SEROUT,HSEROUT or DEBUG ? max 232 or no max232 ?
Results 1 to 28 of 28
    Default I noticed...
    OK got your message after I tried with the DEC modifier ;-) nothing worked !
    So I removed it and .....
    The LCD now shows the correct characters as per what I type in 123 etc and the ABCD keys as well as # and * ....YAY.....
    but sadly now nothing appears in hyperterminal ....
    Does SEROUT now need to be replaced by SEROUT2 ?
    Will try it later and post results either way :-)
    Need some sleep now ..
    Thanks so much for your continued help :-) much appreciated !
    Keep well
    Kind regards
    Dennis
    OH .. by the way .. do you maybe know how I could capture a keyin of the number say 135 # so that it is actually stored as binary or decimal 135 ?
    Quote Originally Posted by Dennis View Post
    If you have PBP 2.60 then that will help. SEROUT has a buad rate problem.
    If you have 2.60, it's real easy with ARRAYREAD.
    Default Solved!!
    Hi Darrel
    Problem seems to be solved now.
    And the solution was in the very problem itself ...passing the variable !!
    I created a new variable called datatx
    and then after the displaying myvar to LCD with LCDOUT,
    all I did was let datatrx = myvar
    then SEROUT myvar
    And whammo it works :-) YAY ...!
    Thanks so much for all your help !
    Here's the code for reference and for anyone who might find it useful
    It captures a keypress, diplays it on the LCD and send the captured keypress via SEROUT.
    Kind regards
    Dennis
    'Keypress display on LCD and TX to wherever
    'Ocsillator selections here
            OSCCON = $70            'Int CLK 8MHz
            OSCTUNE.6 = 1           'PLL 4x
            ADCON1= %00001111       '$0F = disable A/D converter
            cmcon   =   7
            INTCON2.7 = 0     'switch pull-ups ON
    'END of oscillator selections
      'timer/oscillator defines
            DEFINE OSC 32            '4x 8MHz
    'END of timer/oscillator defines
    'Port IO directions and presets for port pins begin here
    'TRISX = %76543210   << tris bit order numbering
    'TRISA = %11111111       'All pins are outputs
    '// Define port pins as inputs and outputs ...
            TRISA  = %00000000 'example only - TRISB = %00001111 ;Make B4-B7 outputs, B0-B3 inputs,
            TRISB = %11111111  'for 4x4 keypad all input
            TRISC = %10000000
            TRISD = %00000000
            TRISE.0 = 0
            TRISE.1 = 0
            TRISE.2 = 0
    'End of Port IO directions and presets for port pins begin here
    'variables begin here
            myvar var byte
            datatx var byte
            datarx var byte
    'end of variables
    'LCD defines begin here
            DEFINE LCD_BITS 4 	'defines the number of data interface lines (4 or 8)
            DEFINE LCD_DREG PORTD 	'defines the port where data lines are connected to
            DEFINE LCD_DBIT 4 	'defines the position of data lines for 4-bit interface (0 or 4)
            DEFINE LCD_RSREG PORTD 	'defines the port where RS line is connected to
            DEFINE LCD_RSBIT 2 	'defines the pin where RS line is connected to
            DEFINE LCD_EREG PORTD 	'defines the port where E line is connected to
            DEFINE LCD_EBIT 3 	'defines the pin where E line is connected
            'DEFINE LCD_RWREG 0 	'defines the port where R/W line is connected to (set to 0 if not used)
            'DEFINE LCD_RWBIT 0 	'defines the pin where R/W line is connected to (set to 0 if not used)
            DEFINE LCD_COMMANDUS 2000 	'defines the delay after LCDOUT statement
            DEFINE LCD_DATAUS 200 		'delay in micro seconds
    'END of LCD DEFINES
    'includes begin here
            INCLUDE "modedefs.bas"
            include "c:\pbp\samples\keypad.bas"
    'end of includes
    'Keypad code begins here
            DEFINE KEYPAD_ROW        4        ' 4 ROW keypad
            DEFINE KEYPAD_ROW_PORT   PORTB    ' ROW port = PORTB
            DEFINE KEYPAD_ROW_BIT    0        ' ROW0 = PORTB.4
            DEFINE KEYPAD_COL        4        ' 4 COL keypad
            DEFINE KEYPAD_COL_PORT   PORTB    ' COL port = PORTB
            DEFINE KEYPAD_COL_BIT    4        ' COL0 = PORTB.0
            DEFINE KEYPAD_DEBOUNCEMS 200      ' debounce delay = 200 mSec
            DEFINE KEYPAD_AUTOREPEAT 1        ' use auto-repeat feature
    'end keypad code
    'Main code begins here
            Pause 2000       ' Wait for LCD to startup
    start:
            'read keypress variable
            @ READKEYPAD _myvar
            LOOKUP  myvar,[0,"123A456B789C*0#D"],myvar
            'lcdout $fe, 1        'clear lcd screen
               'pause 2000
            lcdout myvar      'display keypress variable myvar
                  datatx = myvar '<<<<here's the solution :-)
                 lcdout datatx
       'transmit section
    'THE PROBLEM LINE >>>        SerOut PORTC.6,T2400,["the key pressed is ",datatx]
            SerOut PORTC.6,T2400,["the key pressed is ",datatx] 'SerOut PinNumber2,T2400,DataRec (FIXED!!
       'transmit section ends
        'receive section
             'SerIn PORTC.7,T2400,DataRX
             'LCDOUT datarx          'displays data received from serin datarx
        'receive section ends
            lcdout $fe,1          'clear lcd screen
    goto start
    'End of all code
    then SEROUT myvar
    Well, I'm glad it's working, but I don't think that's what fixed it.
    All that did was copy a byte var to another byte var then displays the copied var. It's no different than displaying the original var in the first place.
    And since it works, I assume that means you don't have PBP 2.60, so I won't need to show an ARRAYREAD example.
    Default Would love an ARRAY read example :)
    Hi again Darrel
    Would love to see an ARRAY read example if you have the time ..if not just point me to a place to read about or reference it :-)
    Kind regards
    Dennis
    Oct 2009
    Utah, USA
    Default ARRAYREAD example
    Not sure what sort of ARRAYREAD example you are looking for... but here is one example.
    I am simply reading in a NMEA string from a gps unit and then parsing the NMEA sentence using ARRAYREAD.
    The underscore at the end of each line of the arrayread statement allows you to wrap the text so you do not have such a LONG sentence, yet it is still all one PBP statement.
    serin2 gps,188,3000,tmout,[WAIT("$GPRMC,"),STR GPRMC\63\"$"]
    arrayread gprmc,[DEC2 hh,DEC2 mm,dec2 ss,_
      wait(","),fix,wait(","),DEC2 latdeg,DEC2 latmin,wait("."),dec4 latminn,_
      wait(","),NS,wait(","),DEC3 londeg,DEC2 lonmin,wait("."),dec4 lonminn,_
      wait(","),EW,wait(","),dec knots,dec Knotss,dec course,_
      wait(","),DEC2 dy,DEC2 mt,DEC2 yr]
    Dwight
  1. N-Bit_MATH
    Last Post: - 16th December 2010, 14:48
  2. Wireless using debug.
    By polymer52 in forum mel PIC BASIC Pro
    Last Post: - 18th January 2010, 14:53
  3. About USB
    By dias11 in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2009, 20:41
  4. debug not working with MPASM assempler
    By santamaria in forum mel PIC BASIC Pro
    Last Post: - 4th March 2009, 07:51
  5. Data EEPROM gets clobbered during programming
    Last Post: - 18th July 2008, 02:46
