finally got the setup to work.
can't say for sure what exactly what was causing the problem. reflashed all the xbee's to their default and reset a few parameters and all is working fine.
code was fine and the pic's were fine.
From a very preliminary test I did, the receiver of the XBees is very susceptible to saturation. I had to move the modules 10-15 meters away to work properly. I know this seems irrelevant ot your case but just keep it in mind.
P.S. Are you going to make a ZigBee network?
the distance factor could have been an issue and one to keep in mind. thanks.
i have the xbp24-zb's for another project for a ZB network.
this current one is using the "802.15.4 series I" xbee's.
i wonder if there is a config parameter that helps with the saturation issue for short distances? would you know?
Just drop the RF power to the minimum. But ifdistance is less that 5 meters the receivers are saturated again.
0= -10dBm
1= -6dBm
2= -4dBM
3= -2dBm
4= 0dBm
so with these 802.15.4 series I, lowest would be -10dBm, yes?
good to know, thx
