Dear Jerson & Bruce,
I could not get here earlier, sorry. I appreciate your efforts !
Jerson, if i declare the delay variable as a byte, it takes even longer.
I just don't understand .. The delay macro i found works perfect if given a number straight from the call, if it is fed by a variable the delay jumps to 20 or 30us. It also seems that the delay is fixed after that, if i compile @ wait 1000, it delays a perfect 1000 cycles, if i compile @ wait ledred (i.e. ledred = 100) it delays 20uS no matter what ledred is ?
Bruce, your asm code also does the trick, perfect 1us or 50us delays, pretty neat. But it also suffers from the same problem. If i compile @ Delaycycles 200 if works perfect, if i compile ledred var byte, ledred = 200, @ delaycycles _ledred it gives a delay of 33uS no matter what the value of the leded var is ??
Apart from that, i need to do a delay between 1 and 1000uS, using tmr0 the max delay will be 256, and i can use the Bruce asm up to 512, the ASM code i posted earlier can go up to about 1024.
I would use the 16-bit TMR1 if it was available but i need that to do a 100Hz sync (count) interrupt...
Any ideas ?
