Pickit3 from Microcode Studio
Results 1 to 21 of 21
    Default Re: Pickit3 from Microcode Studio
    Hmm, I've never had problems like that with my PICkit3. At one time I thought I had bricked it since it wouldn't change firmware between MPLAB and standalone programmer mode but after a while it gave in started working again, other than that it's been working just fine for years, with MPLAB, with the stand alone application and with command line interface (which is what I use 90% of the time).
    Seeing you got it from Sure Electronics and seeing they are selling both what appears to be genuine PK3s from Microchip (the red/clear ones) AND clones (the black ones), which one did you get?
    Make sure you pay attention to the target Circuit design precautions shown in the "PICKit3 poster".
    Dec 2007
    Finland
    Cmd line MPLAB via MicroCode Studio and PICkit v3.10 seems to work now OK, which is good
    But, GUI MPLAB's still seems to have some issues:
    MPLAB X IPE v2.00
    Target device was not found. You must connect to a target device to use PICkit 3.
    MPLAB IDE (v8.92)
    PK3Err0045: You must connect to a target device to use PICkit 3.
    Firmware upgrades/changes were successful in both GUI environments.
    In all cases I have used same HW, so that is not an issue (and yes, PIC was connected to PK3). I think issue in PICkit SW...
    My PICkit 3 is real Microchip one (made in China). Same poster was in package
    How do you power your circuit?
    Depending on how the command line switches are set it may be that the commaŽnd line interface is set to provide power to your circuit while, when you you're programming from within MPLAB, thePICKit3 is not set to provide Power to the circuit.
    Dec 2007
    Finland
    Thanks Henrik!
    It seems that GUI MPLAB's needed additional setting to power the target.
    Power -> Power Target Circuit from Tool (ICSP Options)
    Now it work like a charm.
  1. 16F877A Microcode Studio won't compile
    By curt66111 in forum mel PIC BASIC Pro
    Last Post: - 25th November 2009, 19:35
  2. Microcode studio loader problem
    By woodygjw in forum General
    Last Post: - 10th September 2007, 01:18
  3. Microcode studio and USB pics
    By KPDes in forum mel PIC BASIC Pro
    Last Post: - 27th May 2007, 09:28
  4. Replies: 2
    Last Post: - 9th February 2006, 22:03
  5. How to used ICD of microcode studio
    Last Post: - 19th November 2005, 00:29
