X10 commands and PBP
Results 1 to 10 of 10
    Quote Originally Posted by aratti View Post
    you did already experiment XIN without success, so you solved the problem decoding the X10 burst writing your own Rx routine.
    Without success, if I interfaced the circuit directly with the mains, *without* a TW523. Yes, I did manage to decode the signal with my own routine, rather than XIN.
    More explicitely "XIN instruction doesn't work" and forget about fixing PBP XIN instruction, write your own Rx routine.
    Not quite true; XIN does work, only when used with a TW523.
    http://www.x10.com/products/x10_tw523.htm
    Anand
    Dec 2005
    There are some other reasons to write your own routines. The TW523 delays its output for 22 half-cycles of the powerline (so it can validate the commands) and it only outputs if the commands are valid. This saves you the trouble of checking the manchester coded commands but also means your processor is deaf to the powerline while the previously received command is being output. The 22 half-cycle periods of deafness mean you miss 2/3 of dim/bright commands and cannot receive X-10's extended commands. Most importantly, the TW523 cannot avoid collisions as it is not operating in real time - it can only detect them after the fact. The TW523 was designed about 30 years ago and uses outmoded technology.
    XIN assumes a TW523 so it does not handle extended codes.
    XIN may also be expecting a silence after 22 half-cycles and is being confused by the continued output from the TR-2A.
    The TR-2A operates in real time so you need not miss any powerline activity. You can avoid collisions but you will also need to check the manchester validity of received commands.
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 13:55
    Last Post: - 28th September 2021, 12:26
  3. Sending Commands from Visual Basic about IR to Pic
    By tne_de in forum mel PIC BASIC Pro
    Last Post: - 29th April 2009, 07:09
  4. PBP - are DEFINE command(s) mandatory?
    Last Post: - 15th September 2006, 17:43
  5. WRITE not working
    By servo260 in forum mel PIC BASIC Pro
    Last Post: - 29th December 2004, 03:02
