Help using this crystal?
Results 1 to 6 of 6
Threaded View
    Perth, Australia
    Default Help using this crystal?
    I'm used to using regular 32.768khz 2-pin crystals with 2 caps to drive timer1 for a real time clock.
    But I have this 4-pin clock/crystal that I would like to use (pic attached), but i'm not sure how to go about it.
    I've searched for a data sheet but havnt had much luck finding one that is an exact match.
    Do I still need capacitors for this type of clock? And how do the connections to the timer OSC pins go considering this thing has 4 pins.
    Thanks.
  1. Sharing Crystal with 2 IC's
    By ShaneMichael in forum mel PIC BASIC Pro
    Last Post: - 10th January 2013, 13:33
  2. 20 Mhz Crystal, simple blinking LED
    By BenjaminsShinob in forum mel PIC BASIC Pro
    Last Post: - 16th October 2007, 05:06
  3. Crystal osc running but PIC not using it
    By p15218 in forum mel PIC BASIC Pro
    Last Post: - 18th February 2007, 22:33
  4. Pulsin to pulsout with up than 4MHZ crystal ?
    By RCtech in forum mel PIC BASIC
    Last Post: - 18th May 2006, 19:23
  5. Replies: 1
    Last Post: - 30th June 2004, 08:07
