Problem with 16Ff648a
Results 1 to 19 of 19
    Thanks Darrel, but I did say in my post at 15:51
    Quote Originally Posted by aerostar View Post
    The EPIC programmer software is 2.46beta, latest for this from Melabs site. I have tried the Melabs programmer 4.32beta, but that does not work, it does not read the chip ID.
    and will not even program the chip with the ID detect turned off.
    More info when I do some more testing....
    Early morning test .........
    After thinking about it overnight I wondered if the pic was not crashing but re-starting, so I put the following into the the pic, the porta loop lets me know that the program has started, and will let me know if the pic restarts.
    With the CLEAR in between the portb loops it never executes the 2nd, but restarts the program ! as port A.0 starts toggling again.
    Remove the CLEAR and it works as expected, so I will have to get a different batch of 648As to see if it is the pics.
    DEFINE OSC 20
    COUNTER VAR BYTE
    FOR COUNTER = 0 TO 10 ' confirms beginning of program
    LOW PORTA.0
    PAUSE 250
    HIGH PORTA.0
    PAUSE 250
    NEXT
    TEST:
    FOR COUNTER = 0 TO 20
    LOW PORTB.7
    PAUSE 250
    HIGH PORTB.7
    PAUSE 250
    NEXT
    CLEAR
    LOW PORTB.7
    PAUSE 500
    HIGH PORTB.7
    PAUSE 500
    NEXT
    GOTO TEST
    Thanks Darrel, but I did say in my post at 15:51 ... I have tried the Melabs programmer 4.32beta
    Woops. My bad.
    As soon as I see 2.46 beta, I stop looking for anything else.
    I would be curious what happens with this program.
    Since about the only difference between the 628A and 648A programs will be clearing the additional RAM in BANK2.
    This program tries to clear the same memory without the clear statement.
    It doesn't do banks 0 or 1 because they were already checked with the 628 program loaded in the 648.
    DEFINE OSC 20
    Idx     VAR BYTE
    B2RAM   VAR BYTE[80] BANK2
    COUNTER VAR BYTE
        LOW PORTA.0
        PAUSE 250
        HIGH PORTA.0
        PAUSE 250
    NEXT
    TEST:
    FOR Idx = 0 TO 79
        B2RAM(Idx) = 0
    NEXT Idx
    LOW PORTA.0   ' turn LED on to indicated completed
                  ' may need HIGH don't know which way the LED is.
    STOP
    Probably nonsense, but I'm still curious.
    DEFINE OSC 20
    Idx     VAR BYTE
    COUNTER VAR BYTE
        LOW PORTA.0
        PAUSE 250
        HIGH PORTA.0
        PAUSE 250
    NEXT
    TEST:
    FOR Idx = 0 TO 79
        B2RAM(Idx) = 0
    NEXT Idx
    STOP
    Hi Darrel
    Thank you very much for the code, it works with no problem, I then modified it to check that after writing 0 to the location it was read back to see if it had been written correctly, answer is yes. I then made it keep doing, and again no failures.
    Something is very strange. I have ordered some more 648As from another supplier, they may arrive tomorrow
    I have just been looking through the listing and see that PB shows the following
    16 =0020 RAM_START EQU 00020h
    17 =01EF RAM_END EQU 001EFh
    18 =0003 RAM_BANKS EQU 00003h
    19 =0020 BANK0_START EQU 00020h
    20 =007F BANK0_END EQU 0007Fh
    21 =00A0 BANK1_START EQU 000A0h
    22 =00EF BANK1_END EQU 000EFh
    23 =0120 BANK2_START EQU 00120h
    24 =01EF BANK2_END EQU 001EFh
    25 =2100 EEPROM_START EQU 02100h
    26 =21FF EEPROM_END EQU 021FFh
    page 17 of my data sheet shows that bank 2 ends at 16FH not as it says above, 1EFH , could this be the problem or am I missing the obvious ?
    What do you think ?
    edit.
    I have just changed the bank 2 end location to 16FH from 1EFH in the 648a.bas file and recompiled using the program in post 14, with the clear in position.......it works perfectly... so do you think I have found the problem ?
    Further update, on Bank end location, I have had a look at later version 2.61 files, my current one 2.43 I have used for many moons, and it looks as though the file may have been corrected in 2007, shows the value of updates, but then I would have thought someone would have noticed. I will try tomorrow with 2.61 and confirm that has no problems.
    That's definately it.
    But you had said before ...
    but it crashes, compiled with 2.43 or 2.6.
    Ha, we're even.
    Talking
    where did I put my Beretta Balltrap Sporting gun and my buckshot cartdriges ???
    I was thinking of BADRAM/MAXRAM ... but nooo... could not be possible to have been modified !!!
    EVERYTHING is posssible ... LOL
  1. Problem to compile my program
    By wagner in forum Off Topic
    Last Post: - 7th July 2008, 21:17
  2. USART Problem , but don't know where, in pc? or in PIC?
  3. Microcode Studio 18f2455 problem?????
    By volkan in forum mel PIC BASIC Pro
    Last Post: - 21st May 2007, 22:04
  4. Hardware problem or what ?
    By Steve S. in forum mel PIC BASIC Pro
    Last Post: - 4th March 2007, 22:39
  5. 1 slave 1 master 1 MAX232 1 problem ?
    Last Post: - 31st July 2005, 23:59
