a little help with keypad on 18f4520 please
Results 1 to 18 of 18
    May 2008
    Italy
    Adding OPTION_REG.7 = 0 ' Enable PORTB pull-ups
    Shows a compile error in Microstudio
    Does not compile
    I am using an 18F4520
    Dennis not all pic has the internal pullup, could be that your mcu has not pullup.
    (Check the datasheet).
    Since you will need the pullups (otherwise the keypad will not work), so add four external 10K resistors.
    Al.
    Edit:
    Gusse has read the datasheet for you: Replace OPTION_REG.7 = 0 with INTCON2.7 = 0
    Post Thank you
    Al, Gusse
    Thank you both I implemented mister e's keypad using the whole of port B as an input had to perform some pin swaps on row and column order and it's working .
    I have two more questions :
    1.How do I set the keys to display the correct characters as per the keypad
    my matrix key's are labeled is as follows:
    1 2 3 A
    4 5 6 B
    7 8 9 C
    * 0 # D
    but when I press the keys for example 1,2,3,A
    My readout is 1,2,3,4
    Would I have to do a lookup or re-assignment ?
    2. How do i capture a number ending with a hash for example
    The reason I am asking is because I would like to type in a number for example 135 end it with a # to signify an enter and then store and send the number (TX).
    Any further help would be appreciated
    May 2008
    Italy
    1 2 3 A
    4 5 6 B
    7 8 9 C
    * 0 # D
    I am not familiar with mister e's keypad program, but if you get the sequence from 1 to 16, then use an array to code out what you need.
    Kp_Array    var byte [17]
    Kp_Array[1] = "1"
    Kp_Array[1] = "2"
    Kp_Array[15] = "#"
    Kp_Array[16] = "D"
    If Kp_Array[keypress] = "#" then ........
    Al.
    Thanks again for the tip Al :-)
    I was thinking along the same lines although I don't think this is exactly what I'm after.
    You see the keypad code only allows for a single keypress at a time at the moment.
    So the largest number you can type in is 16 (the highest key on the keypad)
    I want to be able to type in a number like 124 and end it with a #
    So this number (the actual number 124) can be transmitted.
    If you could imagine a cellphone or cordless landline...
    As you type in the numbers on the keypad you can see them on the screen and then you press dial or possibly C(clear or *) to backspace one digit.
    And when you are happy with the number on screen you press dial (in my case #) then your number is dialled (in my case TX'd)
    Does this make sense ?
    Kind regards
    Dennis
    May 2008
    Italy
    So that means that now the keypad works correctly, and when you press the wanted key you obtain the correct caracter.
    To acheive what you want, you will need an additional array and a few variables:
    The array will retain the numbers you key in and a variable should keep track of the number of time you have pressed the keys.
    Here a snippet
    Ratain         var byte
    Ret_Char     var byte [10]
    Ret_Count   var byte
    Ret_Prnt      var byte
    Ret_Clst       var byte
    Ret:Prnt = "#"
    Ret_Clst = "*"
    Loop:
    Ret_Char[Ret_Count]=Key_Char ' here you transfer the char of the key pressed
    If Retain = 0 then ' Retain is a flag then if set will do your job
    Hserout [Ret_Char[Ret_Count]]
    If Ret_Char[Ret_Count] = Ret_Clst then ' if key = "*" then step-back counter
    Ret_Count = Ret_Count - 1
    goto Clear_Count
    If  Ret_Char[Ret_Count] = Ret_Prnt then ' if key = "#" then send string
    Hserout [str Ret_Char \ Ret_count-1]
    RetCount = 0
    goto Clear_Count
    Ret_Count = Ret_Count + 1
    Clear_Count:
    I set the array Ret_Char to 10 elements, if you need more then adjiust it for your need. The snippet is not tested so some adjustment could be necessary.
    Al.
    Default almost spot on !!
    Al
    WOW thank you ... wasn't expecting you to code it for me :-)
    The array idea is perfect for capturing the keypresses and also the option to loop until we see a # or *
    The code snippet raises a few questions though....
    On receipt of a # it sends off a string of characters (those encountered before the #..not so ?
    For example I key in 134#
    First keypress to first variable in the array [1]
    Second to the second variable [3]
    Third to third variable [4]
    Then the # is encountered and we do an hserout
    Will we send a total of a 3 character string using hserout (in other words 24bits)
    Apologies if I have the workings of the code wrong ...I am not clued up on the workings of hserout yet but I am reading up.
    Once again any suggestions or guidance would be appreciated.
    Kind regards
    Dennis
    May 2008
    Italy
    Hserout [str Ret_Char \ Ret_count-1], will send out a string of Ret_count-1 bytes, so "#" will not be sent
    You could use SEROUT2
    SEROUT2,pin,baud,[str Ret_Char \ Ret_count-1]
    or you could use SEROUT
    For A0 = 1 to Ret_count-1
    Serout pin,baud,[Ret_Char [A0]]
    NEXT A0
    Al.
  1. 4x4 keypad Help
    By aaliyah1 in forum mel PIC BASIC Pro
    Last Post: - 5th October 2010, 17:34
  2. Universal Keypad System
    By aratti in forum Code Examples
    Last Post: - 18th January 2009, 14:06
  3. Keypad input test
    By Kalind in forum mel PIC BASIC Pro
    Last Post: - 8th October 2008, 05:00
  4. Need help in matrix keypad coding
    By rano_zen06 in forum mel PIC BASIC Pro
    Last Post: - 24th May 2008, 14:16
  5. Inconsistent output on a 4x4 matrix keypad
    By markcadcam in forum mel PIC BASIC Pro
    Last Post: - 24th November 2006, 04:54
