Be careful that the module you select has a data in = data out feature. Some low cost modules need to have a "balanced" data stream in order to work well.
One of the symptoms is reduced range, the closer you are the more likely the data makes it through the demod stage. The further out you go the more you get DC offsets that creep up and cause the demod to hold states longer causing bit distortion. You should be able to see this on a scope.....latch the tx in continuous transmit at 30m and look at the output of the RX.
Nick
