Microcode Problem
Results 1 to 2 of 2
    SergioRM's Avatar
    SergioRM Guest
    Default Microcode Problem
    Hi all,
    Im using Microcrocode Studio, WIN XP Home and PBP 2.43. I was able to compile it. I dont know how, but I have tried during all the weekend but the MCS dont generate the HEX file, only ASM, BAS and MAC.
    I tried everything I could (including formating my laptop) withou success. Yesterday, it showed an error [303]. I've found in pbp txt files that I must change the FILE number on config.sys, but I am using XP HOME!
    Now it compiles, but dont assembler (instead of message thal everything is ok, but I cant find the HEX file).
    Someone had this error? Can anyone help me?
    Best regards,
    Sergio
    Porto - Portugal
    Hi SergioRM
    I´ve once had a similar problem with MCS and WinXP and I decided to (for good) to get rid of WinXP and use Win2000 and it has been working like a Rolls Royce.
    I remember also that for some reason MCS "forgot" where to put the files and the only way I found at that time was to open a window with the directory where I thought MCS whas doing the writings and watch the differents files beeing created by MCS.
    I´ve found a weird thing also, if by any chance within MCS you use the "save as" with the file you are working like for instance myfile.??? to myfile_a.??? next time you compile the new file, it will erase the previous myfile.hex and you only see myfile_a.hex.
    Sorry if my help is not much
    Abraços
    nomada
  1. Microcode Studio ICD serial comms problem
    By spreader in forum Serial
    Last Post: - 13th March 2009, 06:08
  2. Microcode studio loader problem
    By woodygjw in forum General
    Last Post: - 10th September 2007, 01:18
  3. Microcode Studio 18f2455 problem?????
    By volkan in forum mel PIC BASIC Pro
    Last Post: - 21st May 2007, 21:04
  4. Microcode studo complie problem
    Last Post: - 2nd March 2006, 22:34
  5. MicroCode Loader connection problem
    By muskut in forum mel PIC BASIC Pro
    Last Post: - 14th July 2005, 14:54
