Pickit3 from Microcode Studio
Results 1 to 21 of 21
    Default Pickit3 from Microcode Studio
    I have discovered the programming parameters to program using Pickit3 directly
    from Microcode Studio IDE.
    I downloaded Microchip MPLAB latest 8.4, uninstalled previous version and
    installed new to its default directory.
    MPLAB automatically upgraded the firmware of the Pickit3 on first run.
    The Programmer name for the IDE is PK3CMD.exe and is located at:
    C:\Program Files\Microchip\MPLAB IDE\Programmer Utilities\Pickit3\PK3CMD.exe
    The parameters are:
    -P$target-device$ -F$hex-filename$ -E -M -B -L
    The -B (batch) is only to keep the DOS window open after programming to
    see completion messages and could be left out. A space bar press will exit DOS.
    The -L will release the MCLR.
    Add an V5 or V.3 and possibly other voltages to power the PIC from the Pickit3 USB.
    Enjoy.
    Norm
    Sep 2007
    Waco, Texas
    Hello- I just got my PICkit 3 and tried your config data but all I get is a DOS window, then it goes away and nothing seems to happen.
    I do not have the programmer plugged into the RJ socket because I wanted to see it bring up the programmer first.
    Do I need to have it plugged into the target in order to bring up the programmer?
    "If we knew what we were doing, it wouldn't be called research"
    - Albert Einstein
    I believe so, yes.
    Norm
    Jan 2012
    Grid EN19MV
    Default Re: Pickit3 from Microcode Studio
    The parameters are:
    Thanks for this - the only thing I added to your parameter list is -Y since I like to verify after programming.
    Andy
    -Stephen Hawking
    Feb 2004
    Michigan, USA
    IS this the Microchip version or the Olimex version? I am considering picking up the Olimex version from Digikey for about $42US.
    http://www.digikey.com/product-detai...066-ND/3471442
    The parameters apply to the PICKit 3 from Microchip but if the Olimex unit is compatible it should be compatible.
    On the other hand, why by a clone when the genuine one is the same price?
    If you want a clone they are available on EBAY or from places like SURE Electronics for ~$29 including shipping.
    Does the debugging feature work with PK3 and MCS?
    No, I'm afraid not.
    Source level debugging is only available from within MPLAB as far as I know. It's one of the reasons I've been wanting to "get into" MPLAB X.
    I wish they'd add it to MCSX though, that and code folding.
    Feb 2004
    Michigan, USA
    Honestly, I havent checked. I was going to buy a U2 but this is around 60% of the price and I can have it in the morning. I hadnt looked around for the Microchip version because I assumed it would be a higher price.
    Apr 2007
    Pennsylvania, USA
    $44.95 from Digikey for a real PICKit 3 http://www.digikey.com/product-detai...130-ND/2171224
    Shawn
    ...If you want a clone they are available on EBAY or from places like SURE Electronics for ~$29 including shipping.
    I can second the use of the clone at SURE Electronics.
    Norm
    The comments on the Sure unit scares me. I'd be tempted to buy the other one above.
    Feb 2004
    Michigan, USA
    Quote Originally Posted by spcw1234 View Post
    I knew I'd seen it on Digikey in an earlier search! Thanks. Couldn't find it yesterday, not sure why it didnt appear. Is this directly compatible with Microcode Studio? I've only ever used an old EPIC and a U2 which are awesomely simply to use with their GUI interface.
    Hi Robert,
    My original purchase of PICKIT2 was actual microchip and it failed in short order, which by the fact I paid them licensed me to buy the clones which to my mind are better, have lasted longer, cost 1/2 as much and even bear the PICKIT 2 & PICKIT3 logos, and run without a hitch on microchip software. It is possible they are licensed vendors. I have had zero issues with Sure's products.
    Jan 2012
    Grid EN19MV
    Quote Originally Posted by Archangel View Post
    +1 - what he said
    -Stephen Hawking
    Feb 2004
    Michigan, USA
    I ended up taking a Mircochip version from Digikey.
    Dec 2007
    Finland
    I ended up also to purchase PicKit 3, but I'm not very satified with it (I have had it now 2 days). In MPLAB mode (MPLAB IDE & MPLAB X IDE), operation has been poor. So far I have not managed to program any hex succesfully. I have tested old and new MPLAB's (GUI & command line), but always there have been some issues. With GUI prommers PicKit is detected OK, firmware downloads OK, but when I try to read, write, erase, etc.. there are problems. With command line (e.g via MicroCode Studio) I managed to erase, flash and verify, which was kind of promising event. Anyway, there was issues to run flashed hex in PIC.
    I downloaded PICkit 3 v3.10 standalone prommer software, which started to work OK when bundled firmware files were installed. Now it auto-detect PICs, read & write & verify OK and works otherwise fine.
    I read recently MPLAB mode (in MicroCode Studio) programmed PIC with standalone prommer and surprisingly part of code did not match with original hex. That was the reason why PIC did not work.
    I thought that Microchip tools (mine is from Sure's) would work a little bit more reliable way. Even my old handmade serial port flashing prommer is more reliable and better working that Microchip commercial one.
    I'm not really happy, but happy enough that it is working. My old serial port (COM) prommer had issues with some of the laptops (docking station with com port) so that I had to purchase USB based prommer.
    Hmm, I've never had problems like that with my PICkit3. At one time I thought I had bricked it since it wouldn't change firmware between MPLAB and standalone programmer mode but after a while it gave in started working again, other than that it's been working just fine for years, with MPLAB, with the stand alone application and with command line interface (which is what I use 90% of the time).
    Seeing you got it from Sure Electronics and seeing they are selling both what appears to be genuine PK3s from Microchip (the red/clear ones) AND clones (the black ones), which one did you get?
    Make sure you pay attention to the target Circuit design precautions shown in the "PICKit3 poster".
    Dec 2007
    Finland
    Cmd line MPLAB via MicroCode Studio and PICkit v3.10 seems to work now OK, which is good
    But, GUI MPLAB's still seems to have some issues:
    MPLAB X IPE v2.00
    Target device was not found. You must connect to a target device to use PICkit 3.
    MPLAB IDE (v8.92)
    PK3Err0045: You must connect to a target device to use PICkit 3.
    Firmware upgrades/changes were successful in both GUI environments.
    In all cases I have used same HW, so that is not an issue (and yes, PIC was connected to PK3). I think issue in PICkit SW...
    My PICkit 3 is real Microchip one (made in China). Same poster was in package
    How do you power your circuit?
    Depending on how the command line switches are set it may be that the commaŽnd line interface is set to provide power to your circuit while, when you you're programming from within MPLAB, thePICKit3 is not set to provide Power to the circuit.
    Dec 2007
    Finland
    Thanks Henrik!
    It seems that GUI MPLAB's needed additional setting to power the target.
    Power -> Power Target Circuit from Tool (ICSP Options)
    Now it work like a charm.
  1. 16F877A Microcode Studio won't compile
    By curt66111 in forum mel PIC BASIC Pro
    Last Post: - 25th November 2009, 20:35
  2. Microcode studio loader problem
    By woodygjw in forum General
    Last Post: - 10th September 2007, 02:18
  3. Microcode studio and USB pics
    By KPDes in forum mel PIC BASIC Pro
    Last Post: - 27th May 2007, 10:28
  4. Replies: 2
    Last Post: - 9th February 2006, 23:03
  5. How to used ICD of microcode studio
    Last Post: - 19th November 2005, 01:29
