Hi people, try-outs continue
I started to try different baud rates with different crystals as below:
4Mhz/2400 - 4Mhz/4800 - 8Mhz/4800 - 8Mhz/9600
But during these changes, of course I need to make some different definitions about serial communication:
'Definitions
DEFINE OSC 4			'for 4 Mhz
'DEFINE OSC 8			'for 8 Mhz
DEFINE HSER_TXSTA 20h	'I wonder shall I define as DEFINE HSER_TXSTA 24h???
DEFINE HSER_RCSTA 90h	'same for all
DEFINE HSER_BAUD 2400	'for 2400 Baud rate
'DEFINE HSER_BAUD 4800	'for 4800 Baud rate
'DEFINE HSER_BAUD 9600	'for 9600 Baud rate
DEFINE HSER_SPBRG 25		'for 4Mhz/2400 & 8Mhz/4800 with an error %0.16
'DEFINE HSER_SPBRG 12	'for 4Mhz/4800 & 8Mhz/9600 with an error %0.16
DEFINE HSER_CLROERR 1	'same for all
'Initialization
TRISB=%00000000
PORTB=%00000000
'Program Starts
BEGIN:
PORTB = 0
HIGH PORTB.7
PAUSE 1000
LOW PORTB.7
HIGH PORTB.6
HSEROUT ["AT",13]	'send AT to modem followed by a CR and line feed
HSERIN 5000, BEGIN, [WAIT("OK")]	'now wait for 5secs until OK is received however
HIGH PORTB.5
PAUSE 500
GOTO BEGIN	'if it is not then goto the SMS routine again
'END
Unfortunately none of above succeeded
