How to read 4 el.mech.counters?
Results 1 to 11 of 11
    Jan 2008
    Default How to read 4 el.mech.counters?
    Hello !!!
    I need help. I want to make a interface that will read impulses from 4 electro mechanical counters at once. The counters operate at different speeds and duration. I have solution for 2 counters, but for 4, hm? Please HELP
    DEFINE OSC 8
    pinin	VAR	PORTC.7
    pinout	VAR	PORTC.6
    TRISB = 255
    B var byte
    Serout2 pinout,84,["OK"]
         B = PORTB
         pause 10
         If PORTB <> 255 then Counter
         goto Main
    Counter:
       B = PORTB
       SELECT CASE B
          CASE 255
               GOTO MAIN
          CASE 254
               Serout2 pinout,84,["1"]  'counter 1'
               GOTO CEK
          CASE 253
               Serout2 pinout,84,["2"]  'counter 2'
               GOTO CEK1
          CASE 252
               Serout2 pinout,84,["3"]  'counter 1 and counter 2'
               GOTO CEK2
       END SELECT
      GOTO Counter
    CEK:
      B = PORTB
         SELECT CASE B
          CASE 255
               GOTO MAIN
          CASE 253
               GOTO CEK1
          CASE 252
               GOTO CEK2
       END SELECT
       GOTO CEK
    CEK1:
      B = PORTB
         SELECT CASE B
          CASE 255
               GOTO MAIN
          CASE 254
               GOTO CEK
          CASE 252
               GOTO CEK2
       END SELECT
       GOTO CEK1
    CEK2:
      B = PORTB
         SELECT CASE B
          CASE 255
               GOTO MAIN
          CASE 253
              GOTO CEK1
          CASE 254
              GOTO CEK
       END SELECT
       GOTO CEK2
    Well, I can't offer any suggestions for fixing what you have, other than CTRL-A/DEL.
    Give this a try with HyperTerminal or equivalent @ 19200 baud.
    I'm assuming it's a 16F877.
    <font color="#008000"><b>CLEAR                              </b></font><font color="#0000FF"><b><i>' Clear all User RAM
    </i></b></font><font color="#008000"><b>DEFINE </b></font><b>OSC </b><font color="#800000"><b>8                       </b></font><font color="#0000FF"><b><i>' change to match your crystal
    </i></b></font><font color="#008000"><b>DEFINE </b></font><b>LOADER_USED </b><font color="#800000"><b>1               </b></font><font color="#0000FF"><b><i>' if using a bootloader
    </i></b></font><font color="#008000"><b>DEFINE </b></font><b>HSER_BAUD </b><font color="#800000"><b>19200             </b></font><font color="#0000FF"><b><i>' Hser baud rate
    </i></b></font><font color="#008000"><b>DEFINE </b></font><b>HSER_CLROERR </b><font color="#800000"><b>1              </b></font><font color="#0000FF"><b><i>' Hser clear overflow automatically
    </i></b></font><font color="#008000"><b>DEFINE </b></font><b>HSER_RCSTA </b><font color="#800000"><b>90</b></font><b>h              </b><font color="#0000FF"><b><i>' Hser receive status init
    </i></b></font><font color="#008000"><b>DEFINE </b></font><b>HSER_TXSTA </b><font color="#800000"><b>24</b></font><b>h              </b><font color="#0000FF"><b><i>' Hser transmit status init
    </i></b></font><b>B        </b><font color="#008000"><b>VAR BYTE
    </b></font><b>LastB    </b><font color="#008000"><b>VAR BYTE                  </b></font><font color="#0000FF"><b><i>' state of pins Last time they changed
    </i></b></font><b>Diff     </b><font color="#008000"><b>VAR BYTE                  </b></font><font color="#0000FF"><b><i>' Difference tween Last and Current bits
    </i></b></font><b>Active   </b><font color="#008000"><b>VAR BYTE                  </b></font><font color="#0000FF"><b><i>' Indicates which inputs are active(LOW)
    </i></b></font><b>Idx      </b><font color="#008000"><b>VAR BYTE                  </b></font><font color="#0000FF"><b><i>' generic loop counter
    </i></b></font><b>Counter  </b><font color="#008000"><b>VAR WORD</b></font>[<font color="#800000"><b>4</b></font>]               <font color="#0000FF"><b><i>' The values of the counters
    </i></b></font><b>OPTION_REG</b>.<font color="#800000"><b>7 </b></font>= <font color="#800000"><b>0                   </b></font><font color="#0000FF"><b><i>' enable PORTB pull-ups
    ;---[clear screen + display menu]-------------------------------------------
    </i></b></font><b>Refresh</b>:
        <font color="#008000"><b>HSEROUT </b></font>[<font color="#800000"><b>27</b></font>,<font color="#FF0000">&quot;[2J&quot;</font>,<font color="#800000"><b>10</b></font>,<font color="#800000"><b>10</b></font>,<font color="#800000"><b>10</b></font>,<font color="#800000"><b>10</b></font>,<font color="#800000"><b>10</b></font>,<font color="#800000"><b>10</b></font>, <b>_
                 </b><font color="#FF0000">&quot; A=clear All, (1-4)=Clear Counter#, R=Refresh screen&quot;</font>]
        <font color="#008000"><b>GOTO </b></font><b>DisplayCounters
    Main</b>:
        <font color="#0000FF"><b><i>;---[Handle incoming serial data]---------------------------------------
        </i></b></font><font color="#008000"><b>IF </b></font><b>PIR1</b>.<font color="#800000"><b>5 </b></font><font color="#008000"><b>THEN                 </b></font><font color="#0000FF"><b><i>' If serial data has been received
            </i></b></font><font color="#008000"><b>HSERIN </b></font>[<b>Idx</b>]               <font color="#0000FF"><b><i>' get the byte
            </i></b></font><font color="#008000"><b>SELECT CASE </b></font><b>Idx            </b><font color="#0000FF"><b><i>' What did we receive?
              </i></b></font><font color="#008000"><b>CASE </b></font><font color="#FF0000">&quot;A&quot;</font>,<font color="#FF0000">&quot;a&quot;             </font><font color="#0000FF"><b><i>' A - Clear all counters
                  </i></b></font><font color="#008000"><b>FOR </b></font><b>Idx </b>= <font color="#800000"><b>0 </b></font><font color="#008000"><b>TO </b></font><font color="#800000"><b>3
                    </b></font><b>Counter</b>(<b>Idx</b>) = <font color="#800000"><b>0
                  </b></font><font color="#008000"><b>NEXT </b></font><b>Idx
                  </b><font color="#008000"><b>GOTO </b></font><b>DisplayCounters
              </b><font color="#008000"><b>CASE </b></font><font color="#FF0000">&quot;R&quot;</font>,<font color="#FF0000">&quot;r&quot;             </font><font color="#0000FF"><b><i>' Refresh ANSI Terminal screen
                  </i></b></font><font color="#008000"><b>GOTO </b></font><b>Refresh
              </b><font color="#008000"><b>CASE </b></font><font color="#FF0000">&quot;1&quot;</font>,<font color="#FF0000">&quot;2&quot;</font>,<font color="#FF0000">&quot;3&quot;</font>,<font color="#FF0000">&quot;4&quot;     </font><font color="#0000FF"><b><i>' numbers clear that counter only
                  </i></b></font><b>Counter</b>(<b>Idx </b>- <font color="#FF0000">&quot;1&quot;</font>) = <font color="#800000"><b>0
                  </b></font><font color="#008000"><b>GOTO </b></font><b>DisplayCounters
              </b><font color="#008000"><b>CASE ELSE
                  HSEROUT </b></font>[<font color="#800000"><b>8</b></font>,<font color="#800000"><b>7</b></font>]         <font color="#0000FF"><b><i>' send backspace + bell
            </i></b></font><font color="#008000"><b>END SELECT
        </b></font><font color="#0000FF"><b><i>'---[Count Pulses]------------------------------------------------------
        </i></b></font><b>B </b>= <b>PORTB </b>&amp; <font color="#800000"><b>$F0                </b></font><font color="#0000FF"><b><i>' isolate upper 4-bits
        </i></b></font><b>Diff </b>= <b>B </b>^ <b>LastB               </b><font color="#0000FF"><b><i>' see if any of them changed
        </i></b></font><font color="#008000"><b>IF </b></font><b>Diff </b>!= <font color="#800000"><b>0 </b></font><font color="#008000"><b>THEN              </b></font><font color="#0000FF"><b><i>' if any of them changed
            </i></b></font><b>LastB </b>= <b>B
            Active </b>= <b>Diff </b>&amp; ~<b>B         </b><font color="#0000FF"><b><i>' determine which ones are Active
            </i></b></font><font color="#008000"><b>IF </b></font><b>Active </b>!= <font color="#800000"><b>0 </b></font><font color="#008000"><b>THEN
                IF </b></font><b>Active</b>.<font color="#800000"><b>4 </b></font><font color="#008000"><b>THEN </b></font><b>Counter</b>(<font color="#800000"><b>0</b></font>) = <b>Counter</b>(<font color="#800000"><b>0</b></font>) + <font color="#800000"><b>1 </b></font><font color="#0000FF"><b><i>' increment actives
                </i></b></font><font color="#008000"><b>IF </b></font><b>Active</b>.<font color="#800000"><b>5 </b></font><font color="#008000"><b>THEN </b></font><b>Counter</b>(<font color="#800000"><b>1</b></font>) = <b>Counter</b>(<font color="#800000"><b>1</b></font>) + <font color="#800000"><b>1
                </b></font><font color="#008000"><b>IF </b></font><b>Active</b>.<font color="#800000"><b>6 </b></font><font color="#008000"><b>THEN </b></font><b>Counter</b>(<font color="#800000"><b>2</b></font>) = <b>Counter</b>(<font color="#800000"><b>2</b></font>) + <font color="#800000"><b>1
                </b></font><font color="#008000"><b>IF </b></font><b>Active</b>.<font color="#800000"><b>7 </b></font><font color="#008000"><b>THEN </b></font><b>Counter</b>(<font color="#800000"><b>3</b></font>) = <b>Counter</b>(<font color="#800000"><b>3</b></font>) + <font color="#800000"><b>1
            </b><font color="#008000"><b>ENDIF
        PAUSE </b></font><font color="#800000"><b>20
    </b></font><font color="#008000"><b>GOTO </b></font><b>Main
    </b><font color="#0000FF"><b><i>'--[Display Counter Values]-------------------------------------------------
    </i></b></font><b>DisplayCounters</b>:
        <font color="#008000"><b>HSEROUT </b></font>[<font color="#800000"><b>27</b></font>,<font color="#FF0000">&quot;[H&quot;</font>]      <font color="#0000FF"><b><i>' home cursor (ANSI)
        </i></b></font><font color="#008000"><b>FOR </b></font><b>Idx </b>= <font color="#800000"><b>0 </b></font><font color="#008000"><b>TO </b></font><font color="#800000"><b>3       </b></font><font color="#0000FF"><b><i>' display all counter values
            </i></b></font><font color="#008000"><b>HSEROUT</b></font>[<font color="#008000"><b>DEC </b></font>(<b>Idx</b>+<font color="#800000"><b>1</b></font>),<font color="#FF0000">&quot;: &quot;</font>,<font color="#008000"><b>DEC5 </b></font><b>Counter</b>(<b>Idx</b>),<font color="#800000"><b>13</b></font>,<font color="#800000"><b>10</b></font>]
        </b><font color="#008000"><b>HSEROUT </b></font>[<font color="#800000"><b>13</b></font>,<font color="#800000"><b>10</b></font>]
    </b>
    Cheers,
    Nice programming Darrel.
    I was just wondering, are really typing all these control characters < / i >< / b > < / font >< font color="#008000">< b > or is there a trick for this effects?
    As always there is the obvious in front of us but we try to see further....
    Wink
    Hi, Darrel
    Could you explain the second Item in the list: "[2J"
    and further
    DisplayCounters:
        HSEROUT [27,"[H"]      ' home cursor (ANSI)
    this one : "[H" ???
    May be simple for you, but unknown for me !!!
    BTW: Thanks for the example ... as I just begin serial comms use to pass parameters to and from my PICs and the PC. ( PC is an horrible black box ... I never look into, as you've understood : LOL )
    Alain, this is the ANSI escape codes for the terminals. It does exactly what Darrel remarked, Home position in the terminal window.
    Question
    Hi, Ioannis
    Thanks, but what I do not understand is ... both place cursor @ home position ...
    further question will be :
    is there any table or link to these codes ??? ...
    Ok Ioannis
    With the right words ... Google is my friend !
    http://ascii-table.com/ansi-escape-sequences.php
  1. Cleaning up code
    Last Post: - 2nd December 2009, 07:14
  2. SEROUT WORD variable problem
    Last Post: - 19th April 2009, 11:20
  3. Microcontroller with 2 way paging application problem
  4. Changing declared variables names on the fly
    Last Post: - 16th December 2006, 06:34
  5. How to read data 4 bit
    Last Post: - 11th December 2006, 05:07
