Problem runing my code
Results 1 to 34 of 34
    May 2009
    Question
    i think none understands my quetion.i want to run like this code ..
    i want both programes to run apart from each other its just example so i can write my programe like this plz help
    main:   ' i wa]nt this led to blink  forever without any other delay or stops
    high led
    low led
    loop: ' and i want this led1 to blink without any other delay or stop
    high led1
    pause 2000
    low led1
    pause 200
    goto loop
    Thumbs down Processor unability ....
    With Pics ... You CAN'T do two things at the same time ( say totally independant things - excluding Peripheral use )
    a Pic does ONE THING AT A TIME ... " Multitasking " just is doing a little part of a task, then a little part of another task, then ...... a little part of the first task, then ....
    very quickly.
    thats ALL !!!
    For your LED Example ... you'd have to use a Pair of "555" as EXTERNAL peripherals, ( HPWM modules are too fast ) to drive your leds .
    May 2009
    very quickly.
    thats ALL !!!
    o right thank u Acetronics for reply.check ur pm . it just confused me this 7 sgment it need the routine in main label each 1 ms, so if i put anythings has delays or like serin it cuz the 7seg delay and blinking slow thats im thinkin to define it like lcd or something to kepp the shift out runing each 1 ms .and do my programe works and has delayes,,,,,,,,,
    Wink
    BUT ...
    I think you could " re write " your project ... showing clearly what you want to do !!!
    refresing your full display @ 200 Hz is not compulsory . 50/60 Hz is a classical value ... that leaves some time in between to do little other tasks ... while a digit is lit ...
    You should Google around For the numerous ( ! ) alarm clock projects on the web ...
    Difficult to help you not knowing what you want to do ....
    May 2008
    Italy
    You can obtain the two leds flashing at a different interval with a couple of variable:
    Dled     Var Byte
    Dled1   var Word
    main:   '  led will blink @ 0,1 sec; led1 will be on for 2 secs off for 0,2 sesc
    Pause 1
    Dled = Dled + 1
    Dled1 = Dled1 + 1
    If Dled =>100 then
    Toggle led
    Dled = 0
    If Dled1 = 1 then high led1
    If Dled1 = 2000 low led1
    If Dled1 =>2200 then Dled1 = 0
    Al.
    Quote Originally Posted by Mus.me View Post
    high led
    low led
    high led1
    pause 2000
    low led1
    pause 200
    goto loop
    You might try this:
    For ledvar = 0 to 100
    low led
    high led
    next ledvar
    low led1
    low led
    high led
    High LED1
    goto Main
    May 2009
    Angry i solved that code joe thank u for help
    the big problem i have now is to wake up pic 16f628 from sleep using usart interrupt hserin i tested PIR1 it occur but in sleep mode it doesnt occur . i donno i think im runing usart on synchronous slave mode thats what says the datasheet but i donno wheres my problem .my project is to transmet data to pic then wake it up . here is my code .
     @ DEVICE WDT_ON, PWRT_OFF,MCLR_ON,CPD_OFF, BOD_OFF, PROTECT_OFF,INTRC_OSC_NOCLKOUT
          Include "modedefs.bas"
    RCSTA=$90'DEFINE HSER_RCSTA 90H
    TXSTA = $20'DEFINE HSER_TXSTA 20h
    DEFINE HSER_BAUD 2400
    DEFINE HSER_SPBRG 25
    'DEFINE HSER_EVEN 1
    'DEFINE HSER_CLROERR 1 ' Clear overflow automatically
    'DEFINE HSER_TIMEOUT 1 ' Clear overflow automatically
    PORTA = %00000
    PORTB = %00000010
    TRISA = %00000
    TRISB = %00000010
    intcon = 0
    vrcon = 0
    CMCON = 7
    j var  BYTE
    led var portb.7
    LOOP:
    j = j + 1
    if j = 255 then SLP
    high led2
    HSERIN 10,main,[DEC4 b0]
    goto loop
    ' here will be  my programe
    SLP:
    low led
    RCSTA.4=0
    INTCON.6 = 1
    RCSTA.4 = 1
    PIE1.5 = 1
    PIR1.5 = 0
    @ SLEEP
    @ NOP
    PAUSE 1000
    HIGH PORTB.6
    PAUSE 1000
    LOW PORTB.6
    GOTO LOOP
    please help i had read all the usart datasheet and i did what it says but nothings i think the problem in sync slave mode or the osc goes off during sleep or usart not reciving data even i did set it to recive data and interrupt..
    and acetronics says (Alain
    ... and now, just use " Wake up on interrupt " ... as you have the interrupt flag !!! i donno where to put on interupt i trayed it many ways but nothings when it goes to sleep it die just like my nan bless her ..
    HELLO
    May 2008
    Italy
    Mus.me, the time you are using to go to sleep it seems to to be too short. You have 2.5 secs available than your micro enter into the sleep process. I would use a word (J VAR WORD) and set at least 20 seconds, otherwise you cannot even read the display.
    LOOP:
    j = j + 1
    if j = 255 then SLP '2.5 secs is a too short time use a word
    high led2
    goto loop
    Remove the two long pause in your code (after sleep command) otherwise when micro wakes has to process the two pauses and will loose the Tx data, and will return to sleep.
    @ SLEEP
    @ NOP
    PAUSE 1000
    HIGH PORTB.6
    PAUSE 1000
    LOW PORTB.6
    GOTO LOOP
    Al.
    May 2009
    thank u aratti for reply i think the problem is in usart when pic goes in sleep mode the something aint working to receive data from PC TX , i tryed everythings 3days now but nothings .here where i have the problem, why it doesnt wake up the chip ?? lol
    SLP:
    OPTION_REG.7 = 0
    RCSTA.4=0
    INTCON.6 = 1
    RCSTA.4 = 1
    PIE1.5 = 1
    PIR1.5 = 0
    @ SLEEP
    @ NOP
    GOTO LOOP
    sorry for asking to much but i really wants to learn pbp very good im reading the whole datasheet every nights it helps and i get to much help and ideas from this forum thank u everyone
    HELLO
    Dec 2007
    Finland
    Post
    Hi Mus.me,
    I think you should turn on global interrupt enable (GIE) bit.
    INTCON.7 = 1
    Isn't that the master switch for all interrupts?
    BR,
    -Gusse-
    May 2009
    Question
    Quote Originally Posted by Gusse View Post
    Hi Mus.me,
    INTCON.7 = 1
    BR,
    -Gusse-
    hello Gusse thank u for help , i did that not working, i think i have problem in slave senchronous or somethings goes off when sleep mode .im sending 4 numbers from the pc and it works great .but in sleep mode it doesntwake it up
    HELLO
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  2. 16F883 Code Verify Problem
    By munromh in forum mel PIC BASIC Pro
    Last Post: - 19th February 2009, 12:47
  3. Making Program Code Space your playground...
  4. problem with my code
    By civicgundam in forum mel PIC BASIC Pro
    Last Post: - 3rd February 2008, 02:52
  5. Code problem
    Last Post: - 20th May 2006, 05:43
