIVER I FOUND THEM IN PROBASIC STATION METEO WAS SENDING FROM OUTSIDE TO THE CLOCK IN MY ROOM I TOOK THEM OFF BUT AINT WORKIN .
    REGARDS
    HELLO
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
  2. 16F883 Code Verify Problem
    By munromh in forum mel PIC BASIC Pro
    Last Post: - 19th February 2009, 11:47
  3. Making Program Code Space your playground...
  4. problem with my code
    By civicgundam in forum mel PIC BASIC Pro
    Last Post: - 3rd February 2008, 01:52
  5. Code problem
    Last Post: - 20th May 2006, 04:43
