Adding data to an "array" in ASM
Results 1 to 12 of 12
    Jun 2007
    Mansfield, UK
    Default Adding data to an "array" in ASM
    Hi, Im trying to write some of my PBP code in ASM. The bit im stuck on is setting values in an array. I know arrays dont really exist in ASM but i know its still possible to do what i want. After reading Mike's example in another thread i can see that i can access the elements of an array by using +1, +2 etc. Thats fine when its being added to a constant value. In Mike's example "Led" appears to be the address of the first element in the array.
    The array im working on at the moment uses a variable to decide which element to put data in. Heres the PBP version of the code
    bOutData[bOutDataPos]=cControlCharOut	'Control character (a constant)
    bOutDataPos=bOutDataPos+1
    bOutData[bOutDataPos]=0			'Data length (always zero here)
    bOutData[bOutDataPos]=aAddress		'Chip address (from variable aAddress)
    bOutData[bOutDataPos]=cAction		'Action (another constant)
    bOutData is an output buffer array. bOutDataPos gets incremented every time a byte is added to the array. The send routine elsewhere in the code then sends a byte, shifts all bytes up 1 place in the array then decrements bOutDataPos.
    So, can anyone point me in the right direction here? I just need to know how to access the array elements based on the value in bOutDataPos
    Bombay, India
    This does the same thing in assembly
    asm
        movlw   _bOutDataPos    ; read the index to W
        addwf   _bOutData,w     ; add base of the array and keep in W
        movwf   FSR             ; move W to INDirect File register
        movlw   _cControlCharOut
        movwf   INDF
        incf    FSR             ; move to the next location of array
        clrw
        movwf   INDF
        movlw   _aAddress
        movwf   INDF
        movlw   _cAction
        movwf   INDF
    endasm
    Jun 2007
    Mansfield, UK
    Thanks. That looks like exactly what i want. I wasnt sure if it was even possible with PICs.
    Ive looked FSR and INDF up in the datasheet and i found something else interesting too.
    POSTINC: accesses the FSR value, then automatically increments it by 1 afterwards
    The first part of this probably isn't working like you might expect.
      movlw   _bOutDataPos    ; gets the "address" of bOutDataPos into W
      addwf   _bOutData,w     ; adds the address + the "value" in bOutData
      movwf   FSR             ; loads FSR with the wrong address
    You want to add the base address of the array, which will never change, to the
    offset value in bOutDataPos to get the address for each array element;
      movf   _bOutDataPos,W   ; get the value of your index pointer in bOutDataPos
      addlw  _bOutData        ; add the index to the base address of your array
      movwf  FSR              ; load FSR with base address + offset
    This will probably make it easier to follow;
    Array       VAR BYTE[8]
    Index       VAR BYTE
    Address     VAR BYTE
    Action      CON 10
    ControlChar CON 20
    CLEAR
    Address = 15  ' address
    Index = 0     ' starting Array Index position
     Array[Index]=ControlChar
     Index=Index+1
     Array[Index]=0
     Index=Index+1
     Array[Index]=Address
     Index=Index+1
     Array[Index]=Action
     Index=Index+1
     GOTO Main
    The code after Main would be something like this, which maintains your Index pointer.
    asm
      movf   _Index, W     ;get "offset" value from Index pointer
      addlw  _Array        ;add it to Array[0] base address (result in W)
      movwf  FSR           ;load pointer with base + offset
      movlw  _ControlChar  ;load W with constant value in ControlChar
      movwf  INDF          ;move it to Array[Index]
      incf   _Index, F     ;inc Index pointer
      movf   _Index, W     ;load new Index pointer value
      clrf   INDF          ;Clear Array[Index]
      movf   _Address, W   ;get Address byte value
      movlw  _Action       ;load W with Constant value in Action
    endasm
    It could be made a bit smaller, and you could use incf FSR to increment the
    pointer each time, but you could lose track of which array element you last
    wrote to pretty quick.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jun 2007
    Mansfield, UK
    Ahh, I didnt notice that it was the wrong way round. It is right in my code though because i wrote it out myself instead of copy/paste (i remember better that way).
    Heres how my code looks now. I think its all right
    	; Get the start address for the array
    	MOVLW	_bOutData				; Set WREG to the start of the bOutData array
    	ADDWF	_bOutDataPos,0			; Add bOutDataPos to the address and store back in WREG
    	MOVWF	FSR0					; Copy WREG to the indirect file register
    	; Control character
    	MOVLW	_cControlCharOut		; Copy the output control character to WREG
    	MOVWF	POSTINC0				; Copy WREG to bOutData[bOutDataPos] (specified by indirect file register) and increment FSR0
    	INCF	_bOutDataPos			; Increment the array position
    	; Data length
    	MOVLW	0						; Set WREG to 0
    	; Chip address
    	MOVFF	_aAddress,POSTINC0		; Copy aAddress to bOutData[bOutDataPos]
    	; Action
    	MOVLW	_cActionPing			; Copy the ping action character to WREG
    Looks like you have it under control..;o}
    I don't recommend using this particular syntax though ADDWF _bOutDataPos,0. I much
    prefer being explicit with ADDWF _bOutDataPos,W. I can never remember if 0 or 1 is
    specifying W or F, so it's a lot easier for me, at a later time, to review code with explicit
    arguments.
    -Bruce
    tech at rentron.com
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 05:47
  2. Read/Write Problem
    Last Post: - 10th February 2010, 02:51
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 03:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 15:50
  5. Sinus calculating !
    Last Post: - 29th November 2004, 00:56
