I can not get arround to read the RFID reader.
I was able to properly read my RFID by connecting to pin 3 from my computer's serial port and using hyperterminal so I know the RFID module is working.
Running my code bellow I see the word "test" on my LCD so I know the LCD is properly connected but everytime I get a beep out of my RFID tag I get garbage characters and different characters every time I use the same tag, I am using the dev board that came with Pickit2 (16F887) and connected LCD in 4 bit mode to port B0-B3, RS to B4 and EN to B5 with output of RFID to port C7.
Any help would be appreciated to get me started.
Thank you.
Code:INCLUDE "modedefs.bas" DEFINE OSC 4 TRISB = %11000000 ADCON0 = %00000000 ANSELH = %00000000 WPUB = %00000000 IOCB = %00000000 DEFINE LCD_DREG PORTB ' Set LCD Data port DEFINE LCD_DBIT 0 ' Set starting Data bit (0 or 4) if 4-bit bus DEFINE LCD_RSREG PORTB ' Set LCD Register Select port DEFINE LCD_RSBIT 4 ' Set LCD Register Select bit DEFINE LCD_EREG PORTB ' Set LCD Enable port DEFINE LCD_EBIT 5 ' Set LCD Enable bit DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits) DEFINE LCD_LINES 2 ' Set number of lines on LCD DEFINE LCD_COMMANDUS 2000' Set command delay time in us DEFINE LCD_DATAUS 50 ' Set data delay time in us define HSER_RCSTA 90h 'DEFINE HSER_TXSTA 20h DEFINE HSER_BAUD 9600 DEFINE HSER_SPBRG 25 define HSER_CLROERR A0 var byte A1 var byte A2 var byte A3 var byte A4 var byte A5 var byte A6 var byte A7 var byte A8 var byte A9 var byte A10 var byte A11 var byte LCDOUT $FE,1,"test" 'clear lcd pause 1000 LCDOUT $FE,1 main: HSERIN [A0,A1,A2,A3,A4,A5,A6,A7,A8,A9,A10,A11] LCDOUT $FE,1,A0,A1,A2,A3,A4,A5,A6,A7,A8,A9,A10,A11 goto main End
