a little help with keypad on 18f4520 please
Results 1 to 18 of 18
    Default a little help with keypad on 18f4520 please
    Hi there
    I'm at wit's end ...
    I have been battling to get my matrix keypad(s) working, I have both a 4x3 and a 4x4 keypad.
    Two nights ago I stunbled across some postings and code in the forums which looked like they may be what I am looking for (with a few changes perhaps).
    After trying out both (namely the one from mister e and Steve) I still have not come right and can't understand what I am doing wrong.
    Please see my other posts on mister e's keypad code pages here
    http://www.picbasic.co.uk/forum/show...?t=3250&page=3
    as well as Steve's on this post(hope cross posting is ok):
    http://www.picbasic.co.uk/forum/show...0999#post80999.
    With Steve's implemetation I get only a "||" character on the LCD.
    Attached is my code.
    I am almost convinced I am not setting the registers correctly or calling a variable correctly :-( I was quite happy working with a 16f628 but now that I've re-kindled PIC's as hobby again I decided to go with an 18F series and it's taking some getting used to.
    If some kind soul would help me I would really appreciate it.
    Comments and suggestion or tips and tricks would be more than welcomed too.
    Kind regards
    Dennis
    'LCD code for 16 X 2  HD4x lcd
    'Ocsillator selections here
    OSCCON = $70            'Int CLK 8MHz
    OSCTUNE.6 = 1           'PLL 4x
    ADCON1= %00001111       '$0F = disable A/D converter
    'END of oscillator selections
    'Port IO directions and presets for port pins begin here
    'TRISA = %11111111       'All pins are outputs
    'TRISB = %00000000
    'for keypad
    '// Define port pins as inputs and outputs ...
       TRISA  = %00001000
       TRISB  = %00001101
    TRISC = %00000000
    TRISD = %00000000
    TRISE.0 = 0
    TRISE.1 = 0
    TRISE.2 = 0
    'End of Port IO directions and presets for port pins begin here
    'timer/oscillator defines
    DEFINE OSC 32            '4x 8MHz
    'END of timer/oscillator defines
    'variables begin here
    myvar var byte
    'LCD defines begin here
    DEFINE LCD_BITS 4 	'defines the number of data interface lines (4 or 8)
    DEFINE LCD_DREG PORTD 	'defines the port where data lines are connected to
    DEFINE LCD_DBIT 4 	'defines the position of data lines for 4-bit interface (0 or 4)
    DEFINE LCD_RSREG PORTD 	'defines the port where RS line is connected to
    DEFINE LCD_RSBIT 2 	'defines the pin where RS line is connected to
    DEFINE LCD_EREG PORTD 	'defines the port where E line is connected to
    DEFINE LCD_EBIT 3 	'defines the pin where E line is connected
    DEFINE LCD_RWREG 0 	'defines the port where R/W line is connected to (set to 0 if not used)
    DEFINE LCD_RWBIT 0 	'defines the pin where R/W line is connected to (set to 0 if not used)
    DEFINE LCD_COMMANDUS 2000 	'defines the delay after LCDOUT statement
    DEFINE LCD_DATAUS 200 		'delay in micro seconds
    'END of LCD DEFINES
    'keypad code here
     '// 3x3 Keypad - Rows as inputs, Cols as outputs...
       'Rows: RA3      Cols: RB1
       '      RB3            RA2
       '      RB2            RA4
       '      RB0
       ' RB5: LED & Buzzer ...
       ' RA0: TX to PC's Serial Port
       '// Declare Variables...
       Col_A     VAR PORTB.1
       Col_B     VAR PORTA.2
       Col_C     VAR PORTA.4
       Row_A     VAR PORTA.3
       Row_B     VAR PORTB.3
       Row_C     VAR PORTB.2
       Row_D     VAR PORTB.0
       Buzzer    VAR PORTB.5
       RX_To_PC  VAR PORTA.0
       Scan_Col  VAR BYTE       ' Counter - denoting current col in scan
       Key_Press VAR BYTE       ' Contains value of key (0-9) & * + #
       Key_Down  VAR BYTE       ' Flag set true when key is depressed
       Allow_Key VAR BYTE       ' Flag - disallow multiple keys being pressed
       I         VAR byte       ' General working var
       Scan_Keypad:
       '// Scan cols
          @ incf _Scan_Col, 1   ' Inc col pos...
          SELECT CASE Scan_Col  ' Col (1-3)
                 CASE 1
                      Col_A = 0 ' Switch on col (active low)
                      Col_B = 1 ' Col off
                      Col_C = 1 ' Col off
                      '// 3 Key
                               IF Row_A = 0 THEN        ' Key down? ...
                                  IF Allow_Key = 0 THEN ' Any other key down?
                                     Key_Press = 3      ' Load var w/value of key
                                     Allow_Key = 1      ' Disallow other keys
                      '// 6 Key
                               IF Row_B = 0 THEN
                                     Key_Press = 6
                                     Allow_Key = 1
                      '// 9 Key
                               IF Row_C = 0 THEN
                                     Key_Press = 9
                                     Allow_Key = 1
                      '// # Key
                               IF Row_D = 0 THEN
                                     Key_Press = 35
                                     Allow_Key = 1
                 CASE 2
                      Col_A = 1
                      Col_B = 0
                      Col_C = 1
                      '// 2 Key
                               IF Row_A = 0 THEN
                                     Key_Press = 2
                                     Allow_Key = 1
                      '// 5 Key
                               IF Row_B = 0 THEN
                                     Key_Press = 5
                                     Allow_Key = 1
                      '// 8 Key
                               IF Row_C = 0 THEN
                                     Key_Press = 8
                                     Allow_Key = 1
                      '// 0 Key
                               IF Row_D = 0 THEN
                                     Key_Press = 0
                                     Allow_Key = 1
                 CASE 3
                      Col_A = 1
                      Col_B = 1
                      Col_C = 0
                      '// 1 Key
                               IF Row_A = 0 THEN
                                     Key_Press = 1
                                     Allow_Key = 1
                      '// 4 Key
                               IF Row_B = 0 THEN
                                     Key_Press = 4
                                     Allow_Key = 1
                       '// 7 Key
                              IF Row_C = 0 THEN
                                     Key_Press = 7
                                     Allow_Key = 1
                      '// * Key
                               IF Row_D = 0 THEN
                                     Key_Press = 42
                                     Allow_Key = 1
                           end select
    'end keypad code
    '*********************Includes******
    'Includes end here
       Pause 500       ' Wait for LCD to startup
    'loop1:
     '  Lcdout $fe, 1   ' Clear LCD screen
      '  Lcdout "Hello"  ' Display Hello
       'Pause 1000       ' Wait .5 second
       'Lcdout $fe, $C0   ' Clear LCD screen
       'Lcdout "World"
       'pAUSE 1000
       'Lcdout $fe, 1   ' Clear LCD screen
     'Goto loop1       ' Do it forever
    'start:
    '@ READKEYPAD _myvar
    'lcdout $fe, 1
    lcdout Key_Press
    'goto start
    OKay I have even tried this example
    http://www.rentron.com/serkey16.htm
    and still get || on my lcd but the display does hange to things like ||| when I press some keys.
    I really can't see where I am messing up ... please please could someone help me with this
    May 2008
    Italy
    Tray to use LCDout Dec Key_Press and see if you get the correct ascii value.
    Al.
    Thanks Al
    I now see numbers and not ||
    OK so this is how I am now setup ...
    notice there are no pull-ups on the rows.
    I have series resistors on for the columns (100 OHM)
    In other words KEYPAD >> RESISTOR >> PIC (PortB4-7)
    Aah at least I am now seeing characters
    When Idle the LCD just displays 4 8 12 and the 16 and then it repeats :-(
    What's wrong :-(
    My wishlist
    A schematic( where to wire the pull-ups and where to wire the pull downs.
    I would prefer not to use Port.B since I have the pickit 2 setup for ICSP on PortB.6 and B.7.
    So which ports are advisable to use ? How should I TRIS each ?
    Some code shows keypad ports as input tohers as output ... some show pull-ups others show no pull-ups ?
    This is getting mega confusing
    Should I just stick with dipswitches and give up on the dream of using a keypad for input ?
    Any more help or comments would be seriously appreciated
    May 2008
    Italy
    You don't see any pullup because they are using internal pullup on portB
    See the instruction that activate the weak pullup in the code.
    OPTION_REG.7 = 0 ' Enable PORTB pull-ups
    If you use different port then you have to use external resistors.
    Al.
    Hi again Al
    Thank you again for the reply :-)
    Adding OPTION_REG.7 = 0 ' Enable PORTB pull-ups
    Shows a compile error in Microstudio
    Does not compile
    I am using an 18F4520
    So I am back to square one
    Any suggestions
  1. 4x4 keypad Help
    By aaliyah1 in forum mel PIC BASIC Pro
    Last Post: - 5th October 2010, 16:34
  2. Universal Keypad System
    By aratti in forum Code Examples
    Last Post: - 18th January 2009, 13:06
  3. Keypad input test
    By Kalind in forum mel PIC BASIC Pro
    Last Post: - 8th October 2008, 04:00
  4. Need help in matrix keypad coding
    By rano_zen06 in forum mel PIC BASIC Pro
    Last Post: - 24th May 2008, 13:16
  5. Inconsistent output on a 4x4 matrix keypad
    By markcadcam in forum mel PIC BASIC Pro
    Last Post: - 24th November 2006, 03:54
