Problem runing my code
Results 1 to 34 of 34
Threaded View
  1. #3
    May 2009
    SORRY ITS JUST 7 SEGMENTS NOT LCD..this is the 7segment schema i did draw sorry i havnt draw it good but im sure thats enought to undersnd its normal 7seg working through 74hc164 shift register and 4 digit pins to the pic .atached them all to portb . it works fine with a counter like b0 = b0 +1 to 9999. but i cant add any pause or delay i need to findout how to run my program apart of the 7 segment routing or loop. <<<< ITS LIKE I HAVE A LED BLINK IN A LOOP AND I WANT TO WRITE MY CODE APART AND LET THE LED BLINKIN WITHOUT STOPING EVEN OTHER PROGRAME IS WORKIN AND HAS ITS DELAYS OR NO OR SOME ITS LIKE I WANT TO RUN 2 THINGS IN 1 TIME 2 LOOPS I DONNO IF TIMRERS WILL HELP OR WAT TO WITH THIS BLLODY THINGS LOL >>>>THIS 7SED GODE WORKS OK THE TOP 1 I POSTED BEFOR ISNT WORKING ANYWAY THANK U FOR HELP
    @ DEVICE WDT_ON, PWRT_ON,MCLR_ON,CPD_OFF, BOD_OFF, PROTECT_OFF,INTRC_OSC_NOCLKOUT
          Include "modedefs.bas"
    intcon = 0
    vrcon = 0
    CMCON = 7
    SDO  Var PortB.4
    SCLK Var PortB.5
    BTM  Var PortB.6
    BTN VAR PORTB.7
    SEG var byte
    Digit var byte[4]
    index var byte
    B0 var word
    D0 var byte
    PORTA = %00000
    PORTB = %11000000
    TRISA = %00000
    TRISB = %11000000
    B0 = 0
    loop:
    MAIN:
    ''''''''HERE IN THIS LOOP I CANT WRITE PROGRAME WHICH HAS DELAYS.
    '''''' ALL WAT I WANT IS TO LEAV THIS RUNING ITS ROUTING EACH PAUSEUSS999
    ''''''' I WANT TO PUT MY PROGRAME OUT OF THIS LOOP AND SEND WAT I WANT TO SEE ON THE 7SEGMENT TO  B0 VAR
    if btN = 0 then b0 = b0 - 1
    if btm = 0 then  b0 = b0 +1
    D0 = B0 DIG 0
    READ D0,DIGIT[0]
    D0 = B0 DIG 1
    READ D0,DIGIT[1]
    D0 = B0 DIG 2
    READ D0,DIGIT[2]
    D0 = B0 DIG 3
    READ D0,DIGIT[3]
    for index = 0 to 3
    seg = digit [index]
    SHIFTOUT SDO,SCLK,0,[SEG\8]
    PORTB.0[index] = 1
    PAUSEUS 999
    PORTB=0
    NEXT INDEX
    GOTO MAIN
    data @0,3,159,37,13,153,73,65,31,1,9
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  2. 16F883 Code Verify Problem
    By munromh in forum mel PIC BASIC Pro
    Last Post: - 19th February 2009, 12:47
  3. Making Program Code Space your playground...
  4. problem with my code
    By civicgundam in forum mel PIC BASIC Pro
    Last Post: - 3rd February 2008, 02:52
  5. Code problem
    Last Post: - 20th May 2006, 05:43
