Averaging AtoD samples
Results 1 to 40 of 40
    I played with Darrels 16 bit fast averaging routine and changing the values in HystLevel, AvgCount, FAspread, I got a very slow changing average if the sampling value was close to the average.
    But if suddently the input was grounded or connected to Vdd, then the Value of the average was instatly zeroed or maximized (1024 or 255 according).
    It is an amazing routine. Great job Darrel, once again.
    So, do not be afraid of changing the User Options as Darrel marked them and experiment.
    Test code:
    include "Fast_Average.pbp"
    lcdout com,1
    while 1
        lcdout com,$80,#Value,"    "
        adcin channel,var
        Value=var
        gosub average
    wend
    Mar 2009
    I too played with Darrel's averaging & was very impressed, but for this specific need (throwing away a sprurious reading that arrives in every 10 or 12 samples), I think perhaps Melanie's number sorting is more appropriate.
    Wrt Melanie's number sorting - I dabbled with a 'rolling window' (which just takes the next sample into an array & then sorts along with the previously stored samples already in the array) or a 'fill an empty array' type (which starts with an empty array....and waits untilt he array is filled before sorting, then empties & repeats). It might have been my cack approach, but I didn't see a whole lot of difference (results wise) between the two methods.
    plcguy ...thanks for the extra explanation, but that 140 'spurious' count - though much slimmed down - would still cause chaos in the frequency detect circuit I'm intending this to go in.
    I also mulled a "deduce which sample value appeared the most' in a group of samples ....which would be a handy utility to have, but at this stage of my programming life (early!), it's beyond me!
    Oct 2010
    Mabe I'm missing part of your challenge.
    How many samples will you throw before deciding it's a real change?
    If you look at the filter I added you can set the # of samples to skip as well as the % above and % below to determine what level of input is out of range.
    I would prob work on the spurious signal issue. good data acquisition is critical if the program is to be robust. That routine I added is really for a failed sensor check, rather than a continuous filter.
    Mar 2009
    Quote Originally Posted by Plcguy View Post
    The challenge is that when detecting frequency using the internal PIC comparators......the resulkting count appears to be jittery. By that I mean for say 1Khz, you get 'counts' arriving like thus...
    5000, 4999, 5000,4999, 5001, 5000, 4999,5001,3479, 5000,4999,5001
    now for the life of me I can't get to the bottom of why the spurious count arrives! (which would be the preferred option), so I'm faced with getting rid of it in software. What Melanie's number sort routine does, is sort an array of samples into numerical order (which will put the spurious count at the beginning), and then averages only the middle of the array. It gets rid of the spurious count completely.
    If the frequency changes, then the middle of the array (after sorting) should reflect the count.
    So my challenge if you like, is to get rid of spurious counts (ie not 'average' with them at all) ...and also to do this as quickly as possible.
    As I say Melanie's routine works....but I'm always open to other methods to rid spurious readings from the equation.
    Have you tried Darrel's routine with values set high enough?
    Mar 2009
    I tried Darrel's averaging when I wanted to smooth out rapidly changing AtoD values (the output of a peak detect - whose level is proprtional to ac signal amplitude...and moves about a lot) - it worked very well in that situation.
    But for this situation - I really don't want the spurious compartor counts to be handled at all - I want them rejected...so no, I haven't used it in this instance....unless I've missed the point, I don't think it's what I need here?
    As long as the values don't hit the edges your are fine.
    Give it a chance.
  1. Darrel's latest 16 bit averaging routine?
    Last Post: - 17th October 2009, 01:57
  2. ADC Averaging
    By Sach_1979 in forum mel PIC BASIC Pro
    Last Post: - 21st September 2009, 06:53
  3. Atod Digital Filter
    By GeoJoe in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2008, 17:04
  4. Microchip free samples in UK?
    By zoki008 in forum Off Topic
    Last Post: - 21st March 2006, 16:06
  5. Averaging & 16 maths
    By paul.mcallister in forum mel PIC BASIC Pro
    Last Post: - 22nd May 2005, 18:17
