newbie LCD to 18F4520
Results 1 to 4 of 4
    Default newbie LCD to 18F4520
    Hi all
    I am trying to get my LCD working on a pic 18F4520. (have tested the LCD on a 16f628 and it definitely works but only have the .hex file from years ago)
    SO right now I attaching the code I have so far ...
    I'm just not sure I have the code all correct.
    Do I need to add things like DEFINES to change the default ports.
    I would also like to use the built in clock.This is in my code, please could someone just double check it is correct.
    Here is my code so far, I know it's probably very wrong but it's what I have so far.
                OSCCON = $70            'Int CLK 8MHz
    OSCTUNE.6 = 1           'PLL 4x
    ADCON1= %00001111       '$0F = disable A/D converter
    TRISA = %00000000       'All pins are outputs
    TRISB = %00000000
    TRISC = %00000000
    TRISD = %00000000
    TRISE.0 = 0
    TRISE.1 = 0
    TRISE.2 = 0
    DEFINE OSC 32            '4x 8MHz
       Pause 500       ' Wait for LCD to startup
    loop1:
       Lcdout $fe, 1   ' Clear LCD screen
       Lcdout "Hello"  ' Display Hello
       Pause 500       ' Wait .5 second
       Lcdout "World"
       Goto loop1       ' Do it forever
    My pinout are as follows and please see the attached diagram too
    1 VDD VSS
    2 VSS VDD
    3 VEE VEE (10k)
    4 RS 21(PortD.2)
    5 RW VSS
    6 E 22(PortD.3)
    7
    8
    9
    10
    11 D4 27(PortD.4)
    12 D5 28(PortD.5)
    13 D6 29(PortD.6)
    14 D7 30(PortD.7)
    15
    16
    I really would appreciate any help and suggestions.
    Kind regards
    Dennis
    Yes, you need to set the DEFINEs if you are not using the default port/pins.
    Thanks Mackrackit
    Ok I have altered my code to.. would appreciate if someone could check it's right
    'LCD code for 16 X 2  HD4x lcd
    'Ocsillator selections here
    'END of oscillator selections
    'Port IO directions and presets for port pins begin here
    TRISB = %00000000
    TRISC = %00000000
    TRISD = %00000000
    TRISE.0 = 0
    TRISE.1 = 0
    TRISE.2 = 0
    'End of Port IO directions and presets for port pins begin here
    'timer/oscillator defines
    'END of timer/oscillator defines
    'LCD defines begin here
    DEFINE LCD_BITS 4 	'defines the number of data interface lines (4 or 8)
    DEFINE LCD_DREG PORTD 	'defines the port where data lines are connected to
    DEFINE LCD_DBIT 4 	'defines the position of data lines for 4-bit interface (0 or 4)
    DEFINE LCD_RSREG PORTD 	'defines the port where RS line is connected to
    DEFINE LCD_RSBIT 2 	'defines the pin where RS line is connected to
    DEFINE LCD_EREG PORTD 	'defines the port where E line is connected to
    DEFINE LCD_EBIT 3 	'defines the pin where E line is connected
    DEFINE LCD_RWREG 0 	'defines the port where R/W line is connected to (set to 0 if not used)
    DEFINE LCD_RWBIT 0 	'defines the pin where R/W line is connected to (set to 0 if not used)
    DEFINE LCD_COMMANDUS 2000 	'defines the delay after LCDOUT statement
    DEFINE LCD_DATAUS 200 		'delay in micro seconds
    'END of LCD DEFINES
    LCDINIT LcdCurBlink
    loop1:
       Lcdout "World"
    Default Ok all fixed now...almost
    OK all fixed now and working ....well almost :-)
    This line was causing my problem
    LCDINIT LcdCurBlink
    so just took it out ! See the working code below ;-)
    Now there just one problem to sort out ... the "hello world' message writes itself on one long string and then repeats without anyspaces on the first and second lines ....
    something like this
    Hello||World||Hello||World||Hello||World||Hello||W orld||Hello||World||Hello||World||
    How do I format it to something like
    Hello
    World
    TRISB = %00000000
    TRISC = %00000000
    TRISD = %00000000
    TRISE.0 = 0
    TRISE.1 = 0
    TRISE.2 = 0
    'END of LCD DEFINES
    loop1:
       Lcdout "World"
  1. Newbie? Problem with LCD
    By lew247 in forum mel PIC BASIC Pro
    Last Post: - 7th December 2009, 20:48
    Last Post: - 8th August 2009, 20:54
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  5. LCD will not start
