@mister_e please read your pm box
I download the code from Melabs and it is the code for writing to 93C56, i use this code for 93C46 but it is not working. Anybody can please help to advise what could I change to make this code work for 93C46?
For more information the ORG pin is short to the ground or VSS. Meaning byte size address organization.
Please help. Thanks!
Here is the code below:
' PicBasic Pro program to read and write to Microwire SEEPROM 93LC56A
' Write to the first 16 locations of an external serial EEPROM
' Read first 16 locations back and send to LCD repeatedly
' Note: for SEEPROMs with byte-sized address
' Define LOADER_USED to allow use of the boot loader.
' This will not affect normal program operation.
Define LOADER_USED 1
Define OSC 4
Define LCD_DREG PORTD
Define LCD_DBIT 4
Define LCD_RSREG PORTE
Define LCD_RSBIT 0
Define LCD_EREG PORTE
Define LCD_EBIT 1
include "modedefs.bas"
CS var PORTA.5 ' Chip select pin
CLK var PORTC.3 ' Clock pin
DI var PORTC.4 ' Data in pin
DO var PORTC.5 ' Data out pin
addr var byte ' Address
B0 var byte ' Data
Low CS ' Chip select inactive
ADCON1 = 7 ' Set PORTA and PORTE to digital
Low PORTE.2 ' LCD R/W line low (W)
Pause 100 ' Wait for LCD to start up
Gosub eewriteen ' Enable SEEPROM writes
For addr = 0 To 15 ' Loop 16 times
B0 = addr + 100 ' B0 is data for SEEPROM
Gosub eewrite ' Write to SEEPROM
Pause 10 ' Delay 10ms after each write
Next addr
loop: For addr = 0 To 15 ' Loop 16 times
Gosub eeread ' Read from SEEPROM
Lcdout $fe,1,#addr,": ",#B0 ' Display
Pause 1000
Next addr
Goto loop
' Subroutine to read data from addr in serial EEPROM
eeread: CS = 1 ' Enable serial EEPROM
Shiftout DI, CLK, MSBFIRST, [%1100\4, addr] ' read comd and add
Shiftin DO, CLK, MSBPOST, [B0] ' Read data
CS = 0 ' Disable
' Subroutine to write data at addr in serial EEPROM
eewrite: CS = 1 ' Enable serial EEPROM
Shiftout DI, CLK, MSBFIRST, [%1010\4, addr, B0] ' write cmd add, data
CS = 0 ' Disable
' Subroutine to enable writes to serial EEPROM
eewriteen: CS = 1 ' Enable serial EEPROM
Shiftout DI, CLK, MSBFIRST, [%10011\5, 0\7] 'write enable cmd clk
CS = 0 ' Disable
