SEROUT,HSEROUT or DEBUG ? max 232 or no max232 ?
Results 1 to 28 of 28
    Default SEROUT,HSEROUT or DEBUG ? max 232 or no max232 ?
    I currently have my PC's serial port ready to send and receive to the PIC 18F4520....
    I have a max232n connected and have connected the pic to the correct pins on the max232n.
    I would like to receive the data in hyperterminal.
    BUT would also like to experiment with HSEROUT and DEBUG etc
    SO here are the questions.
    Of the following choices SEROUT,HSEROUT or DEBUG which one do I choose
    1.To communicate between two pics
    2.From PC to PIC which one should I choose in the following instances
    A.Without a max232n
    B.With a max232n
    3.From PIC to RF
    4.From PIC to IR
    For all the above when may I use the internal oscillator and when not ?
    And lastly ....
    Assuming the Port I would like to transmit/send the data out of is PORT C6
    and the receiving port is PORT C 7,
    would the line be something like
    Loop:
    SerOut PinNumber,T2400,DataOut
    Pause 100 'Delay for Receive viewing
    goto Loop
    Quote Originally Posted by Dennis View Post
    SEROUT,SEROUT2,HSEROUT
    A.Without a max232n
    B.With a max232n
    A.Without a max232n
    SEROUT,SEROUT2,DEBUG
    B.With a max232n
    ANY
    3.From PIC to RF
    4.From PIC to IR
    ANY
    Bauds 4800 and below most times
    And lastly ....
    Loop:
    goto Loop
    Looks OK
    Default It's working :-)
    Thanks a million DAVE
    Now trying out SEROUT and it's working like a charm :-)
    You answers have cleared up the confusion !
    Once again THANK YOU
    Keep well
    kind regards
    Dennis
    Default Passsing the variable :-(
    So far I have tested ..SEROUT,SEROUT2 and DEBUG
    I just have an issue with somehow passing a variable around in my code it seems using SEROUT,SEROUT2 and DEBUG.
    So far I can capture a keypress (thanks to mister e's matrix keypad routine and advice and tips from several others - thank you!)
    The keypress from the keypad is stored in a variable called myvar.
    I send myvar to the LCD using
    lcdout dec myvar      'display keypress variable
    and on the LCD the DECimal number lets say I press 1 on the keypad appears as ||1 and for the number 2 on keypad it appears as ||2 and so on.
    If I change the code to convert myvar as BINary numbers like this
    lcdout BIN myvar      'display keypress variable
    then when I press the number 1 on the keypad I get ||1 on the LCD and then the keypad 2 shows as ||2 and so on.
    NOW .....
    If I use serout to send myvar to hyperterminal or MicroStudio serial port window like this
    SerOut PORTC.6,T2400,["the key pressed is",myvar]
    I just get "the key is pressed' followed by a windings kinda characters like smileys, blocks and so forth :-(
    If I send a string with serout like this
    SerOut PORTC.6,T2400,["the key pressed is"]
    Then everytime I press a key I see "the key is pressed" appearing in hyperterminal.
    Here is my code ....I would really appreciated if someone could point me towards finding a solution as ultimately I would like to TX the binary keypress to be RX for another PIC
    'Keypress display on LCD and TX to wherever
    'Ocsillator selections here
            OSCCON = $70            'Int CLK 8MHz
            OSCTUNE.6 = 1           'PLL 4x
            ADCON1= %00001111       '$0F = disable A/D converter
            cmcon   =   7
            INTCON2.7 = 0     'switch pull-ups ON
    'END of oscillator selections
      'timer/oscillator defines
            DEFINE OSC 32            '4x 8MHz
    'END of timer/oscillator defines
    'Port IO directions and presets for port pins begin here
    'TRISX = %76543210   << tris bit order numbering
    'TRISA = %11111111       'All pins are outputs
    '// Define port pins as inputs and outputs ...
            TRISA  = %00000000 'example only - TRISB = %00001111 ;Make B4-B7 outputs, B0-B3 inputs,
            TRISB = %11111111  'for 4x4 keypad all input
            TRISC = %10000000
            TRISD = %00000000
            TRISE.0 = 0
            TRISE.1 = 0
            TRISE.2 = 0
    'End of Port IO directions and presets for port pins begin here
    'variables begin here
            myvar var byte
            dataout var byte
    'end of variables
    'LCD defines begin here
            DEFINE LCD_BITS 4 	'defines the number of data interface lines (4 or 8)
            DEFINE LCD_DREG PORTD 	'defines the port where data lines are connected to
            DEFINE LCD_DBIT 4 	'defines the position of data lines for 4-bit interface (0 or 4)
            DEFINE LCD_RSREG PORTD 	'defines the port where RS line is connected to
            DEFINE LCD_RSBIT 2 	'defines the pin where RS line is connected to
            DEFINE LCD_EREG PORTD 	'defines the port where E line is connected to
            DEFINE LCD_EBIT 3 	'defines the pin where E line is connected
            DEFINE LCD_RWREG 0 	'defines the port where R/W line is connected to (set to 0 if not used)
            DEFINE LCD_RWBIT 0 	'defines the pin where R/W line is connected to (set to 0 if not used)
            DEFINE LCD_COMMANDUS 2000 	'defines the delay after LCDOUT statement
            DEFINE LCD_DATAUS 200 		'delay in micro seconds
    'END of LCD DEFINES
    'includes begin here
            INCLUDE "modedefs.bas"
            include "c:\pbp\samples\keypad.bas"
    'end of includes
    'Keypad code begins here
            DEFINE KEYPAD_ROW        4        ' 4 ROW keypad
            DEFINE KEYPAD_ROW_PORT   PORTB    ' ROW port = PORTB
            DEFINE KEYPAD_ROW_BIT    0        ' ROW0 = PORTB.4
            DEFINE KEYPAD_COL        4        ' 4 COL keypad
            DEFINE KEYPAD_COL_PORT   PORTB    ' COL port = PORTB
            DEFINE KEYPAD_COL_BIT    4        ' COL0 = PORTB.0
            DEFINE KEYPAD_DEBOUNCEMS 200      ' debounce delay = 200 mSec
            DEFINE KEYPAD_AUTOREPEAT 1        ' use auto-repeat feature
    'end keypad code
    'Main code begins here
            Pause 2000       ' Wait for LCD to startup
    start:
            'read keypress variable
            @ READKEYPAD _myvar
            lcdout $fe, 1        'clear lcd screen
            SerOut PORTC.6,T2400,["the key pressed is",myvar] 'SerOut PinNumber2,T2400,DataRec
            lcdout $fe,1          'clear lcd screen
    goto start
    'End of all code
    Thank you
    Kind regards
    Dennis
    Try
    N2400
    Dec 2007
    Finland
    Post
    Dennis,
    Have you read this?
    Communications Example : PC to PIC bi-directional dialogue
    Thanks to Melanie! This helped me a lot when I did code, which communicated with PC.
    BR,
    -Gusse-
    Edit 1: I have used baud rate up to 38400 very successful. It might work even higher data rate (haven't try so far).
    Edit 2: Running on 16F876A with 10MHz crystal, haven't tested with PIC that has internal oscillator. 1k5 resistors between PC and PIC (TX & RX).
    Default Thanks Gusse
    Will definitely check it out and do the suggested tests :-)
    Thank you
    Default Thanks Dave
    Have tried N2400 ... no luck :-(
    Correct me if I'm wrong but surely is well if the string arrives correctly ?
    I don't think it's a good idea to set those to 0.
    It will end up overwriting bit0 at address 0 in RAM which is normally PBP's R0 system variable.
    Try it without those lines.
    hth,
    Default Darrel ....YOU are the man !
    Darrel ....
    10 points on spotting this issue ... dude can I borrow those 'fine-tooth comb code-eyes' ???
    So I removed the lines...
    and here are the results .....
    1. LCD response is a million times faster.
    2. Keypresses happen almost instantly now
    3. The LCD was not responding to
    Now it responds like it should ...each keypress displays correctly, no funny wingdings like characters :-)
    and ... the LCD display clears after every keypress :-)
    YAY
    The LCD and keypress system is working like it should WOOOHOOOOO !!
    Thanks a million
    Kind regards
    Dennis
    PS... I still want to know how you noticed that ?? Past experiences ?
    Now all that remains is solving my SEROUT variable passing issue so I can see proper characters in hyperterminal :-)
    I keep getting a little square in hyperterminal as the keypress occurs but on the LCD it appears correct :-(
    the key pressed isthe key pressed isthe key pressed is
    Now all that remains is solving my serout variable passing issue so I can see proper characters in hyperterminal :-)
    now I am confused....
    Default smoke and mirrors?
    At least I'm not alone then :-)
    I'm sure it has to do with passing the variable 'cos a 'string like this' appears just fine !
    And if I LCDOUT myvar that works fine on the LCD
    What doesn't work fine is when I SEROUT the variable myvar and try read it in hyperterminal
    WEIRD or what ?
    In fact with SEROUT using N2400 the output is worse and even the string of text is wingings :-)
    See next post here for the output screenshot... this tells me that T2400 is correct !
    Default Here's a screen cap of the hyperterminal output
    See the Received window
    WOOHOO!
    Well, I do have 4 eyes, so I guess you can have a couple of them.
    Need a new pair of specs anyhow.
    For the SEROUT prob...
    Steve's keypad routine returns a result that represents the number of the key. For a 4x4 pad it's 1-16.
    With a LOOKUP statement you can change them to match your keypad ...
    LOOKUP  myvar,[0,"123A456B789C*0#D"],myvar
    hthm,
    Default :-)
    Darrel
    ?Is Steve mister e ??
    Code-wise I tried , Bruce's code and Trent Jackson's code ....
    Mister e's is what I'm using at the moment, it was the one that worked for me, but the other would probably work now that the LCD problem is cleared up ;-) ...
    Where is the keypad code you are referring to ? I am willing to give it a bash :-)
    Kind regards
    Dennis
    Oh and I sure did get my fair share of moving wires and resistors around to get the correct column and row assingments ;-)
    Roll on virtual ports hey ?
    Yup, Steve is mister-e.
    By changing from key numbers to ASCII with the Lookup, your serout should work better.
    Default Thanks again ...
    Darrel :-)
    So with 8 sets of eyes in total now ... should I add the LOOKUP prior to making the assembly key lookup like this ?
    start:
            @ READKEYPAD _myvar
            'lcdout $fe, 1        'clear lcd screen
               'pause 2000
            lcdout dec myvar      'display keypress variable myvar
       'transmit section
       'transmit section ends
        'receive section
             'SerIn PORTC.7,T2400,DataRX
             'LCDOUT datarx          'displays data received from serin datarx
        'receive section ends
    goto start
    Kind regards
    Dennis
    @ READKEYPAD _myvar
    Except for the DEC modifier, good to go.
    start:
            @ READKEYPAD _myvar
               'pause 2000
            lcdout <strike>dec</strike> myvar      'display keypress variable myvar
       'transmit section
        'receive section
    goto start
    Default I noticed...
    OK got your message after I tried with the DEC modifier ;-) nothing worked !
    So I removed it and .....
    The LCD now shows the correct characters as per what I type in 123 etc and the ABCD keys as well as # and * ....YAY.....
    but sadly now nothing appears in hyperterminal ....
    Does SEROUT now need to be replaced by SEROUT2 ?
    Will try it later and post results either way :-)
    Need some sleep now ..
    Thanks so much for your continued help :-) much appreciated !
    Keep well
    Kind regards
    Dennis
    OH .. by the way .. do you maybe know how I could capture a keyin of the number say 135 # so that it is actually stored as binary or decimal 135 ?
    If you have PBP 2.60 then that will help. SEROUT has a buad rate problem.
    If you have 2.60, it's real easy with ARRAYREAD.
    Default Solved!!
    Hi Darrel
    Problem seems to be solved now.
    And the solution was in the very problem itself ...passing the variable !!
    I created a new variable called datatx
    and then after the displaying myvar to LCD with LCDOUT,
    all I did was let datatrx = myvar
    then SEROUT myvar
    And whammo it works :-) YAY ...!
    Thanks so much for all your help !
    Here's the code for reference and for anyone who might find it useful
    It captures a keypress, diplays it on the LCD and send the captured keypress via SEROUT.
    Kind regards
    Dennis
            cmcon   =   7
            TRISC = %10000000
            TRISD = %00000000
            TRISE.0 = 0
            TRISE.1 = 0
            TRISE.2 = 0
            myvar var byte
            datatx var byte
            datarx var byte
    'end of variables
            'DEFINE LCD_RWREG 0 	'defines the port where R/W line is connected to (set to 0 if not used)
            'DEFINE LCD_RWBIT 0 	'defines the pin where R/W line is connected to (set to 0 if not used)
    'END of LCD DEFINES
    'end of includes
    'end keypad code
    start:
            @ READKEYPAD _myvar
               'pause 2000
            lcdout myvar      'display keypress variable myvar
                  datatx = myvar '<<<<here's the solution :-)
                 lcdout datatx
       'transmit section
    'THE PROBLEM LINE >>>        SerOut PORTC.6,T2400,["the key pressed is ",datatx]
            SerOut PORTC.6,T2400,["the key pressed is ",datatx] 'SerOut PinNumber2,T2400,DataRec (FIXED!!
        'receive section
    goto start
    'End of all code
    then SEROUT myvar
    Well, I'm glad it's working, but I don't think that's what fixed it.
    All that did was copy a byte var to another byte var then displays the copied var. It's no different than displaying the original var in the first place.
    And since it works, I assume that means you don't have PBP 2.60, so I won't need to show an ARRAYREAD example.
    Default Would love an ARRAY read example :)
    Hi again Darrel
    Would love to see an ARRAY read example if you have the time ..if not just point me to a place to read about or reference it :-)
    Kind regards
    Dennis
    Oct 2009
    Utah, USA
    Default ARRAYREAD example
    Not sure what sort of ARRAYREAD example you are looking for... but here is one example.
    I am simply reading in a NMEA string from a gps unit and then parsing the NMEA sentence using ARRAYREAD.
    The underscore at the end of each line of the arrayread statement allows you to wrap the text so you do not have such a LONG sentence, yet it is still all one PBP statement.
    serin2 gps,188,3000,tmout,[WAIT("$GPRMC,"),STR GPRMC\63\"$"]
    arrayread gprmc,[DEC2 hh,DEC2 mm,dec2 ss,_
      wait(","),fix,wait(","),DEC2 latdeg,DEC2 latmin,wait("."),dec4 latminn,_
      wait(","),NS,wait(","),DEC3 londeg,DEC2 lonmin,wait("."),dec4 lonminn,_
      wait(","),EW,wait(","),dec knots,dec Knotss,dec course,_
      wait(","),DEC2 dy,DEC2 mt,DEC2 yr]
    Dwight
    Mar 2017
    Default Re: SEROUT,HSEROUT or DEBUG ? max 232 or no max232 ?
    Hi Dennis I'm brand new to the forum.
    I see your question about the usage of max232 is my question as well, I have built an interface with a Wi-Fi chip and asked them if I needed the MAX232 chip to stabilise the signal quality using the picbasic "SEROUT" function and showed them an oscilloscope image of the signal produced and they were very busy and answered with "device connect to Wi-Fi is RS232 interface, the MAX232 chip is needed but not if UART".Did you find out if the process is RS232 or UART ?Name:  BaudRate_9600_Inverted.jpg
Size:  219.8 KBName:  BaudRate_9600_NotInverted.jpg
    You replied to a seven year old thread... It would be best to start a new thread.
    When you start the new thread be sure to include the PIC you are using along with the WIFI module you are using. Without knowing this we would just be guessing about the best solution for you.
    Can I assume your wifi device is a variation of the ESP8266? If so, you would NOT require a MAX chip between the PIC and the Wifi module. Serout, Hserout should work, as also debug (the last in mode 0).
    Only thing to remember is the Wifi module, depending on the version you have might not be 5 volt tolerant.
    Anand Dhuru
    Mar 2017
    Hello ardhuru,
    I took mackrackit's advice and moved my quiry to http://www.picbasic.co.uk/forum/showthread.php?t=22510
    cheers
  1. N-Bit_MATH
    Last Post: - 16th December 2010, 15:48
  2. Wireless using debug.
    By polymer52 in forum mel PIC BASIC Pro
    Last Post: - 18th January 2010, 15:53
  3. About USB
    By dias11 in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2009, 21:41
  4. debug not working with MPASM assempler
    By santamaria in forum mel PIC BASIC Pro
    Last Post: - 4th March 2009, 08:51
  5. Data EEPROM gets clobbered during programming
    Last Post: - 18th July 2008, 03:46
