Simple asm delay ?
Results 1 to 23 of 23
    Apr 2006
    GearSweaterMountain, The Netherlands
    Hi Jerson,
    I understand your questions, let me explain some more :
    I drive 3 powerled's directly from the mains using a led driver board. These led's are switched by FET's, each on it's own channel. The driver board itself is about 10x10mm, a pic with 3 pwm channels in a SO8 package is just not available. Everything larger won't fit the enclosure.
    The driver cannot drive 2 or 3 led's at once, that's why i'm switching between the three. Doing so at a total delay (led1 delay + led2 delay + led3 delay)=1000Hz + some overhead.
    Pauseus does it's work, and all is fading smoothly. Except for the first start of a color. This sticks to 12us. When a fade is started, the color that is being faded in does not start at 1 or 2 us but starts with an initial delay of 12uS.
    Hope this makes my problem somewhat clearer ...
    I did count the instruction cycles, i even did a cross comparison of the asm files, the one using a number @ wait 0 and the one using @ wait _ledRED both files are exactly the same and have the exact same length ! I played around with the variables, changed them to byte's, putting them in bank0 ....
    Why would changing from a numeric value to a numeric value stored in a variable result in an overhead of 30uS, i just don't understand.
    Apr 2006
    Small update :
    Declaring the variables as:
    ledRED VAR WORD BANK0
    Does reduce the total delay somewhat, the shortest delay (0) now results in 20uS ..
    Bombay, India
    Try declaring your variable as BYTE instead of word. It will shave more time from the 20uS.
    Bombay, India
    Assuming you have TMR0 (8 bit timer) free, you can try this code
    AsmDelay macro  delayus
          movlw  0FFh-delayus    ; delayus to overflow                          1T
          movwf  TMR0        1T
          bcf        INTCON, T0IF    ; clear the timer0 Overflow flag          1T
          btfss     INTCON, T0IF    ; wait till it overflows                          1T/2T
          goto      $-1                   ; back to the btfss                              2T
    The minimum delay you will achieve will be 4T cycles or roughly 2uS at 8MHz.
    The way to use it would be
          GPIO = %01
          @ AsmDelay 12
          GPIO = %10
          @ AsmDelay 24
    I hope this takes you closer to your goal. The code is just a concept, you may have to correct it. One important point you should note - the maximum delay will be 255uS
    Try this.
    asm
    DelayCycles macro ncy ; ncy can be from 1 up to 256
      local n
    n set   (ncy)   ; assign ncy value to label n
      while n > 2   ; inserts goto $+1 while n > 2
        goto $+1    ; burn 2 cycles
    n   set   n - 2 ; n = n - 2
      endw
                    ; handle left-overs
      while n > 0   ; 1 nop for odd numbers
        nop         ; burn 1 cycle
    n   set   n - 1 ; n = n - 1
      endw
    endasm
      HIGH 0
      @ DelayCycles 1  ; adds 1 nop
      LOW 0
      @ DelayCycles 5  ; adds 2 x goto $+1 and 1 x nop
      GOTO Main
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Bombay, India
    Brilliant work.
    PS. It has a catch though. Te macro expansion occurs at compile time. So, you will not be able to "feed" the delay value at runtime
    Apr 2006
    Dear Jerson & Bruce,
    I could not get here earlier, sorry. I appreciate your efforts !
    Jerson, if i declare the delay variable as a byte, it takes even longer.
    I just don't understand .. The delay macro i found works perfect if given a number straight from the call, if it is fed by a variable the delay jumps to 20 or 30us. It also seems that the delay is fixed after that, if i compile @ wait 1000, it delays a perfect 1000 cycles, if i compile @ wait ledred (i.e. ledred = 100) it delays 20uS no matter what ledred is ?
    Bruce, your asm code also does the trick, perfect 1us or 50us delays, pretty neat. But it also suffers from the same problem. If i compile @ Delaycycles 200 if works perfect, if i compile ledred var byte, ledred = 200, @ delaycycles _ledred it gives a delay of 33uS no matter what the value of the leded var is ??
    Apart from that, i need to do a delay between 1 and 1000uS, using tmr0 the max delay will be 256, and i can use the Bruce asm up to 512, the ASM code i posted earlier can go up to about 1024.
    I would use the 16-bit TMR1 if it was available but i need that to do a 100Hz sync (count) interrupt...
    Any ideas ?
  1. 16F628A - Stops if release power switch.
    By dene12 in forum General
    Last Post: - 14th February 2009, 08:57
  2. Old and beyond help ?
    Last Post: - 11th December 2008, 16:23
  3. RF Transmitter
    By et_Fong in forum mel PIC BASIC Pro
    Last Post: - 27th October 2005, 17:34
  4. Memory Space of the PIC16F84...
    By Tear in forum mel PIC BASIC Pro
    Last Post: - 1st July 2005, 20:55
  5. Problem with saving to EEPROM...
    Last Post: - 1st July 2005, 01:10
