Hi Al
How are you ?
I am experimenting with your code snippet .. here's what I have so far.
'keypad variables for array keypress capture begin here
        Retain         var byte
        Ret_Char     var byte [10]
        Ret_Count   var byte
        Ret_Prnt      var byte
        Ret_Clst       var byte
        Ret_Prnt = "#"
        Ret_Clst = "*"
        'keypad capture code begins here
        Ret_Char[Ret_Count]=datatx ' here you transfer the char of the key pressed
        If Retain = 0 then ' Retain is a flag then if set will do your job
        For A0 = 1 to Ret_count -1
        Serout portc.6,T2400,baud,[Ret_Char [A0]]
        NEXT A0
        lcdout datatx 'display the variable on the LCD
        lcdout $fe,1          'clear lcd screen
        If Ret_Char[Ret_Count] = Ret_Clst then ' if key = "*" then step-back counter
        Ret_Count = Ret_Count - 1
        goto Clear_Count
        If  Ret_Char[Ret_Count] = Ret_Prnt then ' if key = "#" then send string
        Serout portc.6,T2400,[Ret_Char [A0]]
        NEXT A0
        RetCount = 0
        goto Clear_Count
        Ret_Count = Ret_Count + 1
        Clear_Count:
goto start
As i try to compile I encounter an error here
Not quite sure why ?
Do you think I could attain the same thing with either a case select statement or a do...while loop ?
So if I were using a do ... while (or while wend) for example
do
keep allowing keypress
While
key_press_variable is not equal to '#" 'until we see #
then serout
Kind regards
Dennis
