Question about Option_Reg
Results 1 to 3 of 3
    Question Question about Option_Reg
    Hi, I would like to ask something about option_reg:-
    If I want to make a system where PIC does somthing upon a switch press. A correct statement would be (Considering the use of OPTION_REG):
    A) Enable the PULL UP or PULL DOWN and connect the switch between Gnd and the PIC pin or the other way around.
    B) It does not work when pins are made as inputs so connect external resistance to GND. The switch between VCC and PIC pin or other way around?
    I did try to find this answer in datasheet but unfortunately either I missed it or it's not there. Thanks for your help.
    ___________________
    WHY things get boring when they work just fine?
    May 2008
    Italy
    Only bit 7 of OPTION_REG control the weak pullup on portB and only on portB.
    When :
    OPTION_REG.7 = 0 the weak pullup are set
    OPTION_REG.7 = 1 the weak pullup are removed
    Naturally the pullup apply only if portB is an input, otherwise if is set as an OUTPUT, you don't need any pullup.
    If you need a pulldown situation, on portB, then you set OPTION_REG.7 = 1 and you connect external resistors from pins to ground.
    Al.
    Question
    Thanks Aratti......But is it a reliable way to do it? On one side it's great that I save space on my PCB. Has any of your projects caused any problems or unreliable operation due to internal PULL up or Pull down?
    ___________________
  1. ADCIN question
    By Greg McFadden in forum General
    Last Post: - 16th September 2008, 03:53
  2. AN Question for "word" variable read The serial port
    By redfoen in forum mel PIC BASIC Pro
    Last Post: - 14th December 2007, 18:39
  3. Remote PIC input question
    By Adrian in forum mel PIC BASIC Pro
    Last Post: - 1st September 2007, 16:44
  4. Question for a math guru
    Last Post: - 22nd November 2006, 10:45
  5. Please answer my first question
    By John_001 in forum Off Topic
    Last Post: - 15th September 2006, 07:49
