Switch Sequence
Results 1 to 12 of 12
Thread: Switch Sequence
    Feb 2005
    Essex, UK
    Default Switch Sequence
    I am very new to PICs, so any help is greatly appriciated. I have scowled the NET and this seems the friendliest place for help.
    I would like to develop using a 16F876 a small application that had 1 switch as input, say on RB0. Then each time the switch is pressed a different LED routine is actioned.
    So for example:
    1st switch push, LED on RC0 stays on
    2nd switch push, LED on RC1 blinks
    3rd switch push, LEDs on RC2 and RC3 'wink'
    etc etc.
    Once the, say 3 routines are completed, it goes back to the first again.
    Can anyone help with this or point me in the right directionto get me going. I'm keen to learn about PICs as they have so many uses.
    Many thanks for any anticipate help.
    .... that had 1 switch as input, say on RB0. Then each time the switch is pressed a different LED routine is actioned.
    So for example:
    As i don't know what 'wink' mean... this is something to help you to start...
    There's so many different way but... Never tested but should work.
    ADCON1=7       'disable analog to digital converter
    OPTION_REG.7=0 'enable pull-up resistor on PORTb
    PushButton var PORTB.0 ' pushButton connected between RB0
                           ' and ground
    Led1 VAR PORTC.0 ' All LEDs
    Led2 VAR PORTC.1 ' Connected between
    Led3 VAR PORTC.2 ' RC pins and ground
    Led4 VAR PORTC.3 ' via resistor
    PushHowManyTimes var byte
    Delay VAR BYTE
    Delay=0
    PushHowManyTimes=0
    start:
         While pushbutton ' do the specific task untill pushbutton
                          ' is pressed
              branch PushHowManyTimes , [Start,StayOn,Blink]
         wend
         PushHowManytimes=PushHowManytimes+1 ' Changing task
         if PushHowManytimes=3 then PushHowManytimes=1
         while pushbutton=0 ' waiting untill pushbutton is release
         wend
         pause 50 ' debounce time
         goto start
    StayOn:
         High PORTC.0
         goto start
    Blink:
         Low PORTC.0
         If delay<50 then
              High PORTC.1
              If delay<100 then
                   low PORTC.1
                   delay=0
         pause 10
         Delay=delay+1
         goto start
    Feb 2005
    Essex, UK
    Thanks very much for your help Steve, this is exactly what i wanted and it is a good platform to expand from.
    One question, is it possible to permantly monitor the switch input.
    For example, when the switch is pressed, the program BRANCHes to a preset routine. However, if this preset routine is a long one , ie multiple LED flashes etc, it will only look at the switch input at the end of this preset routine (when it 'goto START') and not during the routine.
    ie.
    Blink:
    Low PORTC.0
    If delay<50 then
    High PORTC.1
    If delay<100 then
    low PORTC.1
    delay=0
    pause 10
    Delay=delay+1
    goto start *** ONLY LOOKS AT SWITCH INPUT HERE AND NOT DURING ROUTINE ***
    Does this make sense, i need to permantly monitor the switch input no matter what else the code is doing elsewhere.
    Many thanks again,
    hi,
    In the above section, it monitor the switches every 10ms. Close to be constant monitoring.
    BTW, i case you have more complex routines, the most interesting stuff to do it is to use interrupts (rb0 or else other interrupt source that your PIC can provide).
    In this case, it will monitor in background your push button and jump to the "interrupt handler" when he is pressed. In the interrupt handler, set a flag or variable that will say to your previous task that you have to change to another task.
    Feb 2005
    Essex, UK
    I have read some notes on inturrupts and have come up with the following, however, it doesn't do anything !! Of course with what i know about PICs, im not surprised. I am learning quickly though !!
    This is what i have so far. Can you correct me if i've gone wrong on the interrupt side please?
    Led5 Var PORTC.4 '
    ON INTERRUPT GOTO start ' Interrupt handler is start
    INTCON = %10010000 ' Enable RB0 interrupt
    Bright var byte
    Delay VAR BYTE
    Delay=0
    PushHowManyTimes=0
    start:
    DISABLE ' Disable interrupts in handler
    branch PushHowManyTimes , [Start,StayOn,Blink,Fade,Wink]
    If PushHowManytimes=5 then PushHowManytimes=1
    RESUME ' Return to main program
    ENABLE ' Enable interrupts after handler
    GOTO START
    StayOn **** Routine *****
    etc etc etc etc
    Blink **** Routine *****
    etc etc etc etc
    Many thanks for any help received.
    not too far. You didn't define the RB0 interrupt type (falling edge)
    and i do my own version. Hope this work and help you.
    ' I/O definition
    TRISC=0   ' Set PORTC as OUTPUT
    TRISB.0=1 ' Set PORTB.1 as input
    Led5 Var PORTC.4 '
    ' register and interrupt definition
    OPTION_REG=0 ' enable pull-up resistor on PORTb
                 ' Interrupt on falling edge of RB0
    ON INTERRUPT GOTO  ProcedureSwitcher
    ' Variable definition
    Bright           var byte
    Delay            VAR WORD
    DelayLoop        var Word
    ' Variable initialisation
    PORTC=0 ' Reset all outputs on PORTC
    PushHowManyTimes=0
    start:
          Select Case PushHowManyTimes
                 case 1
                      gosub StayOn
                 Case 2
                      gosub Blink
                 ' Place your other procedure here
          end select
          goto start
    StayOn:
         PORTC.0 = 1
    Blink:
         Toggle PORTC.1
         Delay = 500
         Gosub DoDelay
    ' I do a Delay Loop to be sure getting all interrupt withou latency
    DoDelay:
         For DelayLoop=0 to Delay
              pause 1
         Next
    '  Interrupt handler stuff here
    ProcedureSwitcher:
         PORTC=0 ' reset output to PORTC
         DelayLoop=Delay ' to exit the delay loop
         While PORTB.0 = 0 ' waiting for push-button release
         wend
    Feb 2005
    Essex, UK
    Thanks Steve. I've tried but failed !! The code was copied exactly as you have posted it, but didn't seem to work. I've tried to see what the problem is but can't figure it out.
    Just to confirm
    RC0 is Outputs
    RB0 is Switch Input.
    Can you help please.
    Thanks again.
    Damn, the next time i'll test it before sending here.. many apologize. Change to this tested one ;o[
    ' I/O definition
    Led5 Var PORTC.4 '
    HexLed           var byte
    Delay            VAR WORD
    DelayLoop        var Word
    PushHowManyTimes=0
    HexLed=0
    start:
                 case 1
                      gosub StayOn
                 Case 2
                      gosub Blink
                 case 3
                      gosub HEXonPORTC0_1
          end select
          goto start
    StayOn:
         led1 = 1
    Blink:
         Toggle led2
         Delay = 500
         Gosub DoDelay
    HEXonPORTC0_1:
         PORTC=HexLed
         delay=500
         gosub dodelay
         HexLed=HexLed+1
         if HexLed=4 then HexLed=0
    DoDelay:
              pause 1
         Next
    ProcedureSwitcher:
         INTCON.7 = 1 'disable all interrputs
         HexLed=0
         If PushHowManytimes=4 then PushHowManytimes=1
         While PORTB.0 = 0 ' waiting untill
         wend              ' push-button is release
         pause 100 ' debounce time
                            ' reset RB0 interrupt flag
    Feb 2005
    Essex, UK
    Thanks very much, that works great. I'm almost there with the main code now. The one thing i can't figure out though, is that with an Interrupt, should that stop what ever is being processed and then move onto the next procedural call? As part of the sequence i have set up at the moment is some PWM. If this procedure is being processed, and you push the button, it does remember the push, but doesn't move on until the full PWM part of the code has finished its cycle.
    Heres an extract of working code which hopefully demonstartes what i mean. Its a piece of code which makes the LEDs look as if the are fading on and off. I would like to step to the next LED immediately the button is pushed, no matter at what position the fading is at. Can this be done?
    Here it is:
    ' I/O definition
    Red VAR PORTC.0 ' All LEDs
    Green VAR PORTC.1 ' Connected between
    Bright var byte
    PushHowManyTimes VAR byte
    Delay VAR WORD
    DelayLoop VAR Word
    PushHowManyTimes=0
    start:
    case 1
    gosub FadeRed
    Case 2
    gosub FadeGreen
    end select
    goto start
    FadeRed:
    low Red
    for bright = 0 to 255
    PWM Red,Bright,1
    next
    for bright = 255 to 0 step -1
    PWM Red,Bright,1
    next
    FadeGreen:
    low red
    PWM Green,Bright,1
    next
    PWM Green,Bright,1
    next
    DoDelay:
    pause 1
    Next
    ProcedureSwitcher:
    ' HexLed=0
    If PushHowManytimes=3 then PushHowManytimes=1
    Thank you again.
    sure it can be done.
    start:
         case 1
              GetOut = 0
              gosub FadeRed
         Case 2
              GetOut = 0
              gosub FadeGreen
    end select
    goto start
    FadeRed:
         bright = 0
         while (Bright !=255) and (GetOut=0)
              PWM Red,Bright,1
              bright = bright + 1
         wend
         while (bright !=0) and (getout = 0)
              PWM Red,Bright,1
              bright=bright - 1
         wend
    FadeGreen:
         bright = 0
              PWM Green,Bright,1
              bright = bright + 1
         wend
              PWM Green,Bright,1
              bright=bright - 1
         wend
    ProcedureSwitcher:
    GetOut = 1 ' to get out of the entire PWM loops
    Feb 2005
    Essex, UK
    Thanks ever so much for your help Steve. I now have the main body of the code working very well.
    As it is evident that you know your stuff when it comes to Pic Basic, can you recommend any books for learning. I value your opinion.
    Thanks again.
    Sorry to disapointed you but, i can't recommmend any book since i use only the PBP manual and datasheets.
    BUT if you do a search in this forum, on Melabs, on Crownhill and on Reynolds Electronic website, you'll find few books related to PBP.
    Be friend with PBP manual and datasheet will lead you success. I know datasheet are sometime hard to understand but... what is the worst result you'll have ??? compile error, nothing is working... that's food for brain cells
    Have fun!
  1. How can I get a PIC to switch 2.5V DC to my Opamp pin?
    By HankMcSpank in forum Schematics
    Last Post: - 9th January 2010, 23:04
  2. counting switch events beginner
    By mrpete in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2009, 17:08
  3. a switch and 2LED
    By win_832001 in forum mel PIC BASIC
    Last Post: - 11th October 2006, 23:06
  4. Newbie - 16F628A and switch latching
    By malc-c in forum mel PIC BASIC Pro
    Last Post: - 19th May 2006, 03:35
  5. Switch Polling vs Interrupts
    By eric blair in forum General
    Last Post: - 17th October 2003, 10:38
