SEROUT,HSEROUT or DEBUG ? max 232 or no max232 ?
Results 1 to 28 of 28
    Dec 2007
    Finland
    Post
    Dennis,
    Have you read this?
    Communications Example : PC to PIC bi-directional dialogue
    Thanks to Melanie! This helped me a lot when I did code, which communicated with PC.
    BR,
    -Gusse-
    Edit 1: I have used baud rate up to 38400 very successful. It might work even higher data rate (haven't try so far).
    Edit 2: Running on 16F876A with 10MHz crystal, haven't tested with PIC that has internal oscillator. 1k5 resistors between PC and PIC (TX & RX).
    Default Thanks Gusse
    Will definitely check it out and do the suggested tests :-)
    Thank you
    Default Thanks Dave
    Have tried N2400 ... no luck :-(
    Correct me if I'm wrong but surely is well if the string arrives correctly ?
    DEFINE LCD_RWREG 0 'defines the port where R/W line is connected to (set to 0 if not used)
    DEFINE LCD_RWBIT 0 'defines the pin where R/W line is connected to (set to 0 if not used)
    I don't think it's a good idea to set those to 0.
    It will end up overwriting bit0 at address 0 in RAM which is normally PBP's R0 system variable.
    Try it without those lines.
    hth,
    Default Darrel ....YOU are the man !
    Darrel ....
    10 points on spotting this issue ... dude can I borrow those 'fine-tooth comb code-eyes' ???
    So I removed the lines...
    and here are the results .....
    1. LCD response is a million times faster.
    2. Keypresses happen almost instantly now
    3. The LCD was not responding to
    lcdout $fe,1          'clear lcd screen
    Now it responds like it should ...each keypress displays correctly, no funny wingdings like characters :-)
    and ... the LCD display clears after every keypress :-)
    YAY
    The LCD and keypress system is working like it should WOOOHOOOOO !!
    Thanks a million
    Kind regards
    Dennis
    PS... I still want to know how you noticed that ?? Past experiences ?
    Now all that remains is solving my SEROUT variable passing issue so I can see proper characters in hyperterminal :-)
    I keep getting a little square in hyperterminal as the keypress occurs but on the LCD it appears correct :-(
    the key pressed isthe key pressed isthe key pressed is
    Quote Originally Posted by Dennis View Post
    Now all that remains is solving my serout variable passing issue so I can see proper characters in hyperterminal :-)
    now I am confused....
    Default smoke and mirrors?
    At least I'm not alone then :-)
    I'm sure it has to do with passing the variable 'cos a 'string like this' appears just fine !
    And if I LCDOUT myvar that works fine on the LCD
    What doesn't work fine is when I SEROUT the variable myvar and try read it in hyperterminal
    WEIRD or what ?
    In fact with SEROUT using N2400 the output is worse and even the string of text is wingings :-)
    See next post here for the output screenshot... this tells me that T2400 is correct !
    Default Here's a screen cap of the hyperterminal output
    See the Received window
    WOOHOO!
    Well, I do have 4 eyes, so I guess you can have a couple of them.
    Need a new pair of specs anyhow.
    For the SEROUT prob...
    Steve's keypad routine returns a result that represents the number of the key. For a 4x4 pad it's 1-16.
    With a LOOKUP statement you can change them to match your keypad ...
    LOOKUP  myvar,[0,"123A456B789C*0#D"],myvar
    hthm,
    Default :-)
    Darrel
    ?Is Steve mister e ??
    Code-wise I tried , Bruce's code and Trent Jackson's code ....
    Mister e's is what I'm using at the moment, it was the one that worked for me, but the other would probably work now that the LCD problem is cleared up ;-) ...
    Where is the keypad code you are referring to ? I am willing to give it a bash :-)
    Kind regards
    Dennis
    Oh and I sure did get my fair share of moving wires and resistors around to get the correct column and row assingments ;-)
    Roll on virtual ports hey ?
  1. N-Bit_MATH
    Last Post: - 16th December 2010, 15:48
  2. Wireless using debug.
    By polymer52 in forum mel PIC BASIC Pro
    Last Post: - 18th January 2010, 15:53
  3. About USB
    By dias11 in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2009, 21:41
  4. debug not working with MPASM assempler
    By santamaria in forum mel PIC BASIC Pro
    Last Post: - 4th March 2009, 08:51
  5. Data EEPROM gets clobbered during programming
    Last Post: - 18th July 2008, 03:46
