Simple asm delay ?
Results 1 to 23 of 23
    Apr 2006
    GearSweaterMountain, The Netherlands
    Default Simple asm delay ?
    Hi All !
    I'm kinda stuck @ the moment. I have a 12F683 and i need to do a variable delay ranging from 1us to 1000us.
    The problem is that at 8Mhz the pauseus can't go as low as 12us.
    Does anybody have a asm routine or macro that can be used here ?
    Something like :
    Macro delay(time in us)
    if time = 1 then
    nop
    nop
    if time = 2 then
    nop
    nop
    nop
    nop
    if time = 3 then
    etc, etc ...
    Thanks !
    Jun 2007
    Default Use a FOR NEXT
    I think that you could use something like.
    Delay Var Word ' Pause in us
    Counter Var Word
    FOR Counter = 1 to Delay
    @nop
    @nop
    NEXT Counter
    It's untested so I'm guessing it should work but I don't know how long the LOOP will add to the pause.
    Regards, Mike
    Bombay, India
    Assuming a 8MHz clock, some ASM macros
    delay1us macro
        goto $+1      ;  2 cycle delay
    delay2us macro
        delay1us
        delay1us
    delay4us macro
        delay2us
        delay2us
    delay8us macro
        delay4us
        delay4us
    Now, you may want to get something like 5 us. For that you can
    @ delay4us
    @ delay1us
    in your code
    Hope this is helpful to you.
    Apr 2006
    Wow, Thanks.
    I'm gonna try this. Tried the for..next just yet but it won't go below 5us delay.
    Jerson, i think this would do the trick, but i need to figure out how to let the software 'choose' the right delay .. I need to be able to feed the number of uS to delay to the asm macro.
    Something like ...
    Delay1us  macro time
    for x = 0 to time
        goto $+1
    next
    Wink
    The 683 has a TMR1 and also a CCP module ...
    just use one of them for variable delays !!!
    see asm examples in the relevant Datasheet chapter ...
    may be 1 and 2 microseconds will need a "special treatment" ...
    Apr 2006
    You are so right !
    The thing is however, i have tmr1 setup as a counter and i use its overflow to sync the whole program on 100hz.
    I have three different led's that are driven by fet's. Each led has it's own channel and due to the design of the driver, at a given moment only 1 led me be high.
    To be able to shift the colors around, i turn on a certain channel for a certain ammount of time.
    RED con %001
    GRN con %010
    BLU con %100
    loop60
        if ledred = 0 then goto noRED
        GPIO = red
        pauseus ledred
    noRED:
        if ledgrn = 0 then goto noGRN
        GPIO = grn
        pauseus ledgrn
    noGRN:
        if ledblu = 0 then goto noBLU
        GPIO = blu
        pauseus ledblu
    noBLU:
    goto loop60
    Once interrupted the ledred / ledgrn / ledblu values are altered, but always in a way that ledred+ ledgrn + ledblu = 1000, the timer get's a reset and it then jumps back into the loop.
    The example above works but pauseus can't delay faster then 12us ...
  1. 16F628A - Stops if release power switch.
    By dene12 in forum General
    Last Post: - 14th February 2009, 08:57
  2. Old and beyond help ?
    Last Post: - 11th December 2008, 16:23
  3. RF Transmitter
    By et_Fong in forum mel PIC BASIC Pro
    Last Post: - 27th October 2005, 17:34
  4. Memory Space of the PIC16F84...
    By Tear in forum mel PIC BASIC Pro
    Last Post: - 1st July 2005, 20:55
  5. Problem with saving to EEPROM...
    Last Post: - 1st July 2005, 01:10
