Increment a Byte
Results 1 to 9 of 9
    Jun 2006
    Default Increment a Byte
    I have a simple problem but i don't can solve.
    pwr var byte
    If up = 1 Then
           PAUSE 50
           pwr = pwr + 1
           If pwr >= 255 Then pwr = 255
    Endif
    If pwr >= 255 always go to 0 and no to 255.Why happen this?
    May 2008
    Italy
    Since a byte can count up to 255 max when you add 1 to 255 the byte overflow and start from zero again (it cannot be 256).
    If you want to keep your variable pwr at 255 then you can skip the add command, or you must use a word variable.
    pwr var byte
    If up = 1 Then
           PAUSE 50
        If pwr = 255 Then Skip00
     pwr = pwr + 1
     Skip00:
    Endif
    Al.
    Jun 2006
    Thank you. It is work.
    I don't want use word variable , because pwr is for duty of HPWM.
    Wink
    Hi, Savnlik
    You just can use :
    For I = 1 to 255
    PAUSE 50
    HPWM 1,I,1000              ' The reason of your loop ( BTW ...). 1000 is pwm freq.
    NEXT I
    or ...
    DO
    I = I + 1
    While I < 255
    For limiting Numbers:
    I = J MIN 255  ' I is the smaller ( MIN ) number between J and 255 ...
    Or,
    If Pwr > 254 then pwr = 255
    Jun 2006
    Or,
    I had test and not work.Because next have count 255 + 1 = 256
    Jun 2006
    Hi, Savnlik
    You just can use :
    For I = 1 to 255
    PAUSE 50
    NEXT I
    or ...
    DO
    I = I + 1
    While I < 255
    I change the duty manually with two buton's (up and down)
    Ouch, yes of course... my mistake, sorry.
  1. LCD freeze
    By harryweb in forum mel PIC BASIC Pro
    Last Post: - 5th October 2009, 08:01
  2. Memory use - how much do you use?
    By keymuu in forum mel PIC BASIC Pro
    Last Post: - 10th June 2009, 22:39
  3. byte compression
    By Norbert in forum mel PIC BASIC Pro
    Last Post: - 16th June 2007, 18:04
  5. 16F877 RAM Question
    By Art in forum mel PIC BASIC Pro
    Last Post: - 6th August 2005, 11:47
