Problem runing my code
Results 1 to 34 of 34
    Wink
    BUT ...
    I think you could " re write " your project ... showing clearly what you want to do !!!
    refresing your full display @ 200 Hz is not compulsory . 50/60 Hz is a classical value ... that leaves some time in between to do little other tasks ... while a digit is lit ...
    You should Google around For the numerous ( ! ) alarm clock projects on the web ...
    Difficult to help you not knowing what you want to do ....
    May 2008
    Italy
    i think none understands my quetion.i want to run like this code ..
    i want both programes to run apart from each other its just example so i can write my programe like this plz help
    You can obtain the two leds flashing at a different interval with a couple of variable:
    Dled     Var Byte
    Dled1   var Word
    main:   '  led will blink @ 0,1 sec; led1 will be on for 2 secs off for 0,2 sesc
    Pause 1
    Dled = Dled + 1
    Dled1 = Dled1 + 1
    If Dled =>100 then
    Toggle led
    Dled = 0
    If Dled1 = 1 then high led1
    If Dled1 = 2000 low led1
    If Dled1 =>2200 then Dled1 = 0
    Al.
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  2. 16F883 Code Verify Problem
    By munromh in forum mel PIC BASIC Pro
    Last Post: - 19th February 2009, 12:47
  3. Making Program Code Space your playground...
  4. problem with my code
    By civicgundam in forum mel PIC BASIC Pro
    Last Post: - 3rd February 2008, 02:52
  5. Code problem
    Last Post: - 20th May 2006, 05:43
