Internal Oscillator and pull-up statements for 16f887
Results 1 to 13 of 13
    Default Is this better?
    Hi Gusse
    Is this looking better ?
    Not sure of the Comparator setting ??
    @__config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_ON & _LVP_OFF & _CP_OFF
    'Ocsillator selections here
      'OSCCON = %01100001 for 4mhz, or OSCCON = %01110001for 8mhz
            OSCCON = %01110001           'Int CLK 8MHz
            ANSEL= %11111111       '$0F = disable A/D converter
            cm1con   =   1
            option_reg = 7     'switch pull-ups ON
    'END of oscillator selections
      'timer/oscillator defines
            define osc 8        '8MHz
    'END of timer/oscillator defines
    Dec 2007
    Finland
    Post
    Hi Dennis,
    I would try with following settings.
    <code><font color="#008000">@__config _INTRC_OSC_NOCLKOUT &amp; _WDT_OFF &amp; _MCLRE_ON &amp; _LVP_OFF &amp; _CP_OFF
    </font>OSCCON = %01110001          <font color="#000080"><i>'Int CLK 8MHz
    </i></font>ANSEL = %00000000           <font color="#000080"><i>'All digital
    </i></font>OPTION_REG.7 = 0            <font color="#000080"><i>'Weak pull-ups enabled
    </i></font><b>DEFINE </b>OSC 8                <font color="#000080"><i>'8MHz</i></font></code>
    Comparators are disabled at POR, no need to disable twice.
    BR,
    -Gusse-
    Default compile errors in MCS
    HI Gusse
    MCS won't allow a compile ....
    It seems to have a problem with this line
    In particular with the first path or the line it seems ...
    Here's the error
    Warning [205]...Found directive in column 1.(__config)
    Error [126] c:......argument out of range (not a valid config register)
    Should I rather set those in the include file ?
    And what about the comparator ? Haven't quite master the way to disable it , the manual mentions CMxCON...
    Kind regards
    Dennis
    Default Fixed!
    Check the include file 16f887.inc
    and it has this line in any way ...
    So I left the line out of the code since there's no need to replicate the config lines.... or am I wrong ?
    Now what about the option to disable the onboard comparators ?
    Kind regards
    Dennis
    Dec 2007
    Finland
    Post
    I have never included fuses to PicBasic code, always modified INC-files.
    Delete line from code and check that you have following line in 16F887.INC
    __config _CONFIG1, _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_ON & _LVP_OFF & _CP_OFF
    Comparators are off after Power On Reset (POR), so if you haven't enabled those, then they are disabled.
    BR,
    -Gusse-
    Default Thanks Gusse
    Thank you for the guidance and help !!
    I have all set in the include file now! :-)
    All is working just fine :-)
    Kind regards
    Dennis
    Dec 2007
    Finland
    Nice to follow your project
    Good Luck!
    BR,
    -Gusse-
    Quote Originally Posted by Gusse View Post
    BR,
    -Gusse-
    I never Fail to include them. To include the configs in your code, open the .inc file and install a semicolon just before the default config so,
    becomes
    ;__config _CONFIG1, _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_ON & _LVP_OFF & _CP_OFF
    save it and start including them in your code without error. This way you can quickly adjust them, if you want to change something.
    Default Thank you
    Hi Joe
    Thanks a million for the reply and advice :-) ,much appreciated !
    Kind regards
    Dennis
