Sleep when inactive ... how ?
Results 1 to 7 of 7
    Brussels, Belgium
    Default Sleep when inactive ... how ?
    I'm sure this is simple but I can't find the answer (even with the new improved search engine) so perhaps I'm phrasing the question wrong.
    I want a 16F628 to go to sleep when inactive for say 60secs.
    The code I'm using is constantly looping looking for a trigger signal to go low before firing a camera but I'd like it to power down completely if nothing happens for say 60secs and wake up again and start monitoring the trigger if a PORTB pin changes state.
    Thanks, Andrew
    Aug 2005
    down south
    not sure if this is what your looking for but is what I do with my camera
    ON INTERRUPT GoTo TAKEPIC 'ON PIR TRIP WAKE UP
    INTCON=$90 'ENABLE .2 INTERUPT
    " be nice it's people like me that make people like you look smart"
    yes I read the datasheet, of the 300 pages I understood 10
    Brussels, Belgium
    Possibly
    The thing is I want an LCD to display some relevant info for a short time after the shot is taken but then go to sleep.
    I suppose I could use a timer overflow to trigger the SLEEP command, and reset the timer everytime something happens to keep it awake ?
    Running at 4MHz can I count to 60secs with an internal timer or do I need to use the timer overflow to increment a "second counter" ?
    Andrew
    Bombay, India
    The easiest way would be to count down 60 x 1 second delays using pause. After that time, simply put your PIC to sleep. The delay can be reset by the Interrupt occurence.
    ISR:
       SleepTimeOut = 60
    INT_RETURN
       if SleepTimeOut <> 0 then
              pause  1000
              SleepTimeOut = SleepTimeOut-1
              @ sleep   ' use the ASM sleep command
              @ nop     ' some pics need these 2 nops (the datasheet will tell)
              @ nop
    Lightbulb
    Hi, Andrew
    If your program loops ...
    just count how many loops in a minute ... and go to an @sleep command if value reaches the loops per minute value ...
    just need to add a counter and a test in your loop ...
    Non-blocking solution ...
    Brussels, Belgium
    So Alain,
    One thing that I always find difficult to answer, how can you work out how many clock cycles are used by a particular group of PBP instructions ? I could test it empirically but there must be a way of calculating it.
    Thanks, Andrew
    Brussels, Belgium
    ISR:
       SleepTimeOut = 60
    INT_RETURN
              pause  1000
              @ nop
    Would work but then I need to rewrite my code - I don't trigger off an interrupt but instead look at PortB which holds not just the trigger signal but also a small keypad. The unit I'm making isn't just a simple "fire", there is also a small menu system to enter a few system parameters.
    Not impossible to rewrite but perhaps I'll just count how many times I loop and conditionally branch ..
    Thanks, Andrew
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 09:00
  2. Battery powered applications
    Last Post: - 22nd June 2009, 07:12
  3. 16F628A current high during sleep
    Last Post: - 9th October 2006, 10:21
  4. Wierd sleep issue
    By orca in forum mel PIC BASIC Pro
    Last Post: - 14th March 2006, 22:06
  5. SLEEP Command and Interupts 16F648A
    By ghoot in forum mel PIC BASIC Pro
    Last Post: - 28th May 2004, 18:35
