A PIC logic 0V output is not equal to a ground?
Results 1 to 6 of 6
    Mar 2009
    Default A PIC logic 0V output is not equal to a ground?
    I've put a question mark at the end of the Subject heading, but I can kind of answer my own question!
    If I physically ground the +ve input to this opamp pin (using a flying lead to connect the pin to ground), the opamp's output inverts vs the input (as it should)....
    but if I then change by connecting that same opamp pin but directly to a PIC pin & then set the PIC pin as an output 'LOW' - weird stuff happens (the output from the opamp looks akin to a full wave recified signal - ie where the negative cycle is flipped up)
    So, a PIC's 0V ouput isn't ground?
    (no laughing at the back - I might be stating the obvious to you, but not to me!)
    What would be my best option to ground that opamp pin under PIC control? (I've tried a CD4066 with poor results - same thing ....the opamp's output looks full wave rectified!)
    Try a low gate voltage (1.5v or 2.5v) NFET, something that will handle low current. That should work reliably.
    Nick
    Wink
    Hi Hank,
    Quite annoying for 180° out of phase looked for ...
    The good question might be : what does my OPA do with inputs tied to ground ???
    This is generally called " Common mode Input Voltage Range "
    RTFDatasheet ... in short terms !
    741 ( ! ) or 5532 AOP ???
    also remember PIC pin must be OR left floating OR Grounded ....
    Mar 2009
    Hi Hank,
    I wouldn't know how to interpret the opamp datasheet for that kind of thing! But I do know when I hardwire the Opamp's +ve pin to ground...the circuit performs as expected (input signal is inverted)...remove the ground & the input is non inverted at the ouput. However when applying a PIC output low in the same manner - eeeeugh. That particular circuit is a fairly generic circuit & not specific to any particular opamp variant.
    Nick, I'll give that a go, but I'm not confident - if a CD4066 doesn't work in situ (which as very low channel 'on' resistance), then it's likely to have a similar outcome!
    Wink
    So, use MacGman idea ...
    a 2N7000 or 7002 will do it !!!
    BTW ... which is the OPA supply voltage ??? ...
    Yes, most digital logic outputs are not purely ground. The are guaranteed to be within a certain range close to 0, usually 0.2 v which is typical VCE of a saturated transitor. For your application, the lowest Rds FET you can find would work best. Also make sure it can be controlled by a 5VDC signal. Like a BSS138LT or Si4410BDY or IRLL014N.
    Tim Barr
  1. Variable voltage output from a Pic?
    By Dan_lay in forum General
    Last Post: - 24th June 2013, 20:25
  2. Controlling power to a PIC with another PIC
    By jswayze in forum Off Topic
    Last Post: - 28th May 2005, 19:44
  3. Serial Pic to Pic using HSER
  4. Bluetooth wireless with PIC / HSERIN / DAC
    By rpatel in forum mel PIC BASIC Pro
    Last Post: - 20th December 2004, 22:13
  5. PIC vs PLC (programmable logic controller)
    By pondindustrial in forum Off Topic
    Last Post: - 17th December 2004, 21:11
