help with calculator
Results 1 to 4 of 4
    Nov 2009
    Default help with calculator
    I'm building a 4-digit calculator but when you put 9999 * 9999 I get an error in the outcome variable 37601 where I keep the result for display of word type, help please
    Talking
    Without further detail given ...
    Your calculator is limited to a RESULT of 65535 ...after that there's some truncature.
    You know what ???
    37601 = ( 9999*9999 ) //65536
    incredible !!! ... PBP always shows something " intelligent "
    Try using PBPL anc a 18Fxxxx Pic .... or another calculating method ! ....
    Miami, Florida USA
    There is not much to add after Acetronics excellent explanation. However, if you post your code, we might be able to help you more.
    Nov 2009
    am beginner sorry... can save the result in the memory??? help please or with arrays...
    DEFINE OSC 20
    DEFINE LCD_DREG PORTB 'LCD data port
    DEFINE LCD_DBIT 4 'LCD data starting bit 0 or 4
    DEFINE LCD_RSREG PORTB 'LCD register select port
    DEFINE LCD_RSBIT 0 'LCD register select bit
    DEFINE LCD_EREG PORTB 'LCD enable port
    DEFINE LCD_EBIT 2 'LCD enable bit
    DEFINE LCD_BITS 4 'LCD bus size 4 or 8
    DEFINE LCD_LINES 2 'Number lines on LCD
    DEFINE LCD_COMMANDUS 2000 'Command delay time in us
    DEFINE LCD_DATAUS 50 'Data delay time in us
    alldigital
    TRISC=%11110000
    TRISB=0
    INICIO2:
    X VAR BYTE
    X=0
    Y VAR BYTE
    Y=0
    SUM VAR WORD
    SUM=0
    RES VAR WORD
    RES=0
    MUL VAR word
    MUL=0
    DIVIN VAR WORD
    DIVIN=0
    DIVDEC VAR WORD
    DIVDEC=0
    DECI VAR WORD
    DECI=0
    G VAR byte
    G=0
    H VAR byte
    H=0
    I VAR byte
    I=0
    P VAR byte
    P=0
    J VAR BYTE
    J=0
    K VAR word
    K=0
    L VAR WORD
    L=0
    FLAG VAR BYTE
    FLAG=0
    CLC VAR BYTE
    CLC=0
    A VAR PORTC.0
    B VAR PORTC.1
    C VAR PORTC.2
    D VAR PORTC.3
    UNO VAR PORTC.4
    DOS VAR PORTC.5
    TRES VAR PORTC.6
    CUATRO VAR PORTC.7
    LCDOUT $FE, 1
    INICIO:
    'TECLADO
    HIGH A
    IF UNO=1 THEN X=1
    IF DOS=1 THEN X=2
    IF TRES=1 THEN X=3
    IF CUATRO=1 THEN X=10
    IF UNO=1 || DOS=1 || TRES=1 || CUATRO=1 THEN GOSUB ANTIREBOTE:Y=Y+1
    PAUSE 10
    LOW A
    HIGH B
    IF UNO=1 THEN X=4
    IF DOS=1 THEN X=5
    IF TRES=1 THEN X=6
    IF CUATRO=1 THEN X=11
    PAUSE 10
    LOW B
    HIGH C
    IF UNO=1 THEN X=7
    IF DOS=1 THEN X=8
    IF TRES=1 THEN X=9
    IF CUATRO=1 THEN X=12
    PAUSE 10
    LOW C
    HIGH D
    IF UNO=1 THEN X=20 'ON
    IF DOS=1 THEN X=0
    IF TRES=1 THEN X=14 'ENTER
    IF CUATRO=1 THEN X=13
    PAUSE 10
    LOW D
    IF Y=1 && X<10 THEN G=X:LCDOUT $FE, 2, #X
    IF Y=2 && X<10 THEN H=X:LCDOUT $FE, 2, #G, #X
    IF Y=3 && X<10 THEN I=X:LCDOUT $FE, 2, #G, #H, #X
    IF Y=4 && X<10 THEN P=X:LCDOUT $FE, 2, #G, #H, #I, #X
    IF FLAG=0 && Y=0 THEN LCDOUT $FE, 2, "0  "
    IF X=10 THEN LCDOUT $FE, 2, "+   "
    IF X=11 THEN LCDOUT $FE, 2, "-   "
    IF X=12 THEN LCDOUT $FE, 2, "*   "
    IF X=13 THEN LCDOUT $FE, 2, "/   "
    IF X=20 THEN GOTO INICIO2
    'PRIMER NUMERO
    IF FLAG=0 THEN
        IF Y=2 && X>=10 THEN
        J=X
        K=G
        LCDOUT $FE, 2, #K
        PAUSE 100
        FLAG=1
        Y=0
        G=0:H=0:I=0:P=0
        if y=3 && x>=10 THEN
        J=X
        K=(G*10)+H
        LCDOUT $FE, 2, #K
        PAUSE 100
        FLAG=1
        Y=0
        G=0:H=0:I=0:P=0
        IF Y=4 && X>=10 THEN
        J=X
        K=(g*100)+(H*10)+(i)
        LCDOUT $FE, 2, #K
        PAUSE 100
        FLAG=1
        Y=0
        G=0:H=0:I=0:P=0
        IF Y=5 && X>=10 THEN
        J=X
        K=(g*1000)+(H*100)+(i*10)+P
        LCDOUT $FE, 2, #K
        PAUSE 100
        FLAG=1
        Y=0
        G=0:H=0:I=0:P=0
    'SEGUNDO NUMERO
    iF FLAG=1 THEN
        IF Y=2 && X=14 THEN
        L=G
        LCDOUT $FE, 2, #L
        PAUSE 100
        CLC=1
        GOSUB OPERACIONES
        IF Y=3 && X=14 THEN
        L=(G*10)+H
        LCDOUT $FE, 2, #L
        PAUSE 100
        CLC=1
        GOSUB OPERACIONES
        IF Y=4 && X=14 THEN
        L=(g*100)+(H*10)+i
        LCDOUT $FE, 2, #L
        PAUSE 100
        CLC=1
        GOSUB OPERACIONES
        IF Y=5 && X=14 THEN
        L=(g*1000)+(H*100)+(i*10)+P
        PAUSE 10
        LCDOUT $FE, 2, #L
        PAUSE 100
        CLC=1
        GOSUB OPERACIONES
    GOTO INICIO
    ANTIREBOTE:
    GOTO ANTIREBOTE
    OPERACIONES:
    IF CLC=1 THEN
        IF J=10 THEN
        SUM=K+L
        LCDOUT $FE, 2, #k, "+", #l,"="
        LCDOUT $FE, $C0, #SUM
        PAUSE 100
        X=0
        IF J=11 THEN
            IF L>K THEN
            RES=L-K
            LCDOUT $FE, $C0,"-", #RES
            RES=K-L
            LCDOUT $FE, $C0, #RES
        LCDOUT $FE, 2, #K, "-",#L,"="
        PAUSE 100
        X=0
        IF J=12 THEN
        MUL=(K*L)
        LCDOUT $FE, 2, #k, "*",#L,"="
        LCDOUT $FE, $C0, #MUL
        PAUSE 100
        X=0
        IF J=13 THEN
        DIVIN=K/L
        DIVDEC=K//L
        DECI=(DIVDEC*100)/L
        LCDOUT $FE, 2, #k, "/",#L,"="
        LCDOUT $FE, $C0, #DIVIN,".",#DECI
        PAUSE 100
        X=0
    HIGH D
    IF DOS=1 THEN X=0
    PAUSE 10
    LOW D
    IF X=20 THEN LCDOUT $FE,1,"0":GOTO INICIO2
    GOTO OPERACIONES
    GOTO INICIO
  1. High Resolution Timer & Speed Calculator
    By WOZZY-2010 in forum Code Examples
    Last Post: - 7th February 2010, 16:45
  2. Tmro Tmr1 Calculator
    By kevin in forum mel PIC BASIC Pro
    Last Post: - 17th April 2006, 17:39
  3. help with my calculator project
    By loayaouad in forum mel PIC BASIC Pro
    Last Post: - 17th May 2005, 07:42
  4. Calculator
    By neiron21 in forum mel PIC BASIC Pro
    Last Post: - 1st February 2005, 00:53
  5. Baud Rate and Timing Calculator
    By picnaut in forum General
    Last Post: - 23rd January 2004, 16:48
