Averaging AtoD samples
Results 1 to 40 of 40
    I think the Fast Average section might be modified so that instead of jumping to the spurious noise point, it will reject the sample entirely.
    That should only take commenting 1 line from the original code.
    Mar 2009
    I've broke the breadboard circuit up ....so can't test right yet. But this sounds cool.
    How does the averging code decide whether what's coming in is spurious...or in fact the beginning of a new stream of samples (eg a new frequency arriving, which will generate a different comparator count - with it's own spurious counts).
    I guess what I really need issome form of 'trigger' (or 'change' threshold) so that my program then knows that a new frequency is coming in (& is not just a spurious reading)...
    For example, red test below is spurious count, blue is new frequency arriving (therefore count changes and starts coming in at around that new level)
    5000,4999,5000,5001, 3956,5000,5001,5000,4999,5000,3789, 2570,2571,2569,2570,2571,18912569,2571....
    Aug 2010
    Maryland, USA
    Hank, It seems to me you need to set some rules, or rather conditions. something like this:
    1) samples must be +- 10 of a target number to be included in the average
    2) numbers outside the +- 10 will need to have 2 more samples within the new samples range to be considered a good sample.
    That seems like it would weed out the rouge numbers. Now of course I have chosen random numbers. The 10 and 3. I don't really know what the numbers represent (I assume gutiar notes). Nor do I have a feel for how long a note will last. thats what drives the 10 number.
    -Bert
    We choose to go to the moon. We choose to go to the moon in this decade and do the other things, not because they are easy, but because they are hard, because that goal will serve to organize and measure the best of our energies and skills, because that challenge is one that we are willing to accept, one we are unwilling to postpone, and one which we intend to win, and the others, too.
                John F. Kennedy
    Notice in the image that all spurious samples were rejected.
    And where the samples changed from 6798 to 3899, the average caught up after 2 samples (adjustable with a constant).
    DEFINE OSC 20
    DEFINE LCD_DREG PORTB 'LCD data port
    DEFINE LCD_DBIT 0 'LCD data starting bit 0 or 4
    DEFINE LCD_RSREG PORTB 'LCD register select port
    DEFINE LCD_RSBIT 4 'LCD register select bit
    DEFINE LCD_EREG PORTB 'LCD enable port
    DEFINE LCD_EBIT 5 'LCD enable bit
    DEFINE LCD_BITS 4 'LCD bus size 4 or 8
    DEFINE LCD_LINES 2 'Number lines on LCD
    DEFINE LCD_COMMANDUS 2000 'Command delay time in us
    DEFINE LCD_DATAUS 50 'Data delay time in us
    DEFINE HSER_SPBRG 129 ' 9600 Baud @ 20MHz, 0.16%
    '----[Averaging Options]------------------------------------------------------------------
    AvgCount	CON  16		' Number of samples to average
    FAspread	CON  50 	' Fast Average threshold +/-
    Reject          CON  2          ' Spurious Rejection level
    ;----[Variables]--------------------------------------------------------------------------
    Value		VAR  WORD
    RejCount        VAR  BYTE
    ADavg		VAR  WORD
    ;----[Initialize]-------------------------------------------------------------------------
    RejCount = 0
    ADavg = 0
    ;----[Main Program Loop]------------------------------------------------------------------
        HSERIN [wait($FF),DEC Value]                                   ; get a sample
        HSEROUT ["Smpl= ",DEC Value]
        LCDOUT $FE,$80,"Smpl= ",DEC Value,"    "
        GOSUB Average                                                  ; average it
        HSEROUT ["  Avg= ",DEC ADavg] ;   ,"  Avg2= ",DEC ADavg2,13,10]
        IF RejCount > 0 THEN HSEROUT ["  Rejected"]                    ; indicate if rejected
        HSEROUT [13,10]
        LCDOUT $FE,$C0,"Avg = ",DEC Value,"    "
        LCDOUT $FE,$94,"FC  = ",DEC RejCount,"    "
    GOTO Main
    ' -=-=-=-=-=-=  Average Sample values -=-=-=-=-=-=-=-=-=-=
    Average:
        IF Value = ADavg Then RejCount = 0 : RETURN  ; NoChange
        IF ABS (Value - ADavg) > FAspread OR Value < AvgCount Then FastAvg
        IF ABS (Value - ADavg) < AvgCount Then RealClose
        ADavg = ADavg - (ADavg/AvgCount)
        ADavg = ADavg + (Value/AvgCount)
        RejCount = 0
        GoTo AVGok
      FastAvg:
        RejCount = RejCount + 1
        IF RejCount = Reject + 1 THEN
            ADavg = Value
            RejCount = 0
        GoTo AVGok
      RealClose:
        RejCount = 0
        ADavg = ADavg - (ADavg/(AvgCount/4))
        ADavg = ADavg + (Value/(AvgCount/4))
      AVGok:
        Value = ADavg			' Put Average back into Value
      NoChange:
    What filters and what rules?
    Darrel rules!
    A masterpiece, if I may say.
    Thanks Ioannis.
    And I'll say ... cncmachineguy's rules were pretty darn close to how I modified the averaging routine.
    Mar 2009
    Wow ...what can I say?!!
    DT you truly rock...and without a doubt you're my most favouritiest E-personage on the whole of this global network!
    I'll give this runout at the weekend...once again, thanks....just brilliant!!
    cnc machine guy - great input too ...many thanks.. re the arriving frequencies (or more importantly, what the PIC sees for incoming signal frequency - comparator 'count'), well, on a std tuned guitar, the lowest note is 82.4Hz...which @20Mhz clock gives a comparator interrupt 'count' of about 60700 per 82.4Hz period' ...the highest note on a guitar is about 1.4Khz & gives a comparator count of about 3500 1.4khz 'period'. Each musical note has about 5% difference...but the problem with guitar 'pitch detection' is you can bend a note, which will obviously fall somewhere in between the 5% between notes.
    I'd like to be able to eventually get the PIC discern not just which note is being played but also when it is s being bent - but for that I need good solid incoming samples to process...and these spurious samples were really screwing me up - hence I relish having a dabble with what DT has just posted!
  1. Darrel's latest 16 bit averaging routine?
    Last Post: - 17th October 2009, 01:57
  2. ADC Averaging
    By Sach_1979 in forum mel PIC BASIC Pro
    Last Post: - 21st September 2009, 06:53
  3. Atod Digital Filter
    By GeoJoe in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2008, 17:04
  4. Microchip free samples in UK?
    By zoki008 in forum Off Topic
    Last Post: - 21st March 2006, 16:06
  5. Averaging & 16 maths
    By paul.mcallister in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2005, 18:17
